Home » Language IDEs » C / C++ IDE (CDT) » Errors when configurin Eclilpse CDT+Cygwin+SystemC
Errors when configurin Eclilpse CDT+Cygwin+SystemC [message #871490] Mon, 14 May 2012 08:04
Iban Ayestaran is currently offline Iban AyestaranFriend
Member
Hello everybody,
I need to compile and debug a SystemC project with Eclipse+Cygwin. I read some documents about how to configure eclipse to do it and I did it accordingly, so my eclipse project is configured like this:
Cygwin C++ Compiler:
_____Includes:
__________"C:\PhD\Cygwin\home\shapes\base\resources\lib\systemc\include"
Cygwin C Compiler:
_____Includes:
Cygwin C++ Linker:
_____Libraries:
__________Libraries:
_______________systemc (the file located in the path is libsystemc.a)
__________Library search path:
_______________"C:\PhD\Cygwin\home\shapes\base\resources\lib\systemc\lib-linux"
However, when I build the project I get some errors similar to this:
undefined reference to `sc_core::sc_module::sc_module(sc_core::sc_module_name const&)'
The most strange thing is that I also have a makefile file generated automatically by another tool, and if I make a makefile project in eclipse it compiles and runs, so I know the code is correct. My problem is that the my makefile does not have any information for debugging, so I cannot debug the code if I generate the executable with it. That is why I want to create a new project in Eclipse, to debug the code.
Does somebody have a clue of what might the problem be?
Thanks in advance,
Iban
P.D: The log of the build I get now is the following:
**** Build of configuration Debug for project Example1_SystemC ****
make all
Building file: ../src/sc_wrappers/consumer_wrapper.cpp
Invoking: Cygwin C++ Compiler
g++ -D__DOL_ETHZ_GEN__ -I"D:\PFC_JZabala\DOL_Iban\Examples_Eclipse\Example1_SystemC\src\lib" -I"D:\PFC_JZabala\DOL_Iban\Examples_Eclipse\Example1_SystemC\src\sc_wrappers" -I"D:\PFC_JZabala\DOL_Iban\Examples_Eclipse\Example1_SystemC\src\processes" -I"D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include" -O0 -g -MMD -MP -MF"src/sc_wrappers/consumer_wrapper.d" -MT"src/sc_wrappers/consumer_wrapper.d" -o "src/sc_wrappers/consumer_wrapper.o" "../src/sc_wrappers/consumer_wrapper.cpp"
../src/sc_wrappers/consumer_wrapper.cpp: In constructor ‘consumer_wrapper::consumer_wrapper(sc_core::sc_module_name)’:
../src/sc_wrappers/consumer_wrapper.cpp:47:51: warning: deprecated conversion from string constant to ‘char*’
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o: In function `consumer_wrapper':
/cygdrive/d/PFC_JZabala/DOL_Iban/Examples_Eclipse/Example1_SystemC/Debug/../src/sc_wrappers/consumer_wrapper.cpp:36: undefined reference to `sc_core::sc_module::sc_module(sc_core::sc_module_name const&)'
/cygdrive/d/PFC_JZabala/DOL_Iban/Examples_Eclipse/Example1_SystemC/Debug/../src/sc_wrappers/consumer_wrapper.cpp:45: undefined reference to `sc_core::sc_module_name::operator char const*() const'
/cygdrive/d/PFC_JZabala/DOL_Iban/Examples_Eclipse/Example1_SystemC/Debug/../src/sc_wrappers/consumer_wrapper.cpp:47: undefined reference to `getIndex(char const*, char*, int)'
/cygdrive/d/PFC_JZabala/DOL_Iban/Examples_Eclipse/Example1_SystemC/Debug/../src/sc_wrappers/consumer_wrapper.cpp:36: undefined reference to `sc_core::sc_module::~sc_module()'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o: In function `~consumer_wrapper':
/cygdrive/d/PFC_JZabala/DOL_Iban/Examples_Eclipse/Example1_SystemC/Debug/../src/sc_wrappers/consumer_wrapper.cpp:61: undefined reference to `sc_core::sc_module::~sc_module()'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o: In function `__static_initialization_and_destruction_0':
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/kernel/sc_ver.h:66: undefined reference to `sc_core::sc_api_version_2_2_0::sc_api_version_2_2_0()'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o: In function `_ZN7sc_core22sc_get_curr_simcontextEv':
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/kernel/sc_simcontext.h:379: undefined reference to `sc_core::sc_curr_simcontext'
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/kernel/sc_simcontext.h:380: undefined reference to `sc_core::sc_simcontext::sc_simcontext()'
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/kernel/sc_simcontext.h:380: undefined reference to `sc_core::sc_default_global_context'
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/kernel/sc_simcontext.h:381: undefined reference to `sc_core::sc_default_global_context'
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/kernel/sc_simcontext.h:381: undefined reference to `sc_core::sc_curr_simcontext'
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/kernel/sc_simcontext.h:383: undefined reference to `sc_core::sc_curr_simcontext'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o: In function `_ZNK5sc_dt8sc_logic7to_charEv':
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/datatypes/bit/sc_logic.h:537: undefined reference to `sc_dt::sc_logic::logic_to_char'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o: In function `~sc_event':
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/kernel/sc_event.h:227: undefined reference to `sc_core::sc_event::cancel()'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o: In function `_ZN7sc_core8sc_event17notify_next_deltaEv':
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/kernel/sc_event.h:260: undefined reference to `sc_core::SC_ID_NOTIFY_DELAYED_'
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/kernel/sc_event.h:260: undefined reference to `sc_core::sc_report_handler::report(sc_core::sc_severity, char const*, char const*, char const*, int)'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o: In function `~sc_signal_in_if':
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/communication/sc_signal_ifs.h:186: undefined reference to `sc_core::sc_interface::~sc_interface()'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o: In function `~sc_signal_write_if':
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/communication/sc_signal_ifs.h:239: undefined reference to `sc_core::sc_interface::~sc_interface()'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o: In function `~sc_signal_inout_if':
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/communication/sc_signal_ifs.h:260: undefined reference to `sc_core::sc_interface::~sc_interface()'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/communication/sc_signal_ifs.h:260: more undefined references to `sc_core::sc_interface::~sc_interface()' follow
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o: In function `~sc_signal':
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/communication/sc_signal.h:540: undefined reference to `sc_core::sc_prim_channel::~sc_prim_channel()'
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/communication/sc_signal.h:540: undefined reference to `sc_core::sc_interface::~sc_interface()'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o: In function `_ZNK7sc_core9sc_signalIN5sc_dt8sc_logicEE12get_data_refEv':
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/communication/sc_signal.h:590: undefined reference to `sc_core::sc_deprecated_get_data_ref()'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o: In function `_ZNK7sc_core9sc_signalIN5sc_dt8sc_logicEE7posedgeEv':
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/communication/sc_signal.h:599: undefined reference to `sc_dt::SC_LOGIC_1'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o: In function `_ZNK7sc_core9sc_signalIN5sc_dt8sc_logicEE7negedgeEv':
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/communication/sc_signal.h:603: undefined reference to `sc_dt::SC_LOGIC_0'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o: In function `_ZNK7sc_core9sc_signalIN5sc_dt8sc_logicEE5traceEPNS_13sc_trace_fileE':
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/communication/sc_signal.h:629: undefined reference to `sc_core::sc_deprecated_trace()'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o: In function `_ZN7sc_core9sc_signalIN5sc_dt8sc_logicEE13register_portERNS_12sc_port_baseEPKc':
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/communication/sc_signal.h:676: undefined reference to `sc_core::sc_signal_invalid_writer(sc_core::sc_object*, sc_core::sc_object*, sc_core::sc_object*)'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o: In function `_ZN7sc_core9sc_signalIN5sc_dt8sc_logicEE5writeERKS2_':
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/communication/sc_signal.h:694: undefined reference to `sc_core::sc_signal_invalid_writer(sc_core::sc_object*, sc_core::sc_object*, sc_core::sc_object*)'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o: In function `_ZN7sc_core9sc_signalIN5sc_dt8sc_logicEE6updateEv':
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/communication/sc_signal.h:728: undefined reference to `sc_dt::SC_LOGIC_1'
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/communication/sc_signal.h:730: undefined reference to `sc_dt::SC_LOGIC_0'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o: In function `_ZN7sc_core9sc_port_bI7read_ifEptEv':
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/communication/sc_port.h:489: undefined reference to `sc_core::SC_ID_GET_IF_'
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/communication/sc_port.h:489: undefined reference to `sc_core::sc_port_base::report_error(char const*, char const*) const'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o: In function `sc_port_b':
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/communication/sc_port.h:357: undefined reference to `sc_core::sc_port_base::sc_port_base(int, sc_core::sc_port_policy)'
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/communication/sc_port.h:357: undefined reference to `sc_core::sc_port_base::~sc_port_base()'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o: In function `~sc_port_b':
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/communication/sc_port.h:369: undefined reference to `sc_core::sc_port_base::~sc_port_base()'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTV16consumer_wrapper[vtable for consumer_wrapper]+0xc): undefined reference to `sc_core::sc_object::print(std::basic_ostream<char, std::char_traits<char> >&) const'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTV16consumer_wrapper[vtable for consumer_wrapper]+0x10): undefined reference to `sc_core::sc_object::dump(std::basic_ostream<char, std::char_traits<char> >&) const'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTV16consumer_wrapper[vtable for consumer_wrapper]+0x14): undefined reference to `sc_core::sc_object::trace(sc_core::sc_trace_file*) const'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTV16consumer_wrapper[vtable for consumer_wrapper]+0x1c): undefined reference to `sc_core::sc_module::get_child_objects() const'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTV16consumer_wrapper[vtable for consumer_wrapper]+0x28): undefined reference to `sc_core::sc_module::before_end_of_elaboration()'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTV16consumer_wrapper[vtable for consumer_wrapper]+0x2c): undefined reference to `sc_core::sc_module::end_of_elaboration()'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTV16consumer_wrapper[vtable for consumer_wrapper]+0x30): undefined reference to `sc_core::sc_module::start_of_simulation()'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTV16consumer_wrapper[vtable for consumer_wrapper]+0x34): undefined reference to `sc_core::sc_module::end_of_simulation()'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTVN7sc_core7sc_portI7read_ifLi1ELNS_14sc_port_policyE0EEE[vtable for sc_core::sc_port<read_if, 1, (sc_core::sc_port_policy)0>]+0x8): undefined reference to `sc_core::sc_object::print(std::basic_ostream<char, std::char_traits<char> >&) const'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTVN7sc_core7sc_portI7read_ifLi1ELNS_14sc_port_policyE0EEE[vtable for sc_core::sc_port<read_if, 1, (sc_core::sc_port_policy)0>]+0xc): undefined reference to `sc_core::sc_object::dump(std::basic_ostream<char, std::char_traits<char> >&) const'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTVN7sc_core7sc_portI7read_ifLi1ELNS_14sc_port_policyE0EEE[vtable for sc_core::sc_port<read_if, 1, (sc_core::sc_port_policy)0>]+0x10): undefined reference to `sc_core::sc_object::trace(sc_core::sc_trace_file*) const'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTVN7sc_core7sc_portI7read_ifLi1ELNS_14sc_port_policyE0EEE[vtable for sc_core::sc_port<read_if, 1, (sc_core::sc_port_policy)0>]+0x40): undefined reference to `sc_core::sc_port_base::before_end_of_elaboration()'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTVN7sc_core7sc_portI7read_ifLi1ELNS_14sc_port_policyE0EEE[vtable for sc_core::sc_port<read_if, 1, (sc_core::sc_port_policy)0>]+0x44): undefined reference to `sc_core::sc_port_base::end_of_elaboration()'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTVN7sc_core7sc_portI7read_ifLi1ELNS_14sc_port_policyE0EEE[vtable for sc_core::sc_port<read_if, 1, (sc_core::sc_port_policy)0>]+0x48): undefined reference to `sc_core::sc_port_base::start_of_simulation()'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTVN7sc_core7sc_portI7read_ifLi1ELNS_14sc_port_policyE0EEE[vtable for sc_core::sc_port<read_if, 1, (sc_core::sc_port_policy)0>]+0x4c): undefined reference to `sc_core::sc_port_base::end_of_simulation()'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTVN7sc_core9sc_port_bI7read_ifEE[vtable for sc_core::sc_port_b<read_if>]+0x8): undefined reference to `sc_core::sc_object::print(std::basic_ostream<char, std::char_traits<char> >&) const'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTVN7sc_core9sc_port_bI7read_ifEE[vtable for sc_core::sc_port_b<read_if>]+0xc): undefined reference to `sc_core::sc_object::dump(std::basic_ostream<char, std::char_traits<char> >&) const'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTVN7sc_core9sc_port_bI7read_ifEE[vtable for sc_core::sc_port_b<read_if>]+0x10): undefined reference to `sc_core::sc_object::trace(sc_core::sc_trace_file*) const'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTVN7sc_core9sc_port_bI7read_ifEE[vtable for sc_core::sc_port_b<read_if>]+0x40): undefined reference to `sc_core::sc_port_base::before_end_of_elaboration()'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTVN7sc_core9sc_port_bI7read_ifEE[vtable for sc_core::sc_port_b<read_if>]+0x44): undefined reference to `sc_core::sc_port_base::end_of_elaboration()'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTVN7sc_core9sc_port_bI7read_ifEE[vtable for sc_core::sc_port_b<read_if>]+0x48): undefined reference to `sc_core::sc_port_base::start_of_simulation()'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTVN7sc_core9sc_port_bI7read_ifEE[vtable for sc_core::sc_port_b<read_if>]+0x4c): undefined reference to `sc_core::sc_port_base::end_of_simulation()'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTVN7sc_core9sc_signalIN5sc_dt8sc_logicEEE[vtable for sc_core::sc_signal<sc_dt::sc_logic>]+0xb4): undefined reference to `sc_core::sc_prim_channel::before_end_of_elaboration()'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTVN7sc_core9sc_signalIN5sc_dt8sc_logicEEE[vtable for sc_core::sc_signal<sc_dt::sc_logic>]+0xb8): undefined reference to `sc_core::sc_prim_channel::end_of_elaboration()'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTVN7sc_core9sc_signalIN5sc_dt8sc_logicEEE[vtable for sc_core::sc_signal<sc_dt::sc_logic>]+0xbc): undefined reference to `sc_core::sc_prim_channel::start_of_simulation()'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTVN7sc_core9sc_signalIN5sc_dt8sc_logicEEE[vtable for sc_core::sc_signal<sc_dt::sc_logic>]+0xc0): undefined reference to `sc_core::sc_prim_channel::end_of_simulation()'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTCN7sc_core9sc_signalIN5sc_dt8sc_logicEEE0_NS_18sc_signal_inout_ifIS2_EE[construction vtable for sc_core::sc_signal_inout_if<sc_dt::sc_logic>-in-sc_core::sc_signal<sc_dt::sc_logic>]+0x18): undefined reference to `sc_core::sc_interface::register_port(sc_core::sc_port_base&, char const*)'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTCN7sc_core9sc_signalIN5sc_dt8sc_logicEEE0_NS_18sc_signal_inout_ifIS2_EE[construction vtable for sc_core::sc_signal_inout_if<sc_dt::sc_logic>-in-sc_core::sc_signal<sc_dt::sc_logic>]+0x1c): undefined reference to `sc_core::sc_interface::default_event() const'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTCN7sc_core9sc_signalIN5sc_dt8sc_logicEEE0_NS_15sc_signal_in_ifIS2_EE[construction vtable for sc_core::sc_signal_in_if<sc_dt::sc_logic>-in-sc_core::sc_signal<sc_dt::sc_logic>]+0x18): undefined reference to `sc_core::sc_interface::register_port(sc_core::sc_port_base&, char const*)'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTCN7sc_core9sc_signalIN5sc_dt8sc_logicEEE0_NS_15sc_signal_in_ifIS2_EE[construction vtable for sc_core::sc_signal_in_if<sc_dt::sc_logic>-in-sc_core::sc_signal<sc_dt::sc_logic>]+0x1c): undefined reference to `sc_core::sc_interface::default_event() const'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTCN7sc_core9sc_signalIN5sc_dt8sc_logicEEE4_NS_18sc_signal_write_ifIS2_EE[construction vtable for sc_core::sc_signal_write_if<sc_dt::sc_logic>-in-sc_core::sc_signal<sc_dt::sc_logic>]+0x40): undefined reference to `sc_core::sc_interface::register_port(sc_core::sc_port_base&, char const*)'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTCN7sc_core9sc_signalIN5sc_dt8sc_logicEEE4_NS_18sc_signal_write_ifIS2_EE[construction vtable for sc_core::sc_signal_write_if<sc_dt::sc_logic>-in-sc_core::sc_signal<sc_dt::sc_logic>]+0x44): undefined reference to `sc_core::sc_interface::default_event() const'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTVN7sc_core18sc_signal_inout_ifIN5sc_dt8sc_logicEEE[vtable for sc_core::sc_signal_inout_if<sc_dt::sc_logic>]+0x18): undefined reference to `sc_core::sc_interface::register_port(sc_core::sc_port_base&, char const*)'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTVN7sc_core18sc_signal_inout_ifIN5sc_dt8sc_logicEEE[vtable for sc_core::sc_signal_inout_if<sc_dt::sc_logic>]+0x1c): undefined reference to `sc_core::sc_interface::default_event() const'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTCN7sc_core18sc_signal_inout_ifIN5sc_dt8sc_logicEEE0_NS_15sc_signal_in_ifIS2_EE[construction vtable for sc_core::sc_signal_in_if<sc_dt::sc_logic>-in-sc_core::sc_signal_inout_if<sc_dt::sc_logic>]+0x18): undefined reference to `sc_core::sc_interface::register_port(sc_core::sc_port_base&, char const*)'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTCN7sc_core18sc_signal_inout_ifIN5sc_dt8sc_logicEEE0_NS_15sc_signal_in_ifIS2_EE[construction vtable for sc_core::sc_signal_in_if<sc_dt::sc_logic>-in-sc_core::sc_signal_inout_if<sc_dt::sc_logic>]+0x1c): undefined reference to `sc_core::sc_interface::default_event() const'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTCN7sc_core18sc_signal_inout_ifIN5sc_dt8sc_logicEEE4_NS_18sc_signal_write_ifIS2_EE[construction vtable for sc_core::sc_signal_write_if<sc_dt::sc_logic>-in-sc_core::sc_signal_inout_if<sc_dt::sc_logic>]+0x40): undefined reference to `sc_core::sc_interface::register_port(sc_core::sc_port_base&, char const*)'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTCN7sc_core18sc_signal_inout_ifIN5sc_dt8sc_logicEEE4_NS_18sc_signal_write_ifIS2_EE[construction vtable for sc_core::sc_signal_write_if<sc_dt::sc_logic>-in-sc_core::sc_signal_inout_if<sc_dt::sc_logic>]+0x44): undefined reference to `sc_core::sc_interface::default_event() const'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTVN7sc_core18sc_signal_write_ifIN5sc_dt8sc_logicEEE[vtable for sc_core::sc_signal_write_if<sc_dt::sc_logic>]+0x18): undefined reference to `sc_core::sc_interface::register_port(sc_core::sc_port_base&, char const*)'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTVN7sc_core18sc_signal_write_ifIN5sc_dt8sc_logicEEE[vtable for sc_core::sc_signal_write_if<sc_dt::sc_logic>]+0x1c): undefined reference to `sc_core::sc_interface::default_event() const'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTVN7sc_core15sc_signal_in_ifIN5sc_dt8sc_logicEEE[vtable for sc_core::sc_signal_in_if<sc_dt::sc_logic>]+0x18): undefined reference to `sc_core::sc_interface::register_port(sc_core::sc_port_base&, char const*)'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o:consumer_wrapper.cpp:(.rdata$_ZTVN7sc_core15sc_signal_in_ifIN5sc_dt8sc_logicEEE[vtable for sc_core::sc_signal_in_if<sc_dt::sc_logic>]+0x1c): undefined reference to `sc_core::sc_interface::default_event() const'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o: In function `_ZN7sc_core9sc_port_bI7read_ifE5vbindERNS_12sc_interfaceE':
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/communication/sc_port.h:553: undefined reference to `sc_core::sc_port_base::bind(sc_core::sc_interface&)'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o: In function `_ZN7sc_core9sc_port_bI7read_ifE5vbindERNS_12sc_port_baseE':
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/communication/sc_port.h:567: undefined reference to `sc_core::sc_port_base::bind(sc_core::sc_port_base&)'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o: In function `_ZN7sc_core9sc_port_bI7read_ifE13add_interfaceEPNS_12sc_interfaceE':
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/communication/sc_port.h:589: undefined reference to `sc_core::SC_ID_BIND_IF_TO_PORT_'
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/communication/sc_port.h:589: undefined reference to `sc_core::sc_port_base::report_error(char const*, char const*) const'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o: In function `_ZNK7sc_core9sc_port_bI7read_ifE14make_sensitiveEPNS_17sc_thread_processEPNS_15sc_event_finderE':
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/communication/sc_port.h:628: undefined reference to `sc_core::sc_port_base::add_static_event(sc_core::sc_thread_process*, sc_core::sc_event const&) const'
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/communication/sc_port.h:633: undefined reference to `sc_core::sc_port_base::make_sensitive(sc_core::sc_thread_process*, sc_core::sc_event_finder*) const'
/cygdrive/c/Users/IAYEST~1/AppData/Local/Temp/ccvG69Af.o: In function `_ZNK7sc_core9sc_port_bI7read_ifE14make_sensitiveEPNS_17sc_method_processEPNS_15sc_event_finderE':
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/communication/sc_port.h:649: undefined reference to `sc_core::sc_port_base::add_static_event(sc_core::sc_method_process*, sc_core::sc_event const&) const'
D:\SystemC\systemc-2.2.0_cygwin_NEVER_USED\include/sysc/communication/sc_port.h:654: undefined reference to `sc_core::sc_port_base::make_sensitive(sc_core::sc_method_process*, sc_core::sc_event_finder*) const'
/usr/lib/gcc/i686-pc-cygwin/4.5.3/../../../libcygwin.a(libcmain.o):(.text+0xa9): undefined reference to `_WinMain@16'
collect2: ld returned 1 exit status
make: *** [src/sc_wrappers/consumer_wrapper.o] Error 1
**** Build Finished ****
Previous Topic:Trying to be a Committer
Next Topic:How can configure CDT MBS to use different toolchains for different folders?
Current Time: Thu Jan 18 15:52:23 GMT 2018
Powered by FUDForum. Page generated in 0.02067 seconds
