Home » Language IDEs » C / C++ IDE (CDT) » make: *** [scd_cmd_1] Error for no reason(make: *** [scd_cmd_1] Error 1 regedit [Discovery Options] page in project properties C/C++ Problem)
make: *** [scd_cmd_1] Error for no reason [message #851678] Sat, 21 April 2012 07:12 Go to next message
Ilya Basin is currently offline Ilya BasinFriend
I've built wine and imported programs/regedit as Makefile project.
In project options I checked "Automate discovery of paths and symbols"
Everything works except sometimes when I restart Eclipse this error appears:
Nothing suspicious on that page though. The error may sometimes disappear after I build the project, but I really haven't noticed a strict relation here.
What this error means? It's not very informative.
[Updated on: Tue, 24 April 2012 06:50]
Report message to a moderator
Re: make: *** [scd_cmd_1] Error for no reason [message #852151 is a reply to message #851678] Sat, 21 April 2012 18:31 Go to previous messageGo to next message
Klaus km is currently offline Klaus kmFriend
the "scanner discovery" could not parse the output of the compiler, if the compiler is using your local language. Are you sure that the compiler is printing all messages in English?
You could set a environment variable, for example LC_MESSAGE=en, to switch the compiler output back to en.
http://gcc.gnu.org/onlinedocs/gcc/Environment-Variables.html
I'm not sure if this is the problem on your PC, but you should check this.
regards,
Klaus
Re: make: *** [scd_cmd_1] Error for no reason [message #854690 is a reply to message #852151] Tue, 24 April 2012 06:49 Go to previous message
Thanks, I'll try
Previous Topic:[solved] Symbol could not be resolved
Next Topic:How to debug forked processes
Current Time: Sat May 26 21:49:24 GMT 2018
Powered by FUDForum. Page generated in 0.02775 seconds
