Home » Modeling » ATL » Ecore 2 Ecore using ATL ->output java objects
Ecore 2 Ecore using ATL ->output java objects [message #879014] Wed, 30 May 2012 11:16 Go to next message
Kosala Yapa is currently offline Kosala YapaFriend
Hi there,
I do ecore model to ecore model transformation using ATL.
Input: aa.xmi
Meta Model: source.ecore
Transformation using ATL
Output: bb.xmi
Meta Model: target.ecore
Problem: The above transformation creates bb.xmi as an output. I know it is possible to read bb.xmi and create java objects in memory. I do not like this approach.
Is it possible to directly create java objects as output in memory instead of above bb.xmi? How can i do that?
Thanks in advance.
Kosala
Re: Ecore 2 Ecore using ATL ->output java objects [message #879059 is a reply to message #879014] Wed, 30 May 2012 12:55 Go to previous messageGo to next message
Ed Willink is currently offline Ed WillinkFriend
I'm pretty sure that ATL works with Java objects and then just saves
them to create the XMI fole, so if you use a Java launch you can access
the output resource to obtain the objects.
Ed Willink
On 30/05/2012 12:16, Kosala Yapa wrote:
> Hi there,
> Input: aa.xmi
> Output: bb.xmi
> Thanks in advance.
> Kosala
Re: Ecore 2 Ecore using ATL ->output java objects [message #881939 is a reply to message #879059] Tue, 05 June 2012 14:21 Go to previous messageGo to next message
Hi Willink,
Here is the java launch, which creates output.xmi. I am trying to find a way to capture java objects in memory.
package org.eclipse.m2m.atl.launch.files;
import java.io.IOException;
import java.io.InputStream;
import java.net.URL;
import java.util.HashMap;
import java.util.Map;
import java.util.Properties;
import java.util.Map.Entry;
import org.eclipse.core.runtime.FileLocator;
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.core.runtime.NullProgressMonitor;
import org.eclipse.core.runtime.Path;
import org.eclipse.core.runtime.Platform;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.xmi.impl.EcoreResourceFactoryImpl;
import org.eclipse.emf.ecore.xmi.impl.XMIResourceFactoryImpl;
import org.eclipse.m2m.atl.common.ATLExecutionException;
import org.eclipse.m2m.atl.core.ATLCoreException;
import org.eclipse.m2m.atl.core.IExtractor;
import org.eclipse.m2m.atl.core.IInjector;
import org.eclipse.m2m.atl.core.IModel;
import org.eclipse.m2m.atl.core.IReferenceModel;
import org.eclipse.m2m.atl.core.ModelFactory;
import org.eclipse.m2m.atl.core.emf.EMFExtractor;
import org.eclipse.m2m.atl.core.emf.EMFInjector;
import org.eclipse.m2m.atl.core.emf.EMFModelFactory;
import org.eclipse.m2m.atl.core.launch.ILauncher;
import org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher;
import target.Device;
import target.TargetPackage;
public class Tpf3 {
private Properties properties;
protected IModel inModel;
protected IModel outModel;
try {
Tpf3 runner = new Tpf3();
runner.loadModels("tpfIN.xmi");
runner.doTpf3(new NullProgressMonitor());
runner.saveModels("tpfOut.xmi");
} catch (ATLCoreException e) {
e.printStackTrace();
} catch (IOException e) {
} catch (ATLExecutionException e) {
}//end main()
public Tpf3() throws IOException {
properties = new Properties();
properties.load(getFileURL("Tpf3.properties").openStream());
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("ecore", new EcoreResourceFactoryImpl());
//System.out.println(properties);
public void loadModels(String inModelPath) throws ATLCoreException {
ModelFactory factory = new EMFModelFactory();
IInjector injector = new EMFInjector();
IReferenceModel sourceMetamodel = factory.newReferenceModel();
injector.inject(sourceMetamodel, getMetamodelUri("source"));
IReferenceModel targetMetamodel = factory.newReferenceModel();
injector.inject(targetMetamodel, getMetamodelUri("target"));
this.inModel = factory.newModel(sourceMetamodel);
injector.inject(inModel, inModelPath);
this.outModel = factory.newModel(targetMetamodel);
public void saveModels(String outModelPath) throws ATLCoreException {
IExtractor extractor = new EMFExtractor();
extractor.extract(outModel, outModelPath);
public Object doTpf3(IProgressMonitor monitor) throws ATLCoreException, IOException, ATLExecutionException {
ILauncher launcher = new EMFVMLauncher();
Map<String, Object> launcherOptions = getOptions();
launcher.initialize(launcherOptions);
launcher.addInModel(inModel, "IN", "source");
launcher.addOutModel(outModel, "OUT", "target");
return launcher.launch("run", monitor, launcherOptions, (Object[]) getModulesList());
protected InputStream[] getModulesList() throws IOException {
InputStream[] modules = null;
String modulesList = properties.getProperty("Tpf3.modules");
if (modulesList != null) {
String[] moduleNames = modulesList.split(",");
modules = new InputStream[moduleNames.length];
for (int i = 0; i < moduleNames.length; i++) {
String asmModulePath = new Path(moduleNames[i].trim()).removeFileExtension().addFileExtension("asm").toString();
modules[i] = getFileURL(asmModulePath).openStream();
return modules;
protected String getMetamodelUri(String metamodelName) {
return properties.getProperty("Tpf3.metamodels." + metamodelName);
protected InputStream getLibraryAsStream(String libraryName) throws IOException {
return getFileURL(properties.getProperty("Tpf3.libraries." + libraryName)).openStream();
protected Map<String, Object> getOptions() {
Map<String, Object> options = new HashMap<String, Object>();
for (Entry<Object, Object> entry : properties.entrySet()) {
if (entry.getKey().toString().startsWith("Tpf3.options.")) {
options.put(entry.getKey().toString().replaceFirst("Tpf3.options.", ""),
entry.getValue().toString());
return options;
protected static URL getFileURL(String fileName) throws IOException {
final URL fileURL;
if (isEclipseRunning()) {
URL resourceURL = Tpf3.class.getResource(fileName);
if (resourceURL != null) {
fileURL = FileLocator.toFileURL(resourceURL);
} else {
fileURL = null;
} else {
fileURL = Tpf3.class.getResource(fileName);
if (fileURL == null) {
throw new IOException("'" + fileName + "' not found");
} else {
return fileURL;
public static boolean isEclipseRunning() {
try {
return Platform.isRunning();
} catch (Throwable exception) {
// Assume that we aren't running.
return false;
Re: Ecore 2 Ecore using ATL -&amp;gt;output java objects [message #882008 is a reply to message #881939] Tue, 05 June 2012 16:05 Go to previous message
After 5 minutes downloading and installing ATL I can see that
IModel has an EMFModel derived class for which the getResource() method
returns a Resource which is usually full of Java model objects.
Try using the Eclipse tooling to help discover what your coding tools do.
Ed Willink
On 05/06/2012 15:21, Kosala Yapa wrote:
> Hi Willink,
> public class Tpf3 {
> public static void main(String[] args) {
> try {
> }//end main()
> return modules;
> metamodelName);
> ""), entry.getValue().toString());
> return options;
> final URL fileURL;
> } else {
> fileURL = null;
> } else {
> } else {
> return fileURL;
> try {
> return false;
> Thanks
Previous Topic:How to create java objects than creating xmi output in ATL transformation?
Next Topic:BPEL 2 XML using ATL
Current Time: Fri Apr 20 18:52:14 GMT 2018
Powered by FUDForum. Page generated in 0.01911 seconds
