class not found even after package exported [message #98903] |
Sun, 30 September 2007 07:59 |
Originally posted by: thakore.mayank.gmail.com
I am running standard, osgi framework bundles from inside eclipse 3.2.0.
I get a class not found exception java.lang.NoClassDefFoundError
However the package is already imported. There are two classes in the
package. One of them I am able to access but not the other ! (the
exporting bundle has the package inside a jar file in its classpath).
When I removed the import both classes are inaccessible. But if I
introduce the import only one of the classes becomes accessible. I have
ensured that only one bundle is exporting the package.
I'm stuck with this for a few hours now and don't know how to go around
looking for a solution. Can you give any pointers?
Thanks!
Mayank
Class which was not found: org.codehaus.xfire.transport.jms.JMSChannel
Class which was found: org.codehaus.xfire.transport.jms.JMSTransport
osgi console output:
osgi>
osgi>
osgi>
osgi>
osgi> ss
Framework is launched.
id State Bundle
0 ACTIVE system.bundle_3.2.0.v20060601
31 ACTIVE XFireBasicHTTP_1.0.0
32 ACTIVE XFireBasicJMS_1.0.0
34 RESOLVED XFireBasicProduction_1.0.0
osgi>
osgi>
osgi>
osgi>
osgi> start 34
org.osgi.framework.BundleException: Exception in
xfirebasicproduction.Activator.start() of bundle XFireBasicProduction.
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1014)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:317)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:256)
org.eclipse.osgi.framework.internal.core.FrameworkCommandPro vider._start(FrameworkCommandProvider.java:239)
org.eclipse.osgi.framework.internal.core.FrameworkCommandInt erpreter.execute(FrameworkCommandInterpreter.java:145)
org.eclipse.osgi.framework.internal.core.FrameworkConsole.do command(FrameworkConsole.java:293)
org.eclipse.osgi.framework.internal.core.FrameworkConsole.co nsole(FrameworkConsole.java:278)
org.eclipse.osgi.framework.internal.core.FrameworkConsole.ru n(FrameworkConsole.java:213)
at java.lang.Thread.run(Thread.java:619)
Caused by: java.lang.NoClassDefFoundError:
org/codehaus/xfire/transport/jms/JMSChannel
at xfirebasicproduction.Activator.start(Activator.java:26)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:995)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:989)
... 13 more
Nested Exception:
java.lang.NoClassDefFoundError: org/codehaus/xfire/transport/jms/JMSChannel
Nested Exception:
osgi>
osgi>
osgi>
osgi>
osgi>
osgi>
osgi>
osgi>
osgi> bundle 31
initial@reference:file:../../export/home/mordox/xfire
stuff/workspace/XFireBasicHTTP/ [31]
Id=31, Status=ACTIVE Data Root=/export/home/mordox/xfire
stuff/workspace/.metadata/.plugins/org.eclipse.pde.core/New_ configuration/org.eclipse.osgi/bundles/31/data
Registered Services
{org.codehaus.xfire.service.binding.ObjectServiceFactory}={s ervice.id=18}
No services in use.
Exported packages
org.apache.commons.codec; version="0.0.0"[exported]
org.apache.commons.codec.binary; version="0.0.0"[exported]
org.apache.commons.codec.digest; version="0.0.0"[exported]
org.apache.commons.codec.language; version="0.0.0"[exported]
org.apache.commons.codec.net; version="0.0.0"[exported]
org.apache.commons.logging; version="0.0.0"[exported]
org.codehaus.stax2; version="0.0.0"[exported]
org.codehaus.stax2.evt; version="0.0.0"[exported]
org.codehaus.stax2.io; version="0.0.0"[exported]
org.codehaus.stax2.validation; version="0.0.0"[exported]
org.codehaus.xfire; version="0.0.0"[exported]
org.codehaus.xfire.addressing; version="0.0.0"[exported]
org.codehaus.xfire.aegis; version="0.0.0"[exported]
org.codehaus.xfire.aegis.jdom; version="0.0.0"[exported]
org.codehaus.xfire.aegis.stax; version="0.0.0"[exported]
org.codehaus.xfire.aegis.type; version="0.0.0"[exported]
org.codehaus.xfire.aegis.type.basic; version="0.0.0"[exported]
org.codehaus.xfire.aegis.type.collection; version="0.0.0"[exported]
org.codehaus.xfire.aegis.type.java5; version="0.0.0"[exported]
org.codehaus.xfire.aegis.type.mtom; version="0.0.0"[exported]
org.codehaus.xfire.aegis.type.xml; version="0.0.0"[exported]
org.codehaus.xfire.annotations; version="0.0.0"[exported]
org.codehaus.xfire.annotations.commons; version="0.0.0"[exported]
org.codehaus.xfire.annotations.commons.soap; version="0.0.0"[exported]
org.codehaus.xfire.annotations.jsr181; version="0.0.0"[exported]
org.codehaus.xfire.annotations.soap; version="0.0.0"[exported]
org.codehaus.xfire.attachments; version="0.0.0"[exported]
org.codehaus.xfire.castor; version="0.0.0"[exported]
org.codehaus.xfire.client; version="0.0.0"[exported]
org.codehaus.xfire.exchange; version="0.0.0"[exported]
org.codehaus.xfire.fault; version="0.0.0"[exported]
org.codehaus.xfire.gen; version="0.0.0"[exported]
org.codehaus.xfire.gen.documentation; version="0.0.0"[exported]
org.codehaus.xfire.gen.jaxb; version="0.0.0"[exported]
org.codehaus.xfire.gen.jsr181; version="0.0.0"[exported]
org.codehaus.xfire.gen.xmlbeans; version="0.0.0"[exported]
org.codehaus.xfire.handler; version="0.0.0"[exported]
org.codehaus.xfire.jaxb; version="0.0.0"[exported]
org.codehaus.xfire.jaxb2; version="0.0.0"[exported]
org.codehaus.xfire.jaxws; version="0.0.0"[exported]
org.codehaus.xfire.jaxws.binding; version="0.0.0"[exported]
org.codehaus.xfire.jaxws.gen; version="0.0.0"[exported]
org.codehaus.xfire.jaxws.handler; version="0.0.0"[exported]
org.codehaus.xfire.jaxws.type; version="0.0.0"[exported]
org.codehaus.xfire.jibx; version="0.0.0"[exported]
org.codehaus.xfire.loom; version="0.0.0"[exported]
org.codehaus.xfire.loom.transport; version="0.0.0"[exported]
org.codehaus.xfire.loom.type; version="0.0.0"[exported]
org.codehaus.xfire.picocontainer; version="0.0.0"[exported]
org.codehaus.xfire.picocontainer.test; version="0.0.0"[exported]
org.codehaus.xfire.picocontainer.util; version="0.0.0"[exported]
org.codehaus.xfire.plexus; version="0.0.0"[exported]
org.codehaus.xfire.plexus.config; version="0.0.0"[exported]
org.codehaus.xfire.plexus.transport; version="0.0.0"[exported]
org.codehaus.xfire.plexus.transport.xmpp; version="0.0.0"[exported]
org.codehaus.xfire.plexus.type; version="0.0.0"[exported]
org.codehaus.xfire.security.wss4j; version="0.0.0"[exported]
org.codehaus.xfire.security.wss4j.crypto; version="0.0.0"[exported]
org.codehaus.xfire.server; version="0.0.0"[exported]
org.codehaus.xfire.server.http; version="0.0.0"[exported]
org.codehaus.xfire.service; version="0.0.0"[exported]
org.codehaus.xfire.service.binding; version="0.0.0"[exported]
org.codehaus.xfire.service.documentation; version="0.0.0"[exported]
org.codehaus.xfire.service.event; version="0.0.0"[exported]
org.codehaus.xfire.service.invoker; version="0.0.0"[exported]
org.codehaus.xfire.soap; version="0.0.0"[exported]
org.codehaus.xfire.soap.handler; version="0.0.0"[exported]
org.codehaus.xfire.spring; version="0.0.0"[exported]
org.codehaus.xfire.spring.config; version="0.0.0"[exported]
org.codehaus.xfire.spring.editors; version="0.0.0"[exported]
org.codehaus.xfire.spring.remoting; version="0.0.0"[exported]
org.codehaus.xfire.transport; version="0.0.0"[exported]
org.codehaus.xfire.transport.dead; version="0.0.0"[exported]
org.codehaus.xfire.transport.http; version="0.0.0"[exported]
org.codehaus.xfire.transport.jms; version="0.0.0"[exported]
org.codehaus.xfire.transport.local; version="0.0.0"[exported]
org.codehaus.xfire.util; version="0.0.0"[exported]
org.codehaus.xfire.util.date; version="0.0.0"[exported]
org.codehaus.xfire.util.dom; version="0.0.0"[exported]
org.codehaus.xfire.util.factory; version="0.0.0"[exported]
org.codehaus.xfire.util.jdom; version="0.0.0"[exported]
org.codehaus.xfire.util.stax; version="0.0.0"[exported]
org.codehaus.xfire.wsdl; version="0.0.0"[exported]
org.codehaus.xfire.wsdl11; version="0.0.0"[exported]
org.codehaus.xfire.wsdl11.builder; version="0.0.0"[exported]
org.codehaus.xfire.wsdl11.parser; version="0.0.0"[exported]
org.codehaus.xfire.xmlbeans; version="0.0.0"[exported]
org.codehaus.xfire.xmpp; version="0.0.0"[exported]
Imported packages
org.osgi.framework; version="1.3.0"<System Bundle [0]>
version="0.0.0"<initial@reference:file:../../export/home/mordox/xfire
stuff/workspace/XFireBasicHTTP/ [31]>
org.codehaus.stax2;
org.codehaus.xfire;
No fragment bundles
Named class space
XFireBasicHTTP; bundle-version="1.0.0"[provided]
No required bundles
osgi>
osgi>
osgi>
osgi>
osgi>
osgi>
osgi>
osgi>
osgi> bundle 34
stuff/workspace/XFireBasicProduction/ [34]
Id=34, Status=RESOLVED Data Root=/export/home/mordox/xfire
stuff/workspace/.metadata/.plugins/org.eclipse.pde.core/New_ configuration/org.eclipse.osgi/bundles/34/data
No registered services.
No services in use.
Exported packages
Imported packages
org.codehaus.stax2;
org.codehaus.xfire;
javax.jms;
stuff/workspace/XFireBasicJMS/ [32]>
jmsserver;
service;
stuff/workspace/XFireBasicProduction/ [34]>
No fragment bundles
Named class space
XFireBasicProduction; bundle-version="1.0.0"[provided]
Required bundles
XFireBasicHTTP;
bundle-version="1.0.0"<initial@reference:file:../../export/home/mordox/xfire
XFireBasicJMS;
osgi>
FUDForum. Page generated in 0.03091 seconds
