Http Service [message #98965] |
Sun, 30 September 2007 19:28 |
Originally posted by: abo.splitshade.de
I try hard to get behind some Implementationdetails in equinox.
One important Question I don?t understand is, what do this lines do?
context = bundleContext;
Object[] proxyServlets = serviceRegistrations.keySet().toArray();
for (int i = 0; i < proxyServlets.length; ++i) {
ServiceRegistration registration = registerHttpService((ProxyServlet)
proxyServlets[i]);
serviceRegistrations.put(proxyServlets[i], registration);
context.registerService(HttpService.class.getName(), factory,
serviceProperties);
This is what happens in the 'org.eclipse.equinox.http.servlet.internal'
package in the Activator class.
What seems to happen here is, that there are several http-Services
registered?
Why would one do that? I thought, only one http-service is needed?
Any Help appreciated
Martin
Re: Http Service [message #99010 is a reply to message #98995] |
Mon, 01 October 2007 06:02 |
Ah ok, that makes sense, thank you very much, it?s a little confusing in
the first view..
Greetings
Martin
Simon Kaegi schrieb:
> Hi Martin,
> You're right in that code is for handling multiple instances of the Http
> Service.
> This is not typical but can be useful in some circumstances.Most uses
> involve extra ports to perhaps provide a public facing web port for one Http
> Service instance as well as an internal management port for another. In
> other cases multiple Http Services are used simply to provide some isolation
> of the URI space between applications.
> -Simon
> "Martin Dilger" <abo@splitshade.de> wrote in message
> news:fdotdf$56b$1@build.eclipse.org...
>> proxyServlets[i]);
>> serviceProperties);
>> registered?
>> Martin
FUDForum. Page generated in 0.03263 seconds
