Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Texo] ignore not null syntax(Oracle problem with string 0 lenght)
[Texo] ignore not null syntax [message #876896] Fri, 25 May 2012 13:32 Go to next message
Olaf Burdziakowski is currently offline Olaf BurdziakowskiFriend
Member
In my model there is defined String attribute than must be always present but may be empty (empty string).
Problem occurs when Oracle database is connected. Oracle translate zero length string to null (not standard). Than generate an error during insert do database: null to not nulable column.
To make work around I defined column as nulable but ecore model still has this attribute as mandatory.
The problem is that Texo when save xml do not write the attribute to xml file (ignore model, use null value from database as more important. I even tried to make default value:
@Basic()
@Column(name = "xserviceOption", nullable = true)
private String serviceOption = "";
But still with the same result - attribute is not present in output xml.
How to solve this?
Re: [Texo] ignore not null syntax [message #877837 is a reply to message #876896] Sun, 27 May 2012 22:09 Go to previous messageGo to next message
Martin Taal is currently offline Martin TaalFriend
Hi Olaf,
I asked a question about this on the EMF forum. Based on the answer I get I will maybe change this in Texo...
gr. Martin
> @Basic()
> How to solve this?
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] ignore not null syntax [message #877991 is a reply to message #877837] Mon, 28 May 2012 08:56 Go to previous message
Hi Olaf,
Can you enter a bugzilla feature request for this? To always serialize null required elements/attributes.
gr. Martin
On 05/28/2012 12:09 AM, Martin Taal wrote:
> Hi Olaf,
> gr. Martin
>> @Basic()
>> How to solve this?
The Netherlands
Previous Topic:[Texo] Problem with enforce unique names
Next Topic:[EcoreTools] Problem installing on 3.8
Current Time: Sun May 20 21:49:08 GMT 2018
Powered by FUDForum. Page generated in 0.01973 seconds
