Home » Modeling » EMF » DAWN and Synchronous Modeling
DAWN and Synchronous Modeling [message #852078] Sat, 21 April 2012 16:52 Go to next message
Siva Raj is currently offline Siva RajFriend
Hi all,
Is DAWN capable of providing Synchronous Communication? I mean, every edit on the models, need to be synchronized with all the editors which share the same model.
Re: DAWN and Synchronous Modeling [message #852126 is a reply to message #852078] Sat, 21 April 2012 17:58 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Am 21.04.2012 18:52, schrieb Siva Raj:
> Hi all,
You can try to play with something like this:
transaction.options().setStaleReferencePolicy(CDOStaleReferencePolicy.PROXY);
transaction.options().setInvalidationPolicy(CDOInvalidationPolicy.RELAXED);
transaction.options().addChangeSubscriptionPolicy(CDOAdapterPolicy.ALL);
transaction.addTransactionHandler(new CDOPostEventTransactionHandler.Default() {
protected void modifiedObject(CDOTransaction tx, CDOObject object, Notification msg) {
try {
transaction.commit();
} catch (Exception e) {
System.out.println("Commit problem. Conflicts: " + transaction.getConflicts()); //$NON-NLS-1$
transaction.rollback();
Martin may have more ideas...
Cheers
/Eike
http://www.esc-net.de
Re: DAWN and Synchronous Modeling [message #852158 is a reply to message #852126] Sat, 21 April 2012 18:38 Go to previous messageGo to next message
Martin Fluegge is currently offline Martin FlueggeFriend
I would do it as Eike supposed, but do not forget to call
IDawnEditingSupport.refresh()
to update the UI.
As this has been asked before, could you file a bugzilla? We could add
switch to the generator to generate a synchronous version.
Martin
Am 21.04.2012 19:58, schrieb Eike Stepper:
>> Hi all,
> @Override
> try {
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Re: DAWN and Synchronous Modeling [message #852664 is a reply to message #852126] Sun, 22 April 2012 07:08 Go to previous messageGo to next message
Dear Eike,
Where should I include this piece of code? Should I have the source?
[Updated on: Sun, 22 April 2012 11:23]
Report message to a moderator
Re: DAWN and Synchronous Modeling [message #853557 is a reply to message #852664] Mon, 23 April 2012 05:55 Go to previous messageGo to next message
insert it at the end of the setInput() method of your editor.
Martin
Re: DAWN and Synchronous Modeling [message #854144 is a reply to message #853557] Mon, 23 April 2012 17:55 Go to previous messageGo to next message
I just followed this link to get started with dawn.
://wiki.eclipse.org/Getting_Started_with_Dawn
I do not have any source in my workspace. But Dawn is working fine now. Where should I insert this piece of code.
[Updated on: Mon, 23 April 2012 17:57]
Re: DAWN and Synchronous Modeling [message #856340 is a reply to message #854144] Wed, 25 April 2012 15:21 Go to previous messageGo to next message
I do not see any link in your post.
Use this tutorial to install the sources:
http://wiki.eclipse.org/CDO_Source_Installation
If you have your own generated editor simply use it's setInput() method.
Otherwise you can play with the example, e.g. the Acore example.
Martin
Am 23.04.2012 19:55, schrieb Siva Raj:
> I just followed this link to get started with dawn. I do not have any
> source in my workspace. Where should I insert this piece of code.
Re: DAWN and Synchronous Modeling [message #862990 is a reply to message #856340] Sun, 29 April 2012 07:53 Go to previous messageGo to next message
UmaShankar Subramani is currently offline UmaShankar SubramaniFriend
Are you looking for something similar to this?
http://www.mftech.org/dawn/screencasts/9_locking/locking.htm
Re: DAWN and Synchronous Modeling [message #870117 is a reply to message #862990] Sun, 06 May 2012 17:15 Go to previous messageGo to next message
[Updated on: Sun, 06 May 2012 19:02]
Re: DAWN and Synchronous Modeling [message #870133 is a reply to message #870117] Sun, 06 May 2012 21:30 Go to previous messageGo to next message
I am done with all the steps for Importing the CDO Source. Now there are some problems in some of the workspace projects.
They are:
1. Most of the dawngenmodel projects
2. cdo.tests projects
3. org.gastro projects
Also, when I try to run the CDO Server I get the following error:
[ERROR] Unknown DB adapter: h2
java.lang.IllegalArgumentException: Unknown DB adapter: h2
What configuration should I run first?
Re: DAWN and Synchronous Modeling [message #870464 is a reply to message #870133] Tue, 08 May 2012 10:52 Go to previous messageGo to next message
Am 06.05.2012 23:30, schrieb Siva Raj:
> projects.
What exactly are these "some problems"?
> They are:
You mean the shipped launch config "CDO Server"? Does this launch config validate okay? Are the h2-related plugins
properly deployed?
In order to do what? Maybe Martin (cc'ed) knows what you're trying to achieve...
Cheers
/Eike
Re: DAWN and Synchronous Modeling [message #870482 is a reply to message #870133] Tue, 08 May 2012 11:50 Go to previous messageGo to next message
First you need to started the server configuration and then create a new
Eclipse instance for the clients as described here:
http://wiki.eclipse.org/Getting_Started_with_Dawn
But let us first solve your errors. I suggest that you already tried a
"workspace clean"?
Martin
Re: DAWN and Synchronous Modeling [message #872256 is a reply to message #870482] Tue, 15 May 2012 19:25 Go to previous messageGo to next message
Hi Martin,
"Eclipse Clean" did not help. Please find the attached screenshot.
Re: DAWN and Synchronous Modeling [message #872438 is a reply to message #872256] Wed, 16 May 2012 05:54 Go to previous messageGo to next message
Am 15.05.2012 21:25, schrieb Siva Raj:
> Hi Martin,
I can't see any exact problem marker descriptions. Why do you think this screenshot can help us to help you?
Cheers
/Eike
Re: DAWN and Synchronous Modeling [message #873921 is a reply to message #872438] Sat, 19 May 2012 13:32 Go to previous message
From this, you could see the projects which has problems. I thought, this might help you.
Previous Topic:CDO developer needed
Next Topic:[CDO] CDOQuery and local changes
Current Time: Thu Jun 21 18:35:29 GMT 2018
Powered by FUDForum. Page generated in 0.02822 seconds
