Registry conflict (running org.eclipse.equinox.jsp.jasper.registry) [message #100367] |
Fri, 26 October 2007 11:07 |
Originally posted by: dp-conde.criticalsoftware.com
I need to run org.eclipse.help.webapp package (as well as some other
packages) to have an embedded eclipse help system in my application.
The problem here is that this package has a dependency of one other
package (org.eclipse.equinox.jsp.jasper.registry) that conflicts with
some other packages that I need for the application.
So I was wondering, is it possible to run org.eclipse.help.webapp
without org.eclipse.equinox.jsp.jasper.registry? I'm using maven to
compile my project and I tried changing the dependencies on the pom.xml
file like this:
<dependency>
<groupId>org.eclipse.help</groupId>
<artifactId>webapp</artifactId>
<version>3.3.0</version>
<exclusions>
<exclusion>
<groupId>org.eclipse.equinox.jsp.jasper</groupId>
<artifactId>registry</artifactId>
</exclusion>
</exclusions>
</dependency>
But this didn't work, any thoughts about this issue?
Thanks in advance,
Daniel Conde.
Re: Registry conflict (running org.eclipse.equinox.jsp.jasper.registry) [message #100511 is a reply to message #100399] |
Mon, 29 October 2007 14:55 |
From what I see, it's probably conflicting with either
org.eclipse.equinox.registry or org.eclipse.equinox.http.registry.
What happens is that when I load org.eclipse.help.webapp, some of the
pictures aren't loaded correctly for the application.
Simon Kaegi wrote:
> You might ask on the Help list but probably not.
> org.eclipse.equinox.jsp.jasper.registry is what allows Help/UA to register
> JSPs the alternative would be to manually register the JSPServlet with the
> Http Service.
> I'm surprised this bundle would cause problems as it's dependencies are
> minor.
> What's conflicting?
> -Simon
> "Daniel Conde" <dp-conde@criticalsoftware.com> wrote in message
> news:ffshss$7rq$1@build.eclipse.org...
>> Hello,
>> So I was wondering, is it possible to run org.eclipse.help.webapp without
>> org.eclipse.equinox.jsp.jasper.registry? I'm using maven to compile my
>> project and I tried changing the dependencies on the pom.xml file like
>> this:
>> <dependency>
>> <exclusions>
>> <exclusion>
>> </exclusion>
>> </exclusions>
>> </dependency>
>> Thanks in advance,
>> Daniel Conde.
FUDForum. Page generated in 0.02355 seconds
