Home » Language IDEs » C / C++ IDE (CDT) » Problems to make the debugger work
Problems to make the debugger work [message #870659] Wed, 09 May 2012 09:14 Go to next message
Michel Dupront is currently offline Michel DuprontFriend
I am trying to use eclipse with ubuntu 12.04 to debug a c++ program.
Things that were working fine with ubuntu 10.04 now give me problems.
From eclipse I built a c++ "Makefile project".
I set it up as I did before.
It runs fine.
But when I want to debug, I get:
My_Exe [C/C++ Application]
  gdb/mi (09/05/12 10:06) (Suspended)
    Thread [1] (Suspended)
      4 <symbol is not available> 0xb7fe0cb2
      3 <symbol is not available> 0xb7ff2977
      2 <symbol is not available> 0xb7fe2eeb
      1 <symbol is not available> 0xb7fdf1d7
    gdb (09/05/12 10:06)
    /My_Path/My_Exec (09/05/12 10:06)
If I click in "step over" anyway, here is the message I get in
the Console window:
.gdbinit: No file or folder of this kind    ("Aucun fichier ou dossier de ce type" in French).
Reading symbols from /My_Path/My_Exec...done.
Single stepping until exit from function _dl_debug_state,
which has no line number information.
I don't know where to start here to fix this problem.
Is the problem due to the gdb compiler ? to eclipse ?
Thanks for any help.
[Updated on: Wed, 09 May 2012 09:24]
Report message to a moderator
Re: Problems to make the debugger work [message #870881 is a reply to message #870659] Thu, 10 May 2012 07:18 Go to previous message
Axel Mueller is currently offline Axel MuellerFriend
Your application has no debug symbols. You must add the option -g to the gcc command line.
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
Previous Topic:How to change the default build configurations when create a new project?
Next Topic:Why is it so difficult to get C++ to work?
Current Time: Wed Jan 17 13:20:56 GMT 2018
Powered by FUDForum. Page generated in 0.02022 seconds
