JavaModelException [message #96644] |
Mon, 23 April 2007 09:39 |
Originally posted by: larsbri.upb.de
I've just started using tptp and in the beginning everything worked fine,
but suddenly i'm getting the following error whenever launching the
profiling of any part of a certain project. I can't remember any changes
I've made and am absolutely clueless to the source of this problem. Though
saying the operation will continue nothing happens except that it's listet
in the Debug-Tab and I can't even delete it from there.
Any help is appreciated.
One of the selected launch delegates has failed.
The Operation will continue
Reason:
org.eclipse.jdt.core.JavaModelException
/test/de [in test] is not on its project's build path
Java Model Exception: Java Model Status [/test/de [in test] is not on its
project's build path]
org.eclipse.jdt.internal.core.JavaElement.newJavaModelExcept ion(JavaElement.java:492)
org.eclipse.jdt.internal.core.PackageFragmentRoot.buildStruc ture(PackageFragmentRoot.java:166)
org.eclipse.jdt.internal.core.Openable.generateInfos(Openabl e.java:229)
at org.eclipse.jdt.internal.core.Openable.openParent(Openable.j ava:420)
org.eclipse.jdt.internal.core.Openable.generateInfos(Openabl e.java:218)
org.eclipse.jdt.internal.core.CompilationUnit.openParent(Com pilationUnit.java:1066)
org.eclipse.jdt.internal.core.JavaElement.openWhenClosed(Jav aElement.java:505)
org.eclipse.jdt.internal.core.JavaElement.getElementInfo(Jav aElement.java:249)
org.eclipse.jdt.internal.core.JavaElement.getElementInfo(Jav aElement.java:235)
org.eclipse.jdt.internal.core.JavaElement.getChildren(JavaEl ement.java:190)
org.eclipse.jdt.internal.core.JavaElement.getChildrenOfType( JavaElement.java:204)
org.eclipse.jdt.internal.core.CompilationUnit.getTypes(Compi lationUnit.java:844)
org.eclipse.jdt.internal.core.CompilationUnit.getAllTypes(Co mpilationUnit.java:562)
org.eclipse.hyades.trace.ui.internal.util.WorkspaceFiltersEx tractor.addCompilationUnitFilters(WorkspaceFiltersExtractor. java:154)
org.eclipse.hyades.trace.ui.internal.util.WorkspaceFiltersEx tractor.addJavaElementFilter(WorkspaceFiltersExtractor.java: 113)
org.eclipse.hyades.trace.ui.internal.util.WorkspaceFiltersEx tractor.addFileFilters(WorkspaceFiltersExtractor.java:95)
org.eclipse.hyades.trace.ui.internal.util.WorkspaceFiltersEx tractor.addResourceFilters(WorkspaceFiltersExtractor.java:77 )
org.eclipse.hyades.trace.ui.internal.util.WorkspaceFiltersEx tractor.addFolderFilters(WorkspaceFiltersExtractor.java:86)
org.eclipse.hyades.trace.ui.internal.util.WorkspaceFiltersEx tractor.addResourceFilters(WorkspaceFiltersExtractor.java:79 )
org.eclipse.hyades.trace.ui.internal.util.WorkspaceFiltersEx tractor.addProjectFilters(WorkspaceFiltersExtractor.java:68)
org.eclipse.hyades.trace.ui.internal.util.WorkspaceFiltersEx tractor.extractFilters(WorkspaceFiltersExtractor.java:40)
org.eclipse.tptp.trace.ui.provisional.launcher.AbstractProce ssLauncher.getLaunchTypeWorkspaceFilters(AbstractProcessLaun cher.java:407)
org.eclipse.tptp.trace.ui.provisional.launcher.AbstractProce ssLauncher.preLaunch(AbstractProcessLauncher.java:118)
org.eclipse.tptp.trace.ui.internal.launcher.deleg.applicatio n.PIJavaLauncherDelegate.preLaunch(PIJavaLauncherDelegate.ja va:37)
org.eclipse.tptp.trace.ui.internal.launcher.core.LauncherUti lity.delegateInit(LauncherUtility.java:1163)
org.eclipse.tptp.trace.ui.provisional.launcher.PrimaryLaunch Delegate.run(PrimaryLaunchDelegate.java:188)
at java.lang.Thread.run(Unknown Source)
Re: JavaModelException [message #97100 is a reply to message #96644] |
Thu, 26 April 2007 08:15 |
The problem still exists but I've been able to find the change from
working to not working.
After starting from a fresh eclipse and project everything's been working
again. So I've restarted doing all the changes I've made before step by
step.
All I needed to do was opening the filter set and then finishing it
without making any changes.
Any clue to where to look would be appreciated.
Re: JavaModelException [message #98798 is a reply to message #96644] |
Wed, 16 May 2007 16:17 |
Originally posted by: kgilmer.gmail.com
I'm getting this error as well when trying to profile a java program
that happens to be an OSGi framework (not equinox). Any ideas to a
resolution or workaround?
thanks
ken
Lars Brinkmann wrote:
> Hi, I've just started using tptp and in the beginning everything worked
> fine, but suddenly i'm getting the following error whenever launching
> the profiling of any part of a certain project. I can't remember any
> changes I've made and am absolutely clueless to the source of this
> problem. Though saying the operation will continue nothing happens
> except that it's listet in the Debug-Tab and I can't even delete it from
> there.
> Reason:
> its project's build path]
> at
> at
> at org.eclipse.jdt.internal.core.Openable.generateInfos(Openabl e.java:229)
> at org.eclipse.jdt.internal.core.Openable.generateInfos(Openabl e.java:218)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
SOLVED: JavaModelException [message #98813 is a reply to message #98798] |
Wed, 16 May 2007 18:08 |
While I do not know why this is happening, creating a new (Java) project
with the same sources as the project with the error resolves my issue.
-Ken
> thanks
> ken
>> worked fine, but suddenly i'm getting the following error whenever
>> launching the profiling of any part of a certain project. I can't
>> remember any changes I've made and am absolutely clueless to the
>> source of this problem. Though saying the operation will continue
>> nothing happens except that it's listet in the Debug-Tab and I can't
>> Reason:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
FUDForum. Page generated in 0.03390 seconds
