Home » Eclipse Projects » Vex » Cannot edit some attributes in Docbook
Cannot edit some attributes in Docbook [message #845161] Sat, 14 April 2012 16:27 Go to next message
Andreas Bartho is currently offline Andreas Bartho
after a long break I started to use VEX again and noticed that in Docbook v4.5 the value of my keycombo action attributes is not displayed in the properties view. It is also not possible to set a value. The predefined enumeration is not loaded, all I see is an empty dropdown list in the properties view. The same happens with other attributes, such as the common dir attribute (in section, para and others).
This behavior happens with the Milestone M8 build as well as the latest CI build. OS is Windows 7 64bit. Back in the old days, when VEX was still on Sourceforge, selecting parameter values worked, though Smile
Kind regards
Andreas
Re: Cannot edit some attributes in Docbook [message #856699 is a reply to message #845161] Wed, 25 April 2012 19:02 Go to previous messageGo to next message
Holger Voormann is currently offline Holger Voormann
Hi Andreas,
Thank you for reporting this issue.
Probably, this bug has been introduced in 1.0.0M8 and occurs for all attributes of enumerated values. I filled bug 377714: bugs.eclipse.org/377714
Holger
Re: Cannot edit some attributes in Docbook [message #859695 is a reply to message #856699] Fri, 27 April 2012 15:17 Go to previous messageGo to next message
Florian Thienel is currently offline Florian Thienel
Hi Andreas,
the bug is fixed and will be delivered with the next milestone 1.0.0M9. In the meantime you could use our "latest greatest" Vex from the CI build update site.
Best Regards,
Florian
Re: Cannot edit some attributes in Docbook [message #871292 is a reply to message #845161] Fri, 11 May 2012 15:19 Go to previous messageGo to next message
sorry for the late reply. I checked it and it works for me now. Thank you.
Andreas
Re: Cannot edit some attributes in Docbook [message #871300 is a reply to message #871292] Fri, 11 May 2012 16:04 Go to previous messageGo to next message
Hi Andreas,
thank you for your feedback! If you have any other issues, just drop us a line. Don't hesitate to create a bug in Bugzilla.
Florian
Re: Cannot edit some attributes in Docbook [message #902491 is a reply to message #845161] Fri, 17 August 2012 18:08 Go to previous message
Gergely Nagy is currently offline Gergely Nagy
Andreas Bartho wrote on Sat, 14 April 2012 16:27
1)May I ask how did you know the way to view/edit attributes in the first place?
I can't see "attribute" editing mentioned in the User guide.. is there a more update/comprehensive description?
2)So Properties is the only way to go with attributes?
Thanks,Gergo
[Updated on: Sat, 18 August 2012 02:57]
Report message to a moderator
Previous Topic:Support for XML includes
Next Topic:compatibility with older Eclipse/WTP
Current Time: Sun May 19 16:06:54 EDT 2013
Powered by FUDForum. Page generated in 0.08532 seconds
