Home » Language IDEs » C / C++ IDE (CDT) » Eclipse Indigo problem with debugger(debugger gives error no source found for ntdll.....)
Eclipse Indigo problem with debugger [message #839197] Sun, 08 April 2012 09:01 Go to next message
Waqas Afzal is currently offline Waqas AfzalFriend
I am new to Eclipse. I have started with CDT and using MinGW. The debugger was working fine until I started getting this error after I am halfway through my program. It says that no source found for ntdll....... How can I resolve this? I have been stuck on it for two days. I am using Eclipse Indigo. Thanks
Re: Eclipse Indigo problem with debugger [message #839316 is a reply to message #839197] Sun, 08 April 2012 13:34 Go to previous message
David Wegener is currently offline David WegenerFriend
On 04/08/2012 04:01 AM, Waqas Afzal wrote:
It sounds like you have stepped into a Windows routing. Ntdll is a
Windows system library. I don't think Microsoft distributes source for
the library, so you won't be able to see the source for it.
Previous Topic:Color on disassembly
Next Topic:Cygwin/Path/Symlink fixed = error 1 and no description?
Current Time: Wed Jun 20 21:27:10 GMT 2018
Powered by FUDForum. Page generated in 0.01712 seconds
