Home » Language IDEs » C / C++ IDE (CDT) » breakpoint commands list (Trying to execute a set of commands after hitting a breakpoint)
breakpoint commands list [message #859693] Fri, 27 April 2012 19:15 Go to next message
chenna varri is currently offline chenna varriFriend
Hi All,
I am trying to execute a set of commands when a breakpoint is hit. place a set of commands in breakpoint properties in Eclipse, something as described here for GDB
For now I can only place breakpoint conditions but not a list of commands to execute when the condition becomes true
Is anyone aware of the syntax or does Eclipse even have this feature?
Thanks for any help,
-Red [CentOS x64, Eclipse Helios CDT]
Re: breakpoint commands list [message #865647 is a reply to message #859693] Mon, 30 April 2012 14:01 Go to previous message
Marc Khouzam is currently offline Marc KhouzamFriend
CDT does not currently support this in the UI but it shouldn't be very hard. Please refer to:
You can achieve what you want by using the Eclipse gdb console, where you can type your commands as a real gdb command-line
Previous Topic:Cannot access memory at address 0x1 - Error
Next Topic:configure GDB for eclipse to use jlink edu
Current Time: Mon Mar 19 03:26:34 GMT 2018
Powered by FUDForum. Page generated in 0.02227 seconds
