Home » Eclipse Projects » Rich Client Platform (RCP) » Tile Editor horizontal/vertical programmatically(Tile Editor horizontal/vertical programmatically)
Tile Editor horizontal/vertical programmatically [message #871014] Thu, 10 May 2012 14:29 Go to next message
Omer Gillani is currently offline Omer GillaniFriend
Is there any way around to tile editor horizontal/vertical programmatically?
When we open new editor, it opens new tab for it. We can drag to set it vertically/horizontally. I want to arrage my editors horizontally/vertically programmatically.
-Omer Gillani
Re: Tile Editor horizontal/vertical programmatically [message #871026 is a reply to message #871014] Thu, 10 May 2012 14:47 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
In 3.x there's no programmatic access to splitting the editor area.
In 4.2 you could probably do it by manipulating the model, but you'd have to provide all of the correct layout/attributes.
PW
Re: Tile Editor horizontal/vertical programmatically [message #871186 is a reply to message #871026] Fri, 11 May 2012 10:37 Go to previous messageGo to next message
Thanks Paul.
We have 3.x and we are shifting it to 4.2. But model is not available to us so far. There are some important workflows that requires to layout editor area programmatically. Can you please guide me to do it anyway even by extending RCP API?
Re: Tile Editor horizontal/vertical programmatically [message #886594 is a reply to message #871186] Fri, 15 June 2012 08:45 Go to previous message
Alexander Haag is currently offline Alexander HaagFriend
Hi Omar,
i did very much the same thing once in 3.2. Basicly i needed to place a subeditor below my main editor.
I am forcing a DnD-Event to do this (see code below). I copied some sources to do quick patch(see derivedSources.7z). This isn't quite a clean API-way to deal with, but it worked for over 4 years now.
Hope this will help you
Greets Alex
IEditorReference[] editorRefs = GuiHelper.getActivePage().getEditorReferences();
int idx = 0;
// get the editor instance by given id (pEditorId)
for (int i = 0; i < editorRefs.length; i++)
   IEditorReference editRef = editorRefs[i];
   if (editRef.getId().equals(pEditorId) && editRef.getEditor(false).equals(result))
      idx = i;
      break;
// create drag-and drop-source of editor
EditorDragSource editorDragSource = new EditorDragSource(idx, false);
EditorAreaDropTarget dropLocation = new EditorAreaDropTarget(editorDragSource, SWT.BOTTOM);
// force dnd of editor
editorDragSource.drag(dropLocation);
Previous Topic:Different splash screens
Next Topic:JFace TreeViewer Connected with PropertiesView
Current Time: Tue Apr 24 03:11:03 GMT 2018
Powered by FUDForum. Page generated in 0.02163 seconds
