Home » Eclipse Projects » Rich Client Platform (RCP) » Modal dialogs randomly not working on OS X 10.7.3
Modal dialogs randomly not working on OS X 10.7.3 [message #818948] Mon, 12 March 2012 10:04 Go to next message
Valerio Santinelli is currently offline Valerio SantinelliFriend
Member
I've recently upgraded a Mac workstation from OS X 10.6 to OS X 10.7.3 and the Eclipse platform from 3.7.0 to 3.7.2
I've cleaned & rebuilt my RCP project and now there's something weird happening. Some of the modal dialogs (FileDialog and DirectoryDialog) just don't block when calling open(). They don't show up and just move on to the next line of code dumping this error on the console:
2012-03-12 10:53:01.273 java[75042:407] An instance 0x7f9d26c070f0 of class SWTFileOpenPanel was deallocated while key value observers were still registered with it. Observation info was leaked, and may even become mistakenly attached to some other object. Set a breakpoint on NSKVODeallocateBreak to stop here in the debugger. Here's the current observation info:
<NSKeyValueObservationInfo 0x7f9d239b2320> (
<NSKeyValueObservance 0x7f9d26cf1b30: Observer: 0x7f9d26ce23d0, Key path: firstResponder, Options: <New: NO, Old: NO, Prior: NO> Context: 0x0, Property: 0x7f9d26cf1940>
Invalid memory access of location 0x0 rip=0x7fff8e426e90
Has anyone ever had a similar problem?
I'm also posting a crash log as sometimes it also crashes:
Process:         java [90188]
Path:            /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/bin/java
Identifier:      java
Version:         1.0 (1.0)
Code Type:       X86-64 (Native)
Parent Process:  eclipse [88800]
PlugIn Path:       /Users/USER/Documents/*/libswt-pi-cocoa-3740.jnilib
PlugIn Identifier: libswt-pi-cocoa-3740.jnilib
PlugIn Version:    ??? (???)
Date/Time:       2012-03-12 11:14:40.630 +0100
OS Version:      Mac OS X 10.7.3 (11D50)
Report Version:  9
Interval Since Last Report:          8527 sec
Crashes Since Last Report:           7
Per-App Crashes Since Last Report:   6
Anonymous UUID:                      D99547BF-F773-473B-A506-5B499A345913
Crashed Thread:  0  Dispatch queue: com.apple.main-thread
Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: 0x000000000000000d, 0x0000000000000000
VM Regions Near 0:
    __TEXT                 00000001088dc000-00000001088e4000 [   32K] r-x/rwx SM=COW  /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/bin/java
Application Specific Information:
objc_msgSend() selector name: isVisible
objc[90188]: garbage collection is OFF
Java information:
 Exception type: Bus Error (0xa) at pc=7fff8e426e90
 Java VM: Java HotSpot(TM) 64-Bit Server VM (20.4-b02-402 mixed mode macosx-amd64)
Current thread (7f98c5004800):  JavaThread "Thread-1" daemon [_thread_in_native, id=2079029600, stack(7fff67cdc000,7fff684dc000)]
Stack: [7fff67cdc000,7fff684dc000]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j  org.eclipse.swt.internal.cocoa.OS.objc_msgSendSuper(Lorg/eclipse/swt/internal/cocoa/objc_super;JJ)J+0
j  org.eclipse.swt.widgets.Display.applicationSendEvent(JJJ)V+383
j  org.eclipse.swt.widgets.Display.applicationProc(JJJ)J+107
v  ~StubRoutines::call_stub
J  org.eclipse.swt.internal.cocoa.OS.objc_msgSend(JJJ)J
j  org.eclipse.swt.internal.cocoa.NSApplication.sendEvent(Lorg/eclipse/swt/internal/cocoa/NSEvent;)V+19
j  org.eclipse.swt.widgets.Display.readAndDispatch()Z+113
j  org.eclipse.ui.internal.Workbench.runEventLoop(Lorg/eclipse/jface/window/Window$IExceptionHandler;Lorg/eclipse/swt/widgets/Display;)V+9
j  org.eclipse.ui.internal.Workbench.runUI()I+555
j  org.eclipse.ui.internal.Workbench.access$4(Lorg/eclipse/ui/internal/Workbench;)I+1
j  org.eclipse.ui.internal.Workbench$7.run()V+73
j  org.eclipse.core.databinding.observable.Realm.runWithDefault(Lorg/eclipse/core/databinding/observable/Realm;Ljava/lang/Runnable;)V+12
j  org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display;Lorg/eclipse/ui/application/WorkbenchAdvisor;)I+18
j  org.eclipse.ui.PlatformUI.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display;Lorg/eclipse/ui/application/WorkbenchAdvisor;)I+2
j  it.itablo.designer.Application.start(Lorg/eclipse/equinox/app/IApplicationContext;)Ljava/lang/Object;+12
j  org.eclipse.equinox.internal.app.EclipseAppHandle.run(Ljava/lang/Object;)Ljava/lang/Object;+135
j  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(Ljava/lang/Object;)Ljava/lang/Object;+103
j  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ljava/lang/Object;)Ljava/lang/Object;+29
j  org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/lang/Object;)Ljava/lang/Object;+149
j  org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/lang/String;Ljava/lang/Runnable;)Ljava/lang/Object;+183
j  sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+0
j  sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+87
j  sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+6
j  java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+161
j  org.eclipse.equinox.launcher.Main.invokeFramework([Ljava/lang/String;[Ljava/net/URL;)V+211
j  org.eclipse.equinox.launcher.Main.basicRun([Ljava/lang/String;)V+126
j  org.eclipse.equinox.launcher.Main.run([Ljava/lang/String;)I+4
j  org.eclipse.equinox.launcher.Main.main([Ljava/lang/String;)V+10
Java Threads: ( => current thread )
  7f98c91c2800 JavaThread "Worker-2" [_thread_blocked, id=367632384, stack(115d9a000,115e9a000)]
  7f98c5adf800 JavaThread "Worker-1" [_thread_blocked, id=360755200, stack(11570b000,11580b000)]
  7f98c7aad000 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=402771968, stack(117f1d000,11801d000)]
  7f98c5d04800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=369762304, stack(115fa2000,1160a2000)]
  7f98c52dc800 JavaThread "AWT-Shutdown" [_thread_blocked, id=336273408, stack(113fb2000,1140b2000)]
  7f98c7aac800 JavaThread "Worker-0" [_thread_blocked, id=368701440, stack(115e9f000,115f9f000)]
  7f98c5aa0000 JavaThread "Worker-JM" [_thread_blocked, id=333680640, stack(113d39000,113e39000)]
  7f98c504d000 JavaThread "[Timer] - Main Queue Handler" daemon [_thread_blocked, id=332619776, stack(113c36000,113d36000)]
  7f98c5acb800 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=329678848, stack(113968000,113a68000)]
  7f98c792d800 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=328617984, stack(113865000,113965000)]
  7f98c792d000 JavaThread "State Saver" daemon [_thread_blocked, id=327557120, stack(113762000,113862000)]
  7f98c792c000 JavaThread "Framework Active Thread" [_thread_blocked, id=326496256, stack(11365f000,11375f000)]
  7f98c505a000 JavaThread "Poller SunPKCS11-Darwin" daemon [_thread_blocked, id=303300608, stack(112040000,112140000)]
=>7f98c5004800 JavaThread "Thread-1" daemon [_thread_in_native, id=2079029600, stack(7fff67cdc000,7fff684dc000)]
  7f98c6813000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=298852352, stack(111c02000,111d02000)]
  7f98c5003800 JavaThread "C2 CompilerThread1" daemon [_thread_blocked, id=297791488, stack(111aff000,111bff000)]
  7f98c5003000 JavaThread "C2 CompilerThread0" daemon [_thread_blocked, id=296730624, stack(1119fc000,111afc000)]
  7f98c5002000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=295669760, stack(1118f9000,1119f9000)]
  7f98c5001800 JavaThread "Surrogate Locker Thread (Concurrent GC)" daemon [_thread_blocked, id=294608896, stack(1117f6000,1118f6000)]
  7f98c5000800 JavaThread "Finalizer" daemon [_thread_blocked, id=291708928, stack(111532000,111632000)]
  7f98c7806800 JavaThread "Reference Handler" daemon [_thread_blocked, id=290648064, stack(11142f000,11152f000)]
  7f98c5800800 JavaThread "main" [_thread_in_native, id=152768512, stack(1090b1000,1091b1000)]
Other Threads:
  7f98c6812000 VMThread [stack: 11132c000,11142c000] [id=289587200]
  7f98c681c800 WatcherThread [stack: 111d05000,111e05000] [id=299913216]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
 par new generation   total 76672K, used 43811K [7b0000000, 7b5330000, 7b5330000)
  eden space 68160K,  59% used [7b0000000, 7b27e1910, 7b4290000)
  from space 8512K,  34% used [7b4ae0000, 7b4dc75b0, 7b5330000)
  to   space 8512K,   0% used [7b4290000, 7b4290000, 7b4ae0000)
 concurrent mark-sweep generation total 963392K, used 113669K [7b5330000, 7f0000000, 7f0000000)
 concurrent-mark-sweep perm gen total 45248K, used 45135K [7f0000000, 7f2c30000, 800000000)
Code Cache  [109329000, 10959a000, 10c329000)
 total_blobs=1076 nmethods=377 adapters=661 free_code_cache=48369280 largest_free_block=20992
Virtual Machine Arguments:
JVM Args: -Dosgi.requiredJavaVersion=1.5 -Dorg.eclipse.swt.internal.carbon.smallFonts -Dorg.eclipse.swt.internal.carbon.smallFonts -Dosgi.requiredJavaVersion=1.5 -Xms40m -Xmx384m -Dorg.eclipse.swt.internal.carbon.smallFonts -XX:MaxPermSize=256m -Xms1g -Xmx1g -Dorg.jpedal.jai=true -Dfile.encoding=MacRoman -Xbootclasspath/p:/Applications/eclipse/plugins/org.eclipse.jdt.debug_3.7.1.v20111006_r372/jdi.jar
Java Command: org.eclipse.equinox.launcher.Main -launcher /Applications/eclipse/Eclipse.app/Contents/MacOS/eclipse -name Eclipse -showsplash 600 -product it.itablo.designer.product -data /Users/tanis/Documents/workspace/../runtime-it.itablo.designer.product -configuration file:/Users/tanis/Documents/workspace/.metadata/.plugins/org.eclipse.pde.core/it.itablo.designer.product/ -dev file:/Users/tanis/Documents/workspace/.metadata/.plugins/org.eclipse.pde.core/it.itablo.designer.product/dev.properties -os macosx -ws cocoa -arch x86_64 -nl it_IT -consoleLog
Launcher Type: SUN_STANDARD
Physical Memory: Page Size = 4k, Total = 8192M, Free = 1640M
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   libobjc.A.dylib               	0x00007fff8e426e90 objc_msgSend + 16
1   com.apple.AppKit              	0x00007fff90181956 -[NSViewDynamicToolTipManager _appActivationChanged:] + 59
2   com.apple.Foundation          	0x00007fff8e6b3d32 __-[NSNotificationCenter addObserver:selector:name:object:]_block_invoke_1 + 47
3   com.apple.CoreFoundation      	0x00007fff955caaaa _CFXNotificationPost + 2634
4   com.apple.Foundation          	0x00007fff8e69ffe7 -[NSNotificationCenter postNotificationName:object:userInfo:] + 65
5   com.apple.AppKit              	0x00007fff9016f757 -[NSApplication sendEvent:] + 3011
6   libswt-pi-cocoa-3740.jnilib   	0x00000001142f0c0f Java_org_eclipse_swt_internal_cocoa_OS_objc_1msgSendSuper__Lorg_eclipse_swt_internal_cocoa_objc_1super_2JJ + 97
7   ???                           	0x0000000109339d6e 0 + 4449344878
8   ???                           	0x000000010932e929 0 + 4449298729
9   ???                           	0x000000010932e85a 0 + 4449298522
10  ???                           	0x0000000109329438 0 + 4449276984
11  libclient64.dylib             	0x0000000108a2177a 0x108976000 + 702330
12  libclient64.dylib             	0x0000000108a2153e 0x108976000 + 701758
13  libclient64.dylib             	0x0000000108a44b75 0x108976000 + 846709
14  libclient64.dylib             	0x0000000108ce98c3 0x108976000 + 3619011
15  libswt-cocoa-3740.jnilib      	0x0000000114238f92 callback + 1344
16  libswt-cocoa-3740.jnilib      	0x0000000114218717 fn1_3 + 47
17  libswt-pi-cocoa-3740.jnilib   	0x00000001142ec448 Java_org_eclipse_swt_internal_cocoa_OS_objc_1msgSend__JJJ + 54
18  ???                           	0x000000010942001d 0 + 4450287645
19  ???                           	0x000000010932e929 0 + 4449298729
20  ???                           	0x000000010932e85a 0 + 4449298522
21  ???                           	0x000000010932ea82 0 + 4449299074
22  ???                           	0x000000010932e85a 0 + 4449298522
23  ???                           	0x000000010932e96e 0 + 4449298798
24  ???                           	0x000000010932e96e 0 + 4449298798
25  ???                           	0x000000010932ed34 0 + 4449299764
26  ???                           	0x000000010932e85a 0 + 4449298522
27  ???                           	0x000000010932e96e 0 + 4449298798
28  ???                           	0x000000010932e96e 0 + 4449298798
29  ???                           	0x000000010932ee8d 0 + 4449300109
30  ???                           	0x000000010932ee8d 0 + 4449300109
31  ???                           	0x000000010932e9b3 0 + 4449298867
32  ???                           	0x000000010932e9b3 0 + 4449298867
33  ???                           	0x000000010932e9b3 0 + 4449298867
34  ???                           	0x0000000109329438 0 + 4449276984
35  libclient64.dylib             	0x0000000108a2177a 0x108976000 + 702330
36  libclient64.dylib             	0x0000000108a2153e 0x108976000 + 701758
37  libclient64.dylib             	0x0000000108a39308 0x108976000 + 799496
38  libclient64.dylib             	0x0000000108a3a496 0x108976000 + 803990
39  libclient64.dylib             	0x0000000108a3a25c JVM_InvokeMethod + 352
40  libjvmlinkage.dylib           	0x0000000109078d7e JVM_InvokeMethod + 78
41  ???                           	0x0000000109339d6e 0 + 4449344878
42  ???                           	0x000000010932e9b3 0 + 4449298867
43  ???                           	0x000000010932e9b3 0 + 4449298867
44  ???                           	0x000000010932ee8d 0 + 4449300109
45  ???                           	0x000000010932e9b3 0 + 4449298867
46  ???                           	0x000000010932e85a 0 + 4449298522
47  ???                           	0x000000010932e85a 0 + 4449298522
48  ???                           	0x000000010932e96e 0 + 4449298798
49  ???                           	0x0000000109329438 0 + 4449276984
50  libclient64.dylib             	0x0000000108a2177a 0x108976000 + 702330
51  libclient64.dylib             	0x0000000108a2153e 0x108976000 + 701758
52  libclient64.dylib             	0x0000000108a44b75 0x108976000 + 846709
53  libclient64.dylib             	0x0000000108a44a1d 0x108976000 + 846365
54  java                          	0x00000001088decf3 0x1088dc000 + 11507
55  java                          	0x00000001088e116d 0x1088dc000 + 20845
56  com.apple.CoreFoundation      	0x00007fff9564be0d +[NSObject performSelector:withObject:] + 61
57  com.apple.Foundation          	0x00007fff8e6ecd94 __NSThreadPerformPerform + 214
58  com.apple.CoreFoundation      	0x00007fff955906e1 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
59  com.apple.CoreFoundation      	0x00007fff9558ff4d __CFRunLoopDoSources0 + 253
60  com.apple.CoreFoundation      	0x00007fff955b6d39 __CFRunLoopRun + 905
61  com.apple.CoreFoundation      	0x00007fff955b6676 CFRunLoopRunSpecific + 230
62  java                          	0x00000001088e0843 0x1088dc000 + 18499
63  java                          	0x00000001088e029a 0x1088dc000 + 17050
64  java                          	0x00000001088dda98 0x1088dc000 + 6808
Thread 1:
0   libsystem_kernel.dylib        	0x00007fff91693bca __psynch_cvwait + 10
1   libsystem_c.dylib             	0x00007fff95220274 _pthread_cond_wait + 840
2   com.apple.Foundation          	0x00007fff8e6f94e4 -[NSCondition wait] + 261
3   com.apple.Foundation          	0x00007fff8e6ec878 -[NSObject(NSThreadPerformAdditions) performSelector:onThread:withObject:waitUntilDone:modes:] + 975
4   com.apple.Foundation          	0x00007fff8e6ec42b -[NSObject(NSThreadPerformAdditions) performSelectorOnMainThread:withObject:waitUntilDone:] + 135
5   java                          	0x00000001088e10a7 0x1088dc000 + 20647
6   java                          	0x00000001088df240 0x1088dc000 + 12864
7   libsystem_c.dylib             	0x00007fff9521c8bf _pthread_start + 335
8   libsystem_c.dylib             	0x00007fff9521fb75 thread_start + 13
Thread 2:: Java: Exception Handler Thread
0   libsystem_kernel.dylib        	0x00007fff9169267a mach_msg_trap + 10
1   libsystem_kernel.dylib        	0x00007fff91691d71 mach_msg + 73
2   libsystem_kernel.dylib        	0x00007fff9169231c mach_msg_server + 641
3   libclient64.dylib             	0x000000010898ade9 0x108976000 + 85481
4   libclient64.dylib             	0x000000010898aca3 0x108976000 + 85155
5   libclient64.dylib             	0x0000000108989884 0x108976000 + 80004
6   libsystem_c.dylib             	0x00007fff9521c8bf _pthread_start + 335
7   libsystem_c.dylib             	0x00007fff9521fb75 thread_start + 13
Thread 3:: Java: Gang worker#0 (Parallel GC Threads)
2   libclient64.dylib             	0x0000000108989f23 0x108976000 + 81699
3   libclient64.dylib             	0x0000000108989de3 0x108976000 + 81379
4   libclient64.dylib             	0x0000000108989d42 0x108976000 + 81218
5   libclient64.dylib             	0x000000010898991d 0x108976000 + 80157
6   libclient64.dylib             	0x00000001089897c3 0x108976000 + 79811
7   libclient64.dylib             	0x00000001089a25c8 0x108976000 + 181704
8   libclient64.dylib             	0x0000000108989884 0x108976000 + 80004
9   libsystem_c.dylib             	0x00007fff9521c8bf _pthread_start + 335
10  libsystem_c.dylib             	0x00007fff9521fb75 thread_start + 13
Thread 4:: Java: Gang worker#1 (Parallel GC Threads)
Thread 5:: Java: Gang worker#2 (Parallel GC Threads)
Thread 6:: Java: Gang worker#3 (Parallel GC Threads)
Thread 7:: Java: Concurrent Mark-Sweep GC Thread
2   libclient64.dylib             	0x0000000108989fb5 0x108976000 + 81845
3   libclient64.dylib             	0x00000001089a8b6e 0x108976000 + 207726
4   libclient64.dylib             	0x000000010898991d 0x108976000 + 80157
5   libclient64.dylib             	0x00000001089897c3 0x108976000 + 79811
6   libclient64.dylib             	0x0000000108a7e8e5 0x108976000 + 1083621
7   libclient64.dylib             	0x0000000108a7e7cf 0x108976000 + 1083343
8   libclient64.dylib             	0x00000001089a89e9 0x108976000 + 207337
9   libclient64.dylib             	0x0000000108989884 0x108976000 + 80004
10  libsystem_c.dylib             	0x00007fff9521c8bf _pthread_start + 335
11  libsystem_c.dylib             	0x00007fff9521fb75 thread_start + 13
Thread 8:: Java: VM Thread
6   libclient64.dylib             	0x0000000108a205b7 0x108976000 + 697783
7   libclient64.dylib             	0x0000000108a20307 0x108976000 + 697095
Thread 9:: Java: Reference Handler
4   libclient64.dylib             	0x0000000108a2ebc3 0x108976000 + 756675
5   libclient64.dylib             	0x0000000108a2e050 0x108976000 + 753744
6   libclient64.dylib             	0x0000000108a2dcbc JVM_MonitorWait + 154
7   libjvmlinkage.dylib           	0x0000000109074b0b JVM_MonitorWait + 59
8   ???                           	0x0000000109339d6e 0 + 4449344878
10  ???                           	0x000000010932e85a 0 + 4449298522
11  ???                           	0x0000000109329438 0 + 4449276984
12  libclient64.dylib             	0x0000000108a2177a 0x108976000 + 702330
13  libclient64.dylib             	0x0000000108a2d808 0x108976000 + 751624
14  libclient64.dylib             	0x0000000108a2d6fe 0x108976000 + 751358
15  libclient64.dylib             	0x0000000108a2d69e 0x108976000 + 751262
16  libclient64.dylib             	0x0000000108a2d540 0x108976000 + 750912
17  libclient64.dylib             	0x0000000108a2d355 0x108976000 + 750421
18  libclient64.dylib             	0x0000000108989884 0x108976000 + 80004
19  libsystem_c.dylib             	0x00007fff9521c8bf _pthread_start + 335
20  libsystem_c.dylib             	0x00007fff9521fb75 thread_start + 13
Thread 10:: Java: Finalizer
10  ???                           	0x000000010932e9b3 0 + 4449298867
11  ???                           	0x000000010932e9b3 0 + 4449298867
12  ???                           	0x0000000109329438 0 + 4449276984
13  libclient64.dylib             	0x0000000108a2177a 0x108976000 + 702330
14  libclient64.dylib             	0x0000000108a2d808 0x108976000 + 751624
15  libclient64.dylib             	0x0000000108a2d6fe 0x108976000 + 751358
16  libclient64.dylib             	0x0000000108a2d69e 0x108976000 + 751262
17  libclient64.dylib             	0x0000000108a2d540 0x108976000 + 750912
18  libclient64.dylib             	0x0000000108a2d355 0x108976000 + 750421
19  libclient64.dylib             	0x0000000108989884 0x108976000 + 80004
20  libsystem_c.dylib             	0x00007fff9521c8bf _pthread_start + 335
21  libsystem_c.dylib             	0x00007fff9521fb75 thread_start + 13
Thread 11:: Dispatch queue: com.apple.libdispatch-manager
0   libsystem_kernel.dylib        	0x00007fff916947e6 kevent + 10
1   libdispatch.dylib             	0x00007fff964f85be _dispatch_mgr_invoke + 923
2   libdispatch.dylib             	0x00007fff964f714e _dispatch_mgr_thread + 54
Thread 12:
0   libsystem_kernel.dylib        	0x00007fff91694192 __workq_kernreturn + 10
1   libsystem_c.dylib             	0x00007fff9521e594 _pthread_wqthread + 758
2   libsystem_c.dylib             	0x00007fff9521fb85 start_wqthread + 13
Thread 13:
Thread 14:: Java: Surrogate Locker Thread (Concurrent GC)
6   libclient64.dylib             	0x000000010898972a 0x108976000 + 79658
7   libclient64.dylib             	0x0000000108a3dfcd 0x108976000 + 819149
8   libclient64.dylib             	0x0000000108a2d540 0x108976000 + 750912
9   libclient64.dylib             	0x0000000108a2d355 0x108976000 + 750421
10  libclient64.dylib             	0x0000000108989884 0x108976000 + 80004
11  libsystem_c.dylib             	0x00007fff9521c8bf _pthread_start + 335
12  libsystem_c.dylib             	0x00007fff9521fb75 thread_start + 13
Thread 15:: Java: Signal Dispatcher
0   libsystem_kernel.dylib        	0x00007fff916926b6 semaphore_wait_trap + 10
1   libclient64.dylib             	0x0000000108a3e80f 0x108976000 + 821263
2   libclient64.dylib             	0x0000000108a3e296 0x108976000 + 819862
3   libclient64.dylib             	0x0000000108a2d540 0x108976000 + 750912
4   libclient64.dylib             	0x0000000108a2d355 0x108976000 + 750421
Thread 16:: Java: C2 CompilerThread0
7   libclient64.dylib             	0x0000000108a4507d 0x108976000 + 847997
8   libclient64.dylib             	0x0000000108a3f67f 0x108976000 + 824959
9   libclient64.dylib             	0x0000000108a2d540 0x108976000 + 750912
10  libclient64.dylib             	0x0000000108a2d355 0x108976000 + 750421
11  libclient64.dylib             	0x0000000108989884 0x108976000 + 80004
12  libsystem_c.dylib             	0x00007fff9521c8bf _pthread_start + 335
13  libsystem_c.dylib             	0x00007fff9521fb75 thread_start + 13
Thread 17:: Java: C2 CompilerThread1
Thread 18:: Java: Low Memory Detector
7   libclient64.dylib             	0x0000000108a41080 0x108976000 + 831616
Thread 19:: Java: VM Periodic Task Thread
4   libclient64.dylib             	0x0000000108a431b2 0x108976000 + 840114
Thread 20:: Java: Poller SunPKCS11-Darwin
3   libclient64.dylib             	0x0000000108b2b8d8 0x108976000 + 1792216
4   libclient64.dylib             	0x0000000108b3a466 JVM_Sleep + 191
5   libjvmlinkage.dylib           	0x000000010907565e JVM_Sleep + 62
6   ???                           	0x0000000109339d6e 0 + 4449344878
8   ???                           	0x000000010932ed34 0 + 4449299764
10  libclient64.dylib             	0x0000000108a2177a 0x108976000 + 702330
11  libclient64.dylib             	0x0000000108a2d808 0x108976000 + 751624
12  libclient64.dylib             	0x0000000108a2d6fe 0x108976000 + 751358
13  libclient64.dylib             	0x0000000108a2d69e 0x108976000 + 751262
14  libclient64.dylib             	0x0000000108a2d540 0x108976000 + 750912
15  libclient64.dylib             	0x0000000108a2d355 0x108976000 + 750421
16  libclient64.dylib             	0x0000000108989884 0x108976000 + 80004
17  libsystem_c.dylib             	0x00007fff9521c8bf _pthread_start + 335
18  libsystem_c.dylib             	0x00007fff9521fb75 thread_start + 13
Thread 21:: Java: Framework Active Thread
4   libclient64.dylib             	0x0000000108a2ebcd 0x108976000 + 756685
10  ???                           	0x000000010932ed34 0 + 4449299764
Thread 22:: Java: State Saver
Thread 23:: Java: Framework Event Dispatcher
Thread 24:: Java: Start Level Event Dispatcher
Thread 25:: Java: [Timer] - Main Queue Handler
Thread 26:: Java: Worker-JM
12  libclient64.dylib             	0x0000000108a2d808 0x108976000 + 751624
13  libclient64.dylib             	0x0000000108a2d6fe 0x108976000 + 751358
14  libclient64.dylib             	0x0000000108a2d69e 0x108976000 + 751262
15  libclient64.dylib             	0x0000000108a2d540 0x108976000 + 750912
16  libclient64.dylib             	0x0000000108a2d355 0x108976000 + 750421
17  libclient64.dylib             	0x0000000108989884 0x108976000 + 80004
18  libsystem_c.dylib             	0x00007fff9521c8bf _pthread_start + 335
19  libsystem_c.dylib             	0x00007fff9521fb75 thread_start + 13
Thread 27:: Java: Worker-0
Thread 28:: Java: AWT-Shutdown
11  ???                           	0x000000010932ed34 0 + 4449299764
Thread 29:: Java: Java2D Disposer
12  ???                           	0x000000010932ed34 0 + 4449299764
13  ???                           	0x0000000109329438 0 + 4449276984
14  libclient64.dylib             	0x0000000108a2177a 0x108976000 + 702330
15  libclient64.dylib             	0x0000000108a2d808 0x108976000 + 751624
16  libclient64.dylib             	0x0000000108a2d6fe 0x108976000 + 751358
17  libclient64.dylib             	0x0000000108a2d69e 0x108976000 + 751262
18  libclient64.dylib             	0x0000000108a2d540 0x108976000 + 750912
19  libclient64.dylib             	0x0000000108a2d355 0x108976000 + 750421
20  libclient64.dylib             	0x0000000108989884 0x108976000 + 80004
21  libsystem_c.dylib             	0x00007fff9521c8bf _pthread_start + 335
22  libsystem_c.dylib             	0x00007fff9521fb75 thread_start + 13
Thread 30:: Java: AWT-EventQueue-0
12  ???                           	0x000000010932ea82 0 + 4449299074
13  ???                           	0x000000010932e85a 0 + 4449298522
14  ???                           	0x000000010932e85a 0 + 4449298522
15  ???                           	0x000000010932e85a 0 + 4449298522
16  ???                           	0x000000010932e85a 0 + 4449298522
17  ???                           	0x0000000109329438 0 + 4449276984
18  libclient64.dylib             	0x0000000108a2177a 0x108976000 + 702330
19  libclient64.dylib             	0x0000000108a2d808 0x108976000 + 751624
20  libclient64.dylib             	0x0000000108a2d6fe 0x108976000 + 751358
21  libclient64.dylib             	0x0000000108a2d69e 0x108976000 + 751262
22  libclient64.dylib             	0x0000000108a2d540 0x108976000 + 750912
23  libclient64.dylib             	0x0000000108a2d355 0x108976000 + 750421
24  libclient64.dylib             	0x0000000108989884 0x108976000 + 80004
25  libsystem_c.dylib             	0x00007fff9521c8bf _pthread_start + 335
26  libsystem_c.dylib             	0x00007fff9521fb75 thread_start + 13
Thread 31:
Thread 32:: Java: Worker-1
Thread 33:: Java: Worker-2
Thread 34:
Thread 35:
Thread 36:
Thread 37:: com.apple.CFSocket.private
0   libsystem_kernel.dylib        	0x00007fff91693df2 __select + 10
1   com.apple.CoreFoundation      	0x00007fff955ffcdb __CFSocketManager + 1355
Thread 38:
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x00007f98c48babc0  rbx: 0x00007f98c8d01fd0  rcx: 0x00000000000f4f57  rdx: 0x00007f98c4888300
  rdi: 0x00007f98c48babc0  rsi: 0x00007fff909e0290  rbp: 0x00007fff684d7800  rsp: 0x00007fff684d77e0
   r8: 0x00007f98c4801c00   r9: 0x00007f98c48362f0  r10: 0x0000000113c0b860  r11: 0x500007f98c48b4b0
  r12: 0x00007f98c7237200  r13: 0x0000000000000000  r14: 0x00007fff90a56633  r15: 0x00000000000001b3
  rip: 0x00007fff8e426e90  rfl: 0x0000000000010246  cr2: 0x00000001155ab01c
Logical CPU: 2
Binary Images:
       0x1088dc000 -        0x1088e3fff  java (1.0 - 1.0) <4AC9C9AB-E0C3-3116-ADBE-2A99D1505D7B> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/bin/java
       0x1088ef000 -        0x1088f5fff  libjli.jnilib (??? - ???) <2927BE65-1D10-3C92-B5B1-B5E070A84C31> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libjli.jnilib
       0x1088ff000 -        0x108904fff  com.apple.JavaVM (14.1.0 - 14.1.0) <83C8C2AB-E99D-39FF-80B4-90A7DEB1DAFB> /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
       0x10890e000 -        0x108913fff  JavaLaunching (??? - ???) <94CDB5A6-7C7A-3FAC-BC48-152A1FB96508> /System/Library/PrivateFrameworks/JavaLaunching.framework/Versions/A/JavaLaunching
       0x108976000 -        0x108fa4ff7  libclient64.dylib (??? - ???) <D3325E4E-CACF-39AE-8668-8F8E5A8F5B2D> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/bundle/Libraries/libclient64.dylib
       0x109074000 -        0x10907bfff  libjvmlinkage.dylib (??? - ???) <4E1B7F6A-050F-3F83-B333-4C0B5456022B> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libjvmlinkage.dylib
       0x1091b3000 -        0x1091bbff7  libverify.dylib (1.0 - 1.0) <BEE0B2CE-E7BA-3830-BD53-D1AC2E127C38> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libverify.dylib
       0x1091c1000 -        0x1091cbfff  JavaNativeFoundation (??? - ???) <3D79FBBE-054D-3209-A8D0-BF5D3D733A91> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaNativeFoundation.framework/Versions/A/JavaNativeFoundation
       0x1091d6000 -        0x1091f6ff7  libjava.jnilib (??? - ???) <F16EC2DC-1801-3D12-BB50-2D88A62FC0BA> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libjava.jnilib
       0x109315000 -        0x109322ff7  libzip.jnilib (??? - ???) <457C25EB-8F18-35CF-878C-82B4D6369300> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libzip.jnilib
       0x111e07000 -        0x111e11fff  com.apple.JavaApplicationLauncher (14.1.0 - 14.1.0) <22591A47-7E67-3F2C-AAEE-5A63558CA28B> /System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Versions/A/JavaApplicationLauncher
       0x111e97000 -        0x111e9dfef  libcldcpuengine.dylib (1.50.69 - compatibility 1.0.0) <C0C4CC37-F2FD-301C-A830-EC54D86612D5> /System/Library/Frameworks/OpenCL.framework/Libraries/libcldcpuengine.dylib
       0x111ea4000 -        0x111ea7ff7  libCoreFSCache.dylib (??? - ???) <0E2C3D54-7D05-35E8-BA10-2142B7C03946> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
       0x111ebf000 -        0x111ebfff5 +cl_kernels (??? - ???) <4B0A7A66-01A2-492D-9404-64EE44215965> cl_kernels
       0x111ecb000 -        0x111ecbffd +cl_kernels (??? - ???) <94BBBFA1-DB3F-4C6D-8562-4F6E3330DCB7> cl_kernels
       0x111efa000 -        0x111f02ff7  com.apple.java.JavaRuntimeSupport (14.1.0 - 14.1.0) <B1138A29-DFA3-3496-BA5A-4FDD61C729C5> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaRuntimeSupport.framework/Versions/A/JavaRuntimeSupport
       0x111f26000 -        0x111f26fff  libcmm.jnilib (??? - ???) <1DF114DE-4BCC-3C7D-A60C-3E5C69612797> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libcmm.jnilib
       0x111fbd000 -        0x111fbeffc +cl_kernels (??? - ???) <B071D260-2C4D-45B8-91DD-015BBBF5ADF0> cl_kernels
       0x111fe8000 -        0x111ff5fff  libj2pkcs11.jnilib (??? - ???) <69689BAB-9455-3758-80A7-26BB4088EBF9> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libj2pkcs11.jnilib
       0x111ffb000 -        0x112020fff  tokendPKCS11.so (??? - ???) <DC0BBE2F-3BE4-320F-A0EC-C317555286E7> /usr/libexec/SmartCardServices/pkcs11/tokendPKCS11.so
       0x112142000 -        0x11214bfff +eclipse_1408.so (??? - ???) <F25E6D65-914A-1B6D-E6EF-B33E70C9FC9A> /Applications/eclipse/*/eclipse_1408.so
       0x11324c000 -        0x11324dff3 +cl_kernels (??? - ???) <DF0A493D-0D71-4268-9654-89DE8B0A06E9> cl_kernels
       0x113250000 -        0x113257fff  com.apple.URLMount.AFPPlugin (4.0 - 4.0) <91C71C5D-562D-37C4-9131-6E6F086288DE> /System/Library/Filesystems/NetFSPlugins/afp.bundle/Contents/MacOS/afp
       0x113285000 -        0x113290ff7  com.apple.AppleSRP (1.0 - 1) <E6D40A04-D788-3799-ABA4-819055C70951> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
       0x11330b000 -        0x113317fff  libnet.jnilib (??? - ???) <597B3A97-B9FE-3EF1-B679-D48167CF1C65> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libnet.jnilib
       0x11331d000 -        0x113321fff  libnio.jnilib (??? - ???) <3385FD79-7550-3BD9-AC99-51F42EF2CC06> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libnio.jnilib
       0x113b8c000 -        0x113bb0fff  libdcpr.jnilib (??? - ???) <B059ACB3-2862-3B2A-8D80-B88AB6145278> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libdcpr.jnilib
       0x1140ff000 -        0x114125ff7  libjpeg.jnilib (??? - ???) <DAD75831-98EB-3C65-B6E3-50E344CB35E6> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libjpeg.jnilib
       0x11416e000 -        0x114171fff  libLatinSuppConverter.dylib (54.0.0 - compatibility 1.0.0) <AE9374F3-9A80-37B1-97F9-E5E952CE1D61> /System/Library/CoreServices/Encodings/libLatinSuppConverter.dylib
       0x114213000 -        0x11424cfff +libswt-cocoa-3740.jnilib (??? - ???) <BFDF4C6B-E2EC-1B0E-CEFA-D970BFE6A3EC> /Users/USER/Documents/*/libswt-cocoa-3740.jnilib
       0x1142dd000 -        0x114303fff +libswt-pi-cocoa-3740.jnilib (??? - ???) <426C4FC2-8051-0A28-4A12-C029EBDFCD63> /Users/USER/Documents/*/libswt-pi-cocoa-3740.jnilib
       0x115c1f000 -        0x115c71fff  libsuncmm.jnilib (??? - ???) <C032DD07-B828-38A2-A39D-315F14B7542E> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libsuncmm.jnilib
       0x115cc3000 -        0x115d29ff7  libfontmanager.jnilib (??? - ???) <193DAC4D-86CC-3A76-811F-E0040A78BB72> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libfontmanager.jnilib
       0x117599000 -        0x117771ff7  libawt.jnilib (??? - ???) <2DCB262F-4E60-356D-841E-F128C09228C3> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libawt.jnilib
       0x11f18b000 -        0x11f21eff7  unorm8_bgra.dylib (1.50.69 - compatibility 1.0.0) <5FB796A4-1AD0-3B4D-AA83-F8A46E039224> /System/Library/Frameworks/OpenCL.framework/Libraries/ImageFormats/unorm8_bgra.dylib
       0x11f49e000 -        0x11f4eaff7  com.apple.AppleShareClientCore (2.5 - 2.5) <CC62F28C-398E-35E2-B2C0-B85A02E57247> /System/Library/Frameworks/AppleShareClientCore.framework/Versions/A/AppleShareClientCore
    0x7fff684dc000 -     0x7fff68510baf  dyld (195.6 - ???) <0CD1B35B-A28F-32DA-B72E-452EAD609613> /usr/lib/dyld
    0x7fff8a859000 -     0x7fff8a8a7fff  libauto.dylib (??? - ???) <D8AC8458-DDD0-3939-8B96-B6CED81613EF> /usr/lib/libauto.dylib
    0x7fff8a8a8000 -     0x7fff8a95bfff  com.apple.CoreText (220.11.0 - ???) <0322442E-0530-37E8-A7D6-AEFD909F0AFE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fff8a95c000 -     0x7fff8a9feff7  com.apple.securityfoundation (5.0 - 55107) <6C2E7362-CB11-3CBD-BB1C-348E4B10F25A> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fff8aa1e000 -     0x7fff8aa24ff7  com.apple.phonenumbers (1.0 - 47) <BC6C2FE2-99C0-3AD6-AA9C-C88780FFFCCF> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
    0x7fff8aa25000 -     0x7fff8aa78fff  com.apple.AppleVAFramework (5.0.14 - 5.0.14) <45159B9E-05BF-35B2-AF76-D933490FBFB1> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x7fff8aa7b000 -     0x7fff8aa91fff  libGL.dylib (??? - ???) <6A473BF9-4D35-34C6-9F8B-86B68091A9AF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fff8aa92000 -     0x7fff8aae9fff  com.apple.Suggestions (1.1 - 85.1) <DE511C42-D2F2-309C-80EE-53862245DE22> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions
    0x7fff8aaea000 -     0x7fff8af07ff7  com.apple.SceneKit (2.2 - 125.3) <DDCC8DB6-D5DB-31CD-A401-F56C84216E1C> /System/Library/PrivateFrameworks/SceneKit.framework/Versions/A/SceneKit
    0x7fff8af08000 -     0x7fff8af70ff7  com.apple.audio.CoreAudio (4.0.2 - 4.0.2) <DFD8F4DE-3B45-3A2E-9CBE-FD8D5DD30923> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fff8af88000 -     0x7fff8af88fff  com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <C06A140F-6114-3B8B-B080-E509303145B8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fff8af89000 -     0x7fff8b0bffff  com.apple.vImage (5.1 - 5.1) <A08B7582-67BC-3EED-813A-4833645964A7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fff8b297000 -     0x7fff8b2deff7  com.apple.CoreMedia (1.0 - 705.61) <0C34B0D4-DB8A-33C7-B67B-F443AD86482C> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x7fff8b2df000 -     0x7fff8b371fff  com.apple.PDFKit (2.6.2 - 2.6.2) <4C8D80F6-09BB-3BD5-983B-A24FBEB5BCF3> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
    0x7fff8b372000 -     0x7fff8b839fff  FaceCoreLight (1.4.7 - compatibility 1.0.0) <E9D2A69C-6E81-358C-A162-510969F91490> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
    0x7fff8b876000 -     0x7fff8b88aff7  com.apple.LangAnalysis (1.7.0 - 1.7.0) <04C31EF0-912A-3004-A08F-CEC27030E0B2> /System/Library/Fr
[Updated on: Mon, 12 March 2012 10:16]
Report message to a moderator
Re: Modal dialogs randomly not working on OS X 10.7.3 [message #818995 is a reply to message #818948] Mon, 12 March 2012 11:00 Go to previous messageGo to next message
Member
Update: it looks like this has to do with bug 364116, but it's not been fixed in Eclipse 3.7.2
Re: Modal dialogs randomly not working on OS X 10.7.3 [message #855348 is a reply to message #818995] Tue, 24 April 2012 18:36 Go to previous messageGo to next message
Bertus  ölscher is currently offline Bertus ölscherFriend
I have the same problem. Did you find a solution for it?
Re: Modal dialogs randomly not working on OS X 10.7.3 [message #856270 is a reply to message #855348] Wed, 25 April 2012 14:15 Go to previous message
Grant Gayed is currently offline Grant GayedFriend
The target milestone of
https://bugs.eclipse.org/bugs/show_bug.cgi?id=364116 is 3.8M6 (aka
4.2M6), so it should be fixed in June's upcoming 3.8/4.2 release. If
you want to try it sooner then get 3.8M6 from
http://download.eclipse.org/eclipse/downloads/drops/S-3.8M6-201203141800/index.php
Grant
Previous Topic:adding the standard "Make Targets"contextMenu-item to the navigator view of RCP
Next Topic:Problems with adding commands to the toolbar.
Current Time: Sun Apr 22 12:57:31 GMT 2018
Powered by FUDForum. Page generated in 0.02244 seconds
