Home » Eclipse Projects » Remote Application Platform (RAP) » RAP 1.4.2 TextCellEditor trouble on Firefox 12
RAP 1.4.2 TextCellEditor trouble on Firefox 12 [message #857365] Thu, 26 April 2012 13:27 Go to next message
Oliver Probst is currently offline Oliver ProbstFriend
I've experienced some troubles with the RAP 1.4.2 TextCellEditors on
Firefox 12:
When selecting the cell, it is not possible to insert text any more. The
org.eclipse.jface.viewers.TextCellEditor#text.keyListener
is called, but
org.eclipse.swt.widgets.Text#setText(String)
will never be reached.
Adding content by copy/paste is possible.
On Firefox 11, this problem didn't occur.
Is this a Firefox bug? A problem of RAP? Some implementation detail I
missed?
Regards, Oliver
Re: RAP 1.4.2 TextCellEditor trouble on Firefox 12 [message #857482 is a reply to message #857365] Thu, 26 April 2012 15:16 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan FurnadjievFriend
Hi Oliver,
just did a quick check (Controls Demo) with RAP from CVS HEAD (1.5M6)
and TextCellEditor is working as expected in Firefox 12. Unfortunately,
I can reproduce the problem with 1.4.2 and Firefox 12. When a key
listener is attached on the server-side, in RAP 1.4.2 we cancel the DOM
event and afterwards generate it programmatically again if doit flag is
set to true (see AsyncKeyEventUtil.js). Probably, this programmatically
generated key event on the client does not work anymore in Firefox 12.
As we drop the support for key event doit flag in RAP 1.5:
367871: Remove support for doit=false for KeyEvents
https://bugs.eclipse.org/bugs/show_bug.cgi?id=367871
it is working there without a problem.
These are my thoughts without doing a deep investigation.
Best,
Ivan
On 4/26/2012 4:27 PM, Oliver Probst wrote:
> Firefox 12:
> is called, but
> missed?
> Regards, Oliver
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: RAP 1.4.2 TextCellEditor trouble on Firefox 12 [message #857521 is a reply to message #857482] Thu, 26 April 2012 16:04 Go to previous messageGo to next message
Maybe this is the answer of the question:
https://developer.mozilla.org/en/Using_the_Editor_from_XUL#Editor_event_handling
"Starting in Gecko 12.0 (Firefox 12.0 / Thunderbird 12.0) , the editor
refuses any events sent by unprivileged content."
On 4/26/2012 6:16 PM, Ivan Furnadjiev wrote:
> Hi Oliver,
> Unfortunately, I can reproduce the problem with 1.4.2 and Firefox 12.
> When a key listener is attached on the server-side, in RAP 1.4.2 we
> cancel the DOM event and afterwards generate it programmatically again
> if doit flag is set to true (see AsyncKeyEventUtil.js). Probably, this
> programmatically generated key event on the client does not work
> anymore in Firefox 12. As we drop the support for key event doit flag
> in RAP 1.5:
> Best,
> Ivan
>> Firefox 12:
>> is called, but
>> missed?
>> Regards, Oliver
Ivan Furnadjiev
Re: RAP 1.4.2 TextCellEditor trouble on Firefox 12 [message #868536 is a reply to message #857521] Wed, 02 May 2012 07:11 Go to previous messageGo to next message
Sabine Neubauer is currently offline Sabine NeubauerFriend
we have the same problem in our application which is based on RAP 1.4.1. It is impossible to type text if a cell editor is used. The same problem exists for text fields with autocompletion (ContentProposalAdapter). Pasting text from the clipboard works fine in both cases.
Is there any solution for RAP 1.4 or do we need to use RAP 1.5 in order to solve the problem?
Kind regards
Sabine
Re: RAP 1.4.2 TextCellEditor trouble on Firefox 12 [message #868540 is a reply to message #868536] Wed, 02 May 2012 07:18 Go to previous messageGo to next message
Hi Sabine,
unfortunately there is no a workaround. As it is working in RAP 1.5 and
there is no more service releases planned for the 1.4 branch I doubt
that we will fix it (if possible at all) there.
Best,
Ivan
On 5/2/2012 10:11 AM, Sabine Neubauer wrote:
> in both cases.
> Kind regards
> Sabine
Ivan Furnadjiev
Re: RAP 1.4.2 TextCellEditor trouble on Firefox 12 [message #868605 is a reply to message #868536] Wed, 02 May 2012 09:29 Go to previous message
BTW... here is a bug where the discussion continue:
378209: Unable to type in a text field if key listener is attached -
Firefox 12 + RAP 1.4 only
https://bugs.eclipse.org/bugs/show_bug.cgi?id=378209
> in both cases.
> Kind regards
> Sabine
Ivan Furnadjiev
Previous Topic:Tomcat as embedded server in osgi
Next Topic:ToolItem Markup support
Current Time: Tue Apr 24 18:34:11 GMT 2018
Powered by FUDForum. Page generated in 0.02013 seconds
