Home » Modeling » EMF » Collecting all objects for treeviewer
| Collecting all objects for treeviewer [message #857416] |
Thu, 26 April 2012 10:12  |
El Shorty Messages: 37 Registered: March 2012 |
Member |
Hey all,
I've got a small question, I have a treeviewer that lists all my groups & persons. I've done this already on 10 different ways but now I found a way that looks decent enough, so I would like to use this. I just got on problem, I don't know how to add a new group to the tree. This is what I do:
TreeViewer treeViewer = new TreeViewer(composite_1, SWT.BORDER);
Tree tree = treeViewer.getTree();
tree.setHeaderVisible(true);
tree.setLinesVisible(true);
[color=orangered]GroupList list = new GroupList();
List<Group> groups = list.getGroups();
GroupCollection allGroups = SmartsignatureFactory.eINSTANCE.createGroupCollection();
allGroups.getContaintsGroups().addAll(groups);[/color]
IObservableList observableList = EMFObservables.observeList(allGroups,
SmartsignaturePackage.Literals.GROUP_COLLECTION__CONTAINTS_GROUPS);
IObservableFactory factory = new IObservableFactory() {
public IObservable createObservable(Object target) {
if (target instanceof Group)
return EMFProperties.list(
SmartsignaturePackage.Literals.GROUP__CONTAINS_PERSONS).observe(target);
} else if (target instanceof IObservable) {
return (IObservable) target;
return null;
// Advisor
TreeStructureAdvisor advisor = new TreeStructureAdvisor() {
public Boolean hasChildren(Object element) {
if (element instanceof Group) {
return ((Group) element).getContainsPersons().size() != 0;
return super.hasChildren(element);
ObservableListTreeContentProvider contentProvider = new ObservableListTreeContentProvider(
factory, advisor);
IObservableMap[] maps = new IObservableMap[3];
maps[0] = EMFProperties.value(
SmartsignaturePackage.Literals.GROUP__NAME).observeDetail(
contentProvider.getKnownElements());
maps[1] = EMFProperties.value(
FeaturePath.fromList(
SmartsignaturePackage.Literals.PERSON__FIRST_NAME))
.observeDetail(contentProvider.getKnownElements());
maps[2] = EMFProperties.value(
SmartsignaturePackage.Literals.PERSON__LAST_NAME))
ObservableMapLabelProvider labelProvider = new ObservableMapLabelProvider(
maps) {
public String getColumnText(Object element, int columnIndex) {
Group group = (Group) element;
return group.getName();
if (element instanceof Person) {
Person person = (Person) element;
return person.getFirstName() + " " + person.getLastName();
return super.getColumnText(element, columnIndex);
public Image getImage(Object element) {
return ResourceManager.getPluginImage("smartapps.smartsignature.ui.admin", "icons/user-group-icon.png");
return ResourceManager.getPluginImage("smartapps.smartsignature.ui.admin", "icons/user-icon.png");
treeViewer.setContentProvider(contentProvider);
treeViewer.setLabelProvider(labelProvider);
treeViewer.setInput(observableList);
what I want is that instead of creating a list of all the group objects and placing them in a collection object, I'ld like that it does that on it's own.
One option I was thinking about was making it so that whenever a group is added, it also get's added to the groupCollection object, I can do that manually but that just sounds wrong.
Hope you can see what I mean,
any help is much appreciated
[Updated on: Thu, 26 April 2012 10:14] Report message to a moderator
| Re: Collecting all objects for treeviewer [message #865285 is a reply to message #865275] |
Mon, 30 April 2012 06:20   |
Ed Merks Messages: 24550 Registered: July 2009 |
Comments below.
On 30/04/2012 12:14 PM, El Shorty wrote:
> Ok, since I got no answer I'll try again.
> What I want is that whenever a group gets added or deleted, my
> treeviewer that shows the groups and the content from the groups to
> update itself. I'm trying to listen to the resource that contains all
> the groups by using an adapter but I must be something wrong because
> the adapter never gets triggered. Here is the code from the tree I
> have so far:
> SmartsignaturePackage.Literals.GROUP_COLLECTION__CONTAINS_GROUPS);
> @Override
> return null;
> // Advisor
> @Override
> return ((Group)
> factory, advisor);
> maps) {
> columnIndex) {
> And I try to add an EContentAdapter to my resource like this:
> ResourceSet resourceSet = new ResourceSetImpl();
> URI fileURI =
> URI.createFileURI(SmartSignResourceUtil.getPath(DataPart.Groups));
> Resource loadResource = resourceSet.getResource(fileURI, true);
> EContentAdapter adapter = new EContentAdapter() {
> public void notifyChanged(Notification notification) {
Did you look at what this method does in the base class?
> treeViewer.refresh();
> loadResource.eAdapters().add(adapter);
> But the adapter never gets triggered. The idea of this was that
> whenever the resource changed, the adapter would get triggered and the
> tree would refresh itself.
I would have expected that data binding would take care of the refresh
via the observables.
> I hope this makes more sense that my first post. Any idea's anyone?
| Re: Collecting all objects for treeviewer [message #865340 is a reply to message #865285] |
Mon, 30 April 2012 06:54   |
Member |
It takes care of the refresh using the observables, whenever I adjust an existing group, the adjustment is added but when I add or delete a group nothing changes.
I know it is because it obsevers allGroups, problem here is that allGroups is a collection of the already existing groups, but I don't know how to add the new groups to it, that is why I wanted the adapter so that I could add new groups whenever the adapter was triggered.
Perhaps it is possible that instead of using groupList, I could use the resource that contains all the groups.
That would be:
URI fileURI = URI.createFileURI(SmartSignResourceUtil.getPath(DataPart.Groups));
I believe that if I could use loadResource instead of allGroups, my problem would be solved but I have no idea how I could do this, that's why I was trying to check if loadResource changed, because if it did than I could manually add my groups by using the adapter.
I'm hoping I make sense
| Re: Collecting all objects for treeviewer [message #865378 is a reply to message #865340] |
Mon, 30 April 2012 07:18   |
I think you'd typically use EMFProperties or EMFEditProperties and use
the resource method to observe the contents of a resource.
> the resource that contains all the groups. That would be:
> URI fileURI =
| Re: Collecting all objects for treeviewer [message #865632 is a reply to message #865556] |
Mon, 30 April 2012 09:51   |
Member |
I'll post the full code I'm using for the treeviewer, just in case anyone sees what I'm overlooking...
public class GroupView extends ViewPart implements ISelectionListener {
private TreeViewer treeViewer;
public GroupView() {
super();
public void createPartControl(Composite parent) {
Composite composite = new Composite(parent, SWT.NONE);
composite.setLayout(new GridLayout(1, false));
Composite composite_1 = new Composite(composite, SWT.NONE);
composite_1.setLayoutData(new GridData(SWT.FILL, SWT.FILL, true, true, 1, 1));
composite_1.setLayout(new TreeColumnLayout());
IObservableList observableList = EMFProperties.resource().observe(loadResource);
return null;
// Advisor
factory, advisor);
maps) {
return ResourceManager.getPluginImage("smartapps.smartsignature.ui.groupoverview", "icons/user-group-icon.png");
return ResourceManager.getPluginImage("smartapps.smartsignature.ui.groupoverview", "icons/user-icon.png");
public void setFocus() {
// TODO Auto-generated method stub
public void selectionChanged(IWorkbenchPart part, ISelection selection) {
| Re: Collecting all objects for treeviewer [message #868533 is a reply to message #865632] |
Wed, 02 May 2012 02:57   |
Thomas Schindl Messages: 4462 Registered: July 2009 |
So where is the code that adds/removes a group? You should try to come
up with code we can locally to reproduce your problem.
We are using EMF-Databinding in many of our projects and if this would
be broken our software would be too. So there's some special about your
code which I can't see without running it.
Tom
Am 30.04.12 15:52, schrieb El Shorty:
> super();
> @Override
> true, 1, 1));
> URI fileURI =
> @Override
> return null;
> // Advisor
> @Override
> != 0;
> factory, advisor);
> maps) {
> columnIndex) {
> return
> return
> @Override
> @Override
> selection) {
| Re: Collecting all objects for treeviewer [message #868592 is a reply to message #868579] |
Wed, 02 May 2012 05:10   |
Member |
Yeah that's what I tought, so now I've made a parent object called GroupCollection, this should contain all the existing groups, whenever I create a new group I add it to the groupCollection object but again nothing changes. I'm guessing I need to adjust my code some more but don't know where anymore, here is what I have now:
URI fileURI = URI.createFileURI(SmartSignResourceUtil.getPath(DataPart.GroupCollections));
if (target instanceof GroupCollection)
SmartsignaturePackage.Literals.GROUP_COLLECTION__CONTAINS_GROUPS).observe(target);
else if (target instanceof Group)
return null;
// Advisor
if (element instanceof GroupCollection) {
return ((GroupCollection) element).getContainsGroups().size() != 0;
else if (element instanceof Group) {
factory, advisor);
IObservableMap[] maps = new IObservableMap[4];
SmartsignaturePackage.Literals.GROUP_COLLECTION__NAME).observeDetail(
SmartsignaturePackage.Literals.GROUP__NAME)).observeDetail(
maps[3] = EMFProperties.value(
maps) {
That's to build my tree. If I'm correct it should be observing my groupCollection, but apparantly I'm wrong because when I add a new group in my wizard like this:
SaveMethod save = new SaveMethod();
save.save(group);
openEditor();
addToGroupCollection();
try {
groupCollection.eResource().save(null);
} catch (IOException e) {
// TODO Auto-generated catch block
e.printStackTrace();
return true;
public void addToGroupCollection() {
List<EObject> collection = loadResource.getContents();
groupCollection = (GroupCollection) collection.toArray()[0];
groupCollection.getContainsGroups().add(group);
I'm sorry for all the questions, I'm really trying to understand this but I keep doing something wrong.. I've only been using EMF & RCP for 2 months, and there is alot to learn & understand. I love it but it's a challenge lolz..
| Re: Collecting all objects for treeviewer [message #868631 is a reply to message #868592] |
Wed, 02 May 2012 06:11   |
EMF-Databinding is listening to the in memory model - your code creates
a new resource instance and saves it to the file system. Why are you not
simply attaching the new object to the existing resource instead of
creating a new one all the time?
Did you take a look at the EMF-Databinding example it our source repo it
shows you have to add/remove objects. BTW your new code with the new
root-element requires you to change the observable creation to observe
the list-feature of GroupCollection.
Tom
Am 02.05.12 11:10, schrieb El Shorty:
> true, 1, 1));
> URI fileURI =
> @Override
> return null;
> // Advisor
> @Override
> != 0;
> factory, advisor);
> maps) {
> columnIndex) {
> return
> return
> save.save(group);
> openEditor();
> try {
> return true;
> URI fileURI =
> challenge lolz..
| Re: Collecting all objects for treeviewer [message #868649 is a reply to message #868631] |
Wed, 02 May 2012 06:46   |
Member |
Tom Schindl wrote on Wed, 02 May 2012 06:11EMF-Databinding is listening to the in memory model - your code creates
Tom
Where do I find the EMF-Databinding example? Defenatly want to see that, I used an example I found on internet to try and figure out how this works.
And about my current code, I'm not sure if I know what you mean because I tought I was doing that already here:
I just found your example here: http://tomsondev.bestsolution.at/2009/06/06/galileo-emf-databinding-part-1/
Thing is I see you use the editingdomain, wich I'm not allowed to use yet, they want me to work around it. I'm not sure if that is what you meant but I need to find another way
[Updated on: Wed, 02 May 2012 07:04] Report message to a moderator
| Re: Collecting all objects for treeviewer [message #869750 is a reply to message #868631] |
Fri, 04 May 2012 04:03  |
Member |
Hey,
I only saw this now, how can I attach the new object to my existing resource? I mean I created my resource in my view and I create my object in my group, how can I add one to another?
Current Time: Wed May 22 21:15:09 EDT 2013
Powered by FUDForum. Page generated in 0.02544 seconds
