Home » Archived » Test and Performance Tools Platform (TPTP) » java.lang.NoClassDefFoundError: <my main class>
java.lang.NoClassDefFoundError: <my main class> [message #94669] |
Fri, 30 March 2007 22:05 |
Originally posted by: jim.marshall.wbemsolutions.com
I just downloaded the all-in-one package. I moved my original Eclipse
install and then unzipped the all-in-one package. Eclipse starts up and
I can debug my application in Eclipse with no problem. But when I select
the profile option I get a "java.lang.NoClassDefFoundError" for my
projects main class.
I am using:
java version "1.5.0_11"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_11-b03)
Java HotSpot(TM) Client VM (build 1.5.0_11-b03, mixed mode)
I am using "Java Profiling", and I am not using the "Agent Discoverer"
(although I tried turning that on and it did not help).
The "Java Profiling with Instrumentation" gives me an error when I click
on the "Test Availability" - "Error: Unable to connect to the Agent
Controller.Connection refused: connect" (I have installed both
jvmti-client-TPTP-4.3.1.zip & javaprofiler.win_ia32-TPTP-4.3.1.zip)
Any help appreciated.
config details:
*** Date: Fri Mar 30 18:04:39 EDT 2007
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.buildId=M20070212-1330
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-launcher
C:\Java\eclipse\eclipse.exe
-name
Eclipse
-showsplash
600
-exitdata
2598_784
-vm
C:\WINDOWS\system32\javaw.exe
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1175292162993
eclipse.vm=C:\WINDOWS\system32\javaw.exe
eclipse.vmargs=-Xms40m
-Xmx256m
-jar
C:\Java\eclipse\startup.jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\Java\eclipse\startup.jar
java.class.version=49.0
java.endorsed.dirs=C:\Program Files\Java\jre1.5.0_11\lib\endorsed
java.ext.dirs=C:\Program Files\Java\jre1.5.0_11\lib\ext
java.home=C:\Program Files\Java\jre1.5.0_11
java.io.tmpdir=C:\DOCUME~1\jmars\LOCALS~1\Temp\
java.library.path=C:\WINDOWS\system32;.;C:\WINDOWS\system32; C:\WINDOWS;c:\cygwin\home\jmars\wbem\wsi\proto\lib\windows;c :\cygwin\home\jmars\wbem\wsi\proto\server\jserver\lib;C:\WIN DOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program
Files\ATI Technologies\ATI.ACE\;C:\Program Files\Microsoft SQL
Server\80\Tools\Binn\;c:\cygwin\home\jmars\wbem\contracts\ne tapp\proto\server\cserver\naprov
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_11-b03
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_11
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_11-b03
line.separator=
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5
org.osgi.framework.language=en
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth.login,ja vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sampled,java
x.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.row set.serial,javax.sql.rowset.spi,javax.swing,javax.swing.bord er,javax.swing.colorchooser,javax.swing.event,javax.swing.fi lechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swin g.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.synth,j avax.swing.table,javax.swing.text,javax.swing.text.html,java x.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tr ee,javax.swing.undo,javax.transaction,javax.transaction.xa,j avax.xml,javax.xml.datatype,javax.xml.namespace,javax.xml.pa rsers,javax.xml.transform,javax.xml.transform.dom,javax.xml. transform.sax,javax.xml.transform.stream,javax.xml.validatio n,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_ 2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,o rg.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA .TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingC ontextExtPackage,org.omg.CosNaming.NamingContextPackage,org. omg.Dynamic,org.omg.DynamicAny
,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny. DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,or g.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInt erceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org. omg.PortableServer,org.omg.PortableServer.CurrentPackage,org .omg.PortableServer.POAManagerPackage,org.omg.PortableServer .POAPackage,org.omg.PortableServer.portable,org.omg.Portable Server.ServantLocatorPackage,org.omg.SendingContext,org.omg. stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom. events,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sa x.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.equinox.common@2:start,
org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=C:\Java\eclipse\configuration\org.eclipse.o sgi\bundles
osgi.configuration.area=file:/C:/Java/eclipse/configuration/
osgi.framework=file:/c:/Java/eclipse/plugins/org.eclipse.osg i_3.2.2.R32x_v20070118.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.2.2.R32x_v20070118
osgi.install.area=file:/C:/Java/eclipse/
osgi.instance.area=file:/C:/Documents and Settings/jmars/workspace-wbem/
osgi.instance.area.default=file:/C:/Documents and Settings/jmars/workspace/
osgi.logfile=C:\Documents and Settings\jmars\workspace-wbem\.metadata\.log
osgi.manifest.cache=C:\Java\eclipse\configuration\org.eclips e.osgi\manifests
osgi.nl=en_US
osgi.os=win32
osgi.splashLocation=c:\Java\eclipse\plugins\org.eclipse.plat form_3.2.2.r322_v20070117b\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=c:\Java\eclipse\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program
Files\Java\jre1.5.0_11\lib\rt.jar;C:\Program
Files\Java\jre1.5.0_11\lib\i18n.jar;C:\Program
Files\Java\jre1.5.0_11\lib\sunrsasign.jar;C:\Program
Files\Java\jre1.5.0_11\lib\jsse.jar;C:\Program
Files\Java\jre1.5.0_11\lib\jce.jar;C:\Program
Files\Java\jre1.5.0_11\lib\charsets.jar;C:\Program
Files\Java\jre1.5.0_11\classes
sun.boot.library.path=C:\Program Files\Java\jre1.5.0_11\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486
i386 i86
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.java.launcher=SUN_STANDARD
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 2
user.country=US
user.dir=C:\cygwin\home\jmars\wbem\wsi\proto\server\jserver\ bin
user.home=C:\Documents and Settings\jmars
user.language=en
user.name=jmars
user.timezone=America/New_York
user.variant=
*** Features:
org.apache.batik (1.6.0.v20060613-1220-0842282835-3442) "Apache Batik"
org.apache.batik.pdf (1.6.0.v20060613-1220-0842282835-3442) "Apache
Batik Pdf"
org.eclipse.emf (2.2.2.v200702131851) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.ecore.sdo (2.2.1.v200702131851) "EMF Service Data
Objects (SDO)"
org.eclipse.jdt (3.2.2.r322_v20070104-R4CR0Znkvtfjv9-) "Eclipse Java
Development Tools"
org.eclipse.jdt.source (3.2.2.r322_v20070104-R4CR0Znkvtfjv9-) "Eclipse
Java Development Tools SDK"
org.eclipse.pde (3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG) "Eclipse Plug-in
Development Environment"
org.eclipse.pde.source (3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG) "Eclipse
Plug-in Development Environment Developer Resources"
org.eclipse.platform (3.2.2.r322_v20070119-RQghndJN8IM0MsK) "Eclipse
Platform"
org.eclipse.platform.source (3.2.2.r322_v20070119-RQghndJN8IM0MsK)
"Eclipse Platform Plug-in Developer Resources"
org.eclipse.rcp (3.2.2.r322_v20070104-8pcviKVqd8J7C1U) "Eclipse RCP"
org.eclipse.rcp.source (3.2.2.r322_v20070104-8pcviKVqd8J7C1U) "Eclipse
RCP Plug-in Developer Resources"
org.eclipse.sdk (3.2.2.r322_v20070104-dCGKm0Ln38lm-8s) "Eclipse Project SDK"
org.eclipse.tptp.monitoring (4.3.1.v200701300931--9FhPQISnZuUufv) "TPTP
Monitoring"
org.eclipse.tptp.monitoring.doc.user
(4.3.0.v200610310100--1G955G767A5755) "TPTP Monitoring Project
Documentation"
org.eclipse.tptp.monitoring.examples
(4.3.0.v200610310100--08422832432322) "User examples for the TPTP
Monitoring Tools Plugins"
org.eclipse.tptp.monitoring.la.core
(4.3.0.v200608310100--2PD88PAA_H8A88) "Monitoring Common Service Plug-in"
org.eclipse.tptp.monitoring.managedagent
(4.3.0.v200610260100--3YIAAYEEEQAEAA) "Managed Agent Plugin"
org.eclipse.tptp.monitoring.managedagent.agents
(4.3.0.v200610260100--08422833362322) "JMX Managed Agent"
org.eclipse.tptp.platform.analysis (4.3.0.v200611060100--3YIAAYDGHSBIBJ)
"TPTP Analysis"
org.eclipse.tptp.platform.analysis.codereview.java
(4.3.0.v200610240100--1G955G759I5755) "Java Code Review Plug-in"
org.eclipse.tptp.platform.analysis.engine
(4.3.0.v200610310100--1G955G6A896A6D) "TPTP Analysis Engine"
org.eclipse.tptp.platform.core (4.3.1.v200701291655--GFEkmGwH-woGu8)
"TPTP Platform"
org.eclipse.tptp.platform.core.doc.user
(4.3.0.v200609200100--2PD88PAA_M8A88) "TPTP Platform Project Documentation"
org.eclipse.tptp.platform.doc.user (4.3.0.v200610310100-8BlVNIlTXxeHREE)
org.eclipse.tptp.platform.examples (4.3.0.v200610310100--08422832432322)
"TPTP Platform Examples"
org.eclipse.tptp.platform.jvmti (4.2.0.v200606131519--08422833372322)
"TPTP JVMTI Profiler Client"
org.eclipse.tptp.platform.la.core (4.3.0.v200608310100--08422832462322)
"Log Analysis Core"
org.eclipse.tptp.platform.lta (4.3.0.v200610310100--1G955G6B6E6A6D)
"TPTP Log and Trace Analyzer"
org.eclipse.tptp.platform.probekit (4.3.0.v200611040100--3YIAAYCPIOBIBJ)
"TPTP ProbeKit"
org.eclipse.tptp.platform.probekit.doc.user
(4.3.0.v200610310100--08422832532322) "Probekit User Documentation"
org.eclipse.tptp.platform.report (4.2.0.v200611020100--2PD88P9JCE_I_P)
"TPTP Charting Service"
org.eclipse.tptp.platform.samples (4.3.0.v200610310100--2PD88P9JBE_I_P)
"TPTP Platform Samples"
org.eclipse.tptp.platform.statistical.ui
(4.1.200.v200610310100--1G955G6B6D7__J) "TPTP Statistical UI"
org.eclipse.tptp.platform.trace (4.3.0.v200610310100--3YIAAYCQGMBIBJ)
"TPTP Platform Trace"
org.eclipse.tptp.test (4.3.1.v200701291655--4hNDDjFNJgGWOW) "TPTP Test"
org.eclipse.tptp.test.doc.user (4.3.0.v200611020100--08422833372322)
"Test Tools User Documentation"
org.eclipse.tptp.test.samples (4.1.200.v200611020100--08422833252322)
"TPTP Test Samples"
org.eclipse.tptp.test.tools (4.3.1.v200701291655--2PD88Q9FBO_JDL) "TPTP
Test Tools"
org.eclipse.tptp.trace (4.1.200.v200610310100--1G955G6B7C6A6D) "TPTP Trace"
org.eclipse.tptp.trace.jvmti (4.2.0.v200606131519--08422833372322) "TPTP
Trace JVMTI Client"
org.eclipse.xsd (2.2.2.v200702131851) "XML Schema Infoset Model (XSD)"
org.mx4j.jmx (4.3.0.v200610110100--08422833362322) "MX4J"
*** Plug-in Registry:
com.ibm.icu (3.4.5.20061213) "International Components for Unicode for
Java (ICU4J)" [Active]
com.ibm.icu.source (3.4.5.20061213) "International Components for
Unicode for Java (ICU4J) source plug-in" [Resolved]
com.jcraft.jsch (0.1.28) "JSch" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.batik (1.6.0.v20060613-1220) "Apache Batik" [Resolved]
org.apache.batik.pdf (1.6.0.v20060613-1220) "Apache Batik Pdf" [Resolved]
org.apache.commons_logging (1.0.4.v200606131651) "Apache commons logging
Plug-in" [Resolved]
org.apache.jakarta_log4j (1.2.8.v200606131651) "Apache Jakarta log4j
Plug-in" [Resolved]
org.apache.lucene (1.4.103.v20060601) "Apache Lucene" [Resolved]
org.apache.xerces (2.8.0.v200606131651) "Xerces 2.8.0" [Resolved]
org.eclipse.ant.core (3.1.100.v20060531) "Ant Build Tool Core" [Resolved]
org.eclipse.ant.ui (3.2.1.r321_v20060828) "Ant UI" [Resolved]
org.eclipse.compare (3.2.1.M20060711) "Compare Support" [Resolved]
org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Resolved]
org.eclipse.core.commands (3.2.0.I20060605-1400) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.0.v20060603) "Eclipse Content
Mechanism" [Active]
org.eclipse.core.expressions (3.2.2.r322_v20070109a) "Expression
Language" [Active]
org.eclipse.core.filebuffers (3.2.1.r321_v20060721) "File Buffers" [Active]
org.eclipse.core.filesystem (1.0.0.v20060603) "Core File Systems" [Resolved]
org.eclipse.core.filesystem.win32.x86 (1.0.0.v20060603) "Core File
System for Windows" [Resolved]
org.eclipse.core.jobs (3.2.0.v20060603) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.resources (3.2.2.R32x_v20061218) "Core Resource
Management" [Active]
org.eclipse.core.resources.compatibility (3.2.0.v20060603) "Core
Resource Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.2.0.v20060603) "Core Resource
Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.2.0.v20060603) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.100.v20060603) "Core Runtime
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.0.v20060601)
"Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.1.R32x_v20060907)
"Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.1.100.v20060605) "Core Variables" [Active]
org.eclipse.debug.core (3.2.1.v20060823) "Debug Core" [Active]
org.eclipse.debug.ui (3.2.2.r322_v20070202) "Debug UI" [Active]
org.eclipse.emf (2.2.0.v200702131851) "Eclipse Modeling Framework (EMF)"
[Resolved]
org.eclipse.emf.ant (2.2.0.v200702131851) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.codegen (2.2.2.v200702131851) "EMF Template Code
Generator" [Resolved]
org.eclipse.emf.codegen.ecore (2.2.2.v200702131851) "EMF Ecore Code
Generation" [Resolved]
org.eclipse.emf.codegen.ecore.ui (2.2.1.v200702131851) "EMF Ecore Code
Generation UI" [Resolved]
org.eclipse.emf.codegen.ui (2.1.0.v200702131851) "EMF Template Code
Generator UI" [Resolved]
org.eclipse.emf.common (2.2.1.v200702131851) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.2.1.v200702131851) "EMF Common UI" [Resolved]
org.eclipse.emf.commonj.sdo (2.1.0.v200702131851) "CommonJ SDO" [Resolved]
org.eclipse.emf.converter (2.2.1.v200702131851) "EMF Model Convert
Support" [Resolved]
org.eclipse.emf.ecore (2.2.2.v200702131851) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.2.1.v200702131851) "EMF Ecore Change
Model" [Resolved]
org.eclipse.emf.ecore.change.edit (2.2.0.v200702131851) "EMF Ecore
Change Edit Support" [Resolved]
org.eclipse.emf.ecore.edit (2.2.0.v200702131851) "EMF Ecore Edit
Support" [Resolved]
org.eclipse.emf.ecore.editor (2.2.0.v200702131851) "Sample Ecore Editor"
[Resolved]
Objects (SDO)" [Resolved]
org.eclipse.emf.ecore.sdo.edit (2.2.0.v200702131851) "EMF Service Data
Objects (SDO) Edit Support" [Resolved]
org.eclipse.emf.ecore.sdo.editor (2.2.0.v200702131851) "EMF Service Data
Objects (SDO) Editor" [Resolved]
org.eclipse.emf.ecore.xmi (2.2.2.v200702131851) "EMF XMI" [Active]
org.eclipse.emf.edit (2.2.2.v200702131851) "EMF Edit" [Resolved]
org.eclipse.emf.edit.ui (2.2.1.v200702131851) "EMF Edit UI" [Resolved]
org.eclipse.emf.exporter (2.2.0.v200702131851) "EMF Model Export
Support" [Resolved]
org.eclipse.emf.importer (2.2.2.v200702131851) "EMF Model Import
Support" [Resolved]
org.eclipse.emf.importer.ecore (2.2.0.v200702131851) "EMF Ecore
Importer" [Resolved]
org.eclipse.emf.importer.java (2.2.1.v200702131851) "EMF Annotated Java
org.eclipse.emf.importer.rose (2.2.0.v200702131851) "EMF Rose Importer"
[Resolved]
org.eclipse.emf.mapping (2.2.0.v200702131851) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.2.0.v200702131851) "Ecore to
Ecore Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.2.0.v200702131851) "Ecore
to Ecore Mapping Editor" [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.2.0.v200702131851) "Ecore to XML
Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.2.0.v200702131851) "Ecore to XML
Mapping UI" [Resolved]
org.eclipse.emf.mapping.ui (2.2.1.v200702131851) "EMF Mapping UI" [Resolved]
org.eclipse.emf.mapping.xsd2ecore (2.1.0.v200702131851) "XSD to Ecore
Mapping" [Resolved]
org.eclipse.emf.mapping.xsd2ecore.editor (2.1.0.v200702131851) "XSD to
org.eclipse.equinox.common (3.2.0.v20060603) "Common Eclipse Runtime"
[Active]
org.eclipse.equinox.preferences (3.2.1.R32x_v20060717) "Eclipse
Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.2.1.R32x_v20060814) "Extension Registry
Support" [Active]
org.eclipse.help (3.2.2.R322_v20061213) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.100.v20060602) "Help Application Server"
[Resolved]
org.eclipse.help.base (3.2.2.R322_v20061207) "Help System Base" [Resolved]
org.eclipse.help.ui (3.2.0.v20060602) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.2.2.R322_v20061114) "Help System Webapp"
[Resolved]
org.eclipse.hyades.analysis.engine (4.3.0.v200610210100) "Symptom Model"
[Resolved]
org.eclipse.hyades.execution (4.3.1.v200702221346) "TPTP Platform
Execution Plug-In" [Active]
org.eclipse.hyades.execution.correlation (4.1.200.v200610280100) "Hyades
Runtime Correlation Engine" [Resolved]
org.eclipse.hyades.execution.trace (4.1.100.v200606131519) "Hyades
Execution Trace" [Resolved]
org.eclipse.hyades.execution.win32.x86 (4.3.0.v200611140100) "TPTP
Platform Execution Plug-In" [Resolved]
org.eclipse.hyades.logging.adapter (4.3.0.v200611140100) "TPTP
Monitoring Project Generic Log Adapter" [Resolved]
org.eclipse.hyades.logging.adapter.ui (4.3.0.v200610210100) "Generic
Adapter UI" [Resolved]
org.eclipse.hyades.logging.core (4.3.0.v200609190100) "Hyades Logging
Agent, Common Base Events and Logging Facility Support" [Resolved]
org.eclipse.hyades.logging.core.sample (4.1.100.v200606131519) "Sample
for Hyades Logging Agent, Common Base Events and Logging Facility
Support" [Resolved]
org.eclipse.hyades.logging.parsers (4.3.0.v200611020100) "TPTP
Monitoring Project Log File Parsers" [Resolved]
org.eclipse.hyades.perfmon (4.2.0.v200606131519) "Perfmon StatCon
Module" [Resolved]
org.eclipse.hyades.probekit (4.2.100.v200609190100) "Hyades Probekit"
[Active]
org.eclipse.hyades.probekit.doc.user (4.2.0.v200610310100) "Probekit
User Documentation" [Resolved]
org.eclipse.hyades.probekit.ui (4.1.200.v200610310100) "Probe Editor"
[Resolved]
org.eclipse.hyades.resources.database (4.2.0.v200611040100) "Hyades Core
Resource Extensions" [Resolved]
org.eclipse.hyades.sdb (4.2.1.v200701300931) "Symptom Database tool"
[Resolved]
org.eclipse.hyades.statistical.ui (4.2.100.v200611061046) "Statistical
UI" [Active]
org.eclipse.hyades.test.core (4.2.101.v200701291655) "TPTP Test Core
Plug-In" [Resolved]
org.eclipse.hyades.test.doc.user (4.2.0.v200611150100) "Test Tools User
org.eclipse.hyades.test.tools.core (4.3.1.v200701291655) "TPTP Test
Tools Core Plug-In" [Resolved]
org.eclipse.hyades.test.tools.ui (4.3.0.v200611150100) "TPTP Test Tools
UI Plug-In" [Resolved]
org.eclipse.hyades.test.ui (4.2.101.v200701291655) "TPTP Test UI
Plug-In" [Resolved]
org.eclipse.hyades.test.ui.extensions (4.2.100.v200611030100) "TPTP Test
UI Extension Plug-In" [Resolved]
org.eclipse.hyades.trace.sample (4.1.100.v200606131519) "Samples for the
TPTP Monitoring Tools Plugins" [Resolved]
org.eclipse.hyades.trace.ui (4.3.0.v200611070100) "Hyades Trace Core UI"
[Active]
org.eclipse.hyades.trace.views (4.1.200.v200611150100) "Hyades Trace
Views Plugin" [Resolved]
org.eclipse.hyades.ui (4.2.0.v200611040100) "Hyades UI" [Resolved]
org.eclipse.jdt (3.2.1.r321_v20060823) "Eclipse Java Development Tools"
[Resolved]
org.eclipse.jdt.apt.core (3.2.1.R32x_v20060822-2100) "Java Annotation
Processing Core" [Active]
org.eclipse.jdt.apt.ui (3.2.1.R32x_v20060822-2100) "Java Annotation
Processing UI" [Resolved]
org.eclipse.jdt.core (3.2.3.v_686_R32x) "Java Development Tools Core"
[Active]
org.eclipse.jdt.core.manipulation (1.0.1.r321_v20060721) "Java Code
Manipulation Functionality" [Resolved]
org.eclipse.jdt.debug (3.2.2.r322_v20070130) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.2.2.r322_v20061205) "JDI Debug UI" [Active]
org.eclipse.jdt.doc.isv (3.2.1.r322_v20070109) "Eclipse JDT Plug-in
Developer Guide" [Resolved]
org.eclipse.jdt.doc.user (3.2.0.v20060605-1400) "Eclipse Java
Development User Guide" [Resolved]
org.eclipse.jdt.junit (3.2.1.r321_v20060810) "Java Development Tools
JUnit support" [Resolved]
org.eclipse.jdt.junit.runtime (3.2.1.r321_v20060721) "Java Development
Tools JUnit runtime support" [Resolved]
org.eclipse.jdt.junit4.runtime (1.0.1.r321_v20060905) "Java Development
Tools JUnit4 runtime support" [Resolved]
org.eclipse.jdt.launching (3.2.2.r322_v20061114) "Java Development Tools
Launching Support" [Active]
Java Development Tools SDK" [Resolved]
org.eclipse.jdt.ui (3.2.2.r322_v20070124) "Java Development Tools UI"
[Active]
org.eclipse.jface (3.2.2.M20061214-1200) "JFace" [Resolved]
org.eclipse.jface.databinding (1.0.0.I20060605-1400) "JFace Data
Binding" [Resolved]
org.eclipse.jface.text (3.2.2.r322_v20070104) "JFace Text" [Resolved]
org.eclipse.ltk.core.refactoring (3.2.1.r321_v20060823) "Refactoring
Core" [Active]
org.eclipse.ltk.ui.refactoring (3.2.2.r322_v20070124) "Refactoring UI"
[Active]
org.eclipse.osgi.services (3.1.100.v20060601) "OSGi Release 3 Services"
[Resolved]
org.eclipse.osgi.util (3.1.100.v20060601) "OSGi R3 Utility Classes"
[Resolved]
org.eclipse.pde (3.2.1.v20060810-0800) "Eclipse Plug-in Development
Environment" [Resolved]
org.eclipse.pde.build (3.2.1.r321_v20060823) "Plug-in Development
Environment Build Support" [Resolved]
org.eclipse.pde.core (3.2.1.v20060915-0800) "Plug-in Development Core"
[Resolved]
org.eclipse.pde.doc.user (3.2.1.v20060816-0800) "Eclipse Plug-in
org.eclipse.pde.junit.runtime (3.2.0.v20060605) "PDE JUnit Plug-in Test"
[Resolved]
org.eclipse.pde.runtime (3.2.0.v20060605) "Plug-in Development
Environment Runtime" [Resolved]
Plug-in Development Environment Developer Resources" [Resolved]
org.eclipse.pde.ui (3.2.1.v20060816-0800) "Plug-in Development UI"
[Resolved]
org.eclipse.platform (3.2.2.r322_v20070117b) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.isv (3.2.2.R32x_v20070115) "Eclipse Platform
Plug-in Developer Guide" [Resolved]
org.eclipse.platform.doc.user (3.2.1.R32x_v200608101155) "Eclipse
Workbench User Guide" [Resolved]
"Eclipse Platform Plug-in Developer Resources" [Resolved]
org.eclipse.platform.source.win32.win32.x86
(3.2.2.r322_v20070119-RQghndJN8IM0MsK) "Eclipse Platform Plug-in
org.eclipse.rcp (3.2.0.v20060605) "Eclipse RCP" [Resolved]
RCP Plug-in Developer Resources" [Resolved]
org.eclipse.rcp.source.win32.win32.x86
(3.2.2.r322_v20070104-8pcviKVqd8J7C1U) "Eclipse RCP Plug-in Developer
org.eclipse.sdk (3.2.2.r322_v20070212) "Eclipse Project SDK" [Resolved]
org.eclipse.search (3.2.1.r321_v20060726) "Search Support" [Resolved]
org.eclipse.swt (3.2.2.v3236b) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.2.2.v3236) "Standard Widget Toolkit
org.eclipse.team.core (3.2.2.M20061114) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.2.2.M20061205) "CVS Team Provider Core"
[Resolved]
org.eclipse.team.cvs.ssh (3.2.1.M20061205) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.2.1.M20061205) "CVS SSH2" [Resolved]
org.eclipse.team.cvs.ui (3.2.2.M20061121) "CVS Team Provider UI" [Resolved]
org.eclipse.team.ui (3.2.1.M200608151725) "Team Support UI" [Resolved]
org.eclipse.text (3.2.0.v20060605-1400) "Text" [Resolved]
org.eclipse.tomcat (4.1.130.v20060601) "Tomcat Wrapper" [Resolved]
org.eclipse.tptp.monitoring (4.1.100.v200606131519) "TPTP Monitoring"
[Resolved]
org.eclipse.tptp.monitoring.doc.user (4.2.100.v200611020100) "TPTP
Monitoring Project Documentation" [Resolved]
org.eclipse.tptp.monitoring.examples (4.3.0.v200610210100) "User
examples for the TPTP Monitoring Tools Plugins" [Resolved]
org.eclipse.tptp.monitoring.la.core (4.3.0.v200611140100) "Monitoring
Common Service Plug-in" [Resolved]
org.eclipse.tptp.monitoring.logui (4.3.1.v200702091252) "Logui Plug-in"
[Resolved]
org.eclipse.tptp.monitoring.managedagent (4.3.0.v200611140100) "Managed
Agent Plugin" [Active]
org.eclipse.tptp.monitoring.managedagent.doc.user (4.3.0.v200611140100)
"Managed Agent Documentation Plugin" [Resolved]
org.eclipse.tptp.monitoring.managedagent.jmx (4.3.0.v200611140100) "JMX
Managed Agent" [Active]
org.eclipse.tptp.monitoring.managedagent.ui (4.3.0.v200611140100)
"Managed Agent UI Plugin" [Active]
org.eclipse.tptp.monitoring.notifications (4.3.0.v200611140100)
"WS-Notifications Provider Plug-in" [Active]
org.eclipse.tptp.monitoring.symptom.doc.user (4.3.0.v200610240100) "TPTP
Monitoring Symptom Database Documentation" [Resolved]
org.eclipse.tptp.monitoring.symptom.editor (4.3.1.v200702091252)
"Symptom editor plug-in" [Resolved]
org.eclipse.tptp.platform.agentcontroller (4.1.101.v200701300931) "TPTP
Agent Controller" [Resolved]
org.eclipse.tptp.platform.agentcontroller.doc.user
(4.2.100.v200611140100) "Agent Controller documentation" [Resolved]
org.eclipse.tptp.platform.analysis (4.1.100.v200606131519) "TPTP
Analysis" [Resolved]
org.eclipse.tptp.platform.analysis.codereview.java (4.3.0.v200610270100)
"Java Code Review Plug-in" [Resolved]
org.eclipse.tptp.platform.analysis.codereview.java.rules
(4.3.0.v200610270100) "Java Code Review Rules Plug-in" [Resolved]
org.eclipse.tptp.platform.analysis.core (4.3.0.v200610240100) "TPTP
Analysis Framework Core Plug-in" [Resolved]
org.eclipse.tptp.platform.analysis.core.ui (4.3.0.v200610240100) "Static
Analysis User Interface Plug-in" [Resolved]
org.eclipse.tptp.platform.analysis.core.ui.doc (4.2.100.v200610270100)
"Analysis run cofiguration online help" [Resolved]
org.eclipse.tptp.platform.analysis.engine (4.1.100.v200606131519) "TPTP
Analysis Engine" [Resolved]
org.eclipse.tptp.platform.collection.framework (4.2.0.v200611140100)
"TPTP Collection Framework" [Resolved]
org.eclipse.tptp.platform.common (4.3.0.v200611070100) "TPTP Common
Plug-in" [Active]
org.eclipse.tptp.platform.common.ui (4.3.0.v200611070100) "TPTP Common
UI Plug-in" [Active]
org.eclipse.tptp.platform.common.ui.trace (4.3.0.v200610310100) "TPTP
Common UI Trace Plug-in" [Active]
org.eclipse.tptp.platform.core (4.1.100.v200606131519) "TPTP Platform"
[Resolved]
org.eclipse.tptp.platform.doc.user (4.2.0.v200611150100) "TPTP Platform
org.eclipse.tptp.platform.examples (4.3.0.v200610210100) "TPTP Platform
Examples" [Resolved]
org.eclipse.tptp.platform.execution (4.3.0.v200611080100) "TPTP Core
Platform (Provisional)" [Resolved]
org.eclipse.tptp.platform.jvmti.client (4.2.0.v200611150100) "TPTP JVMTI
Profiler Client" [Active]
org.eclipse.tptp.platform.la.core (4.3.0.v200610240100) "Log Analysis
Core" [Resolved]
org.eclipse.tptp.platform.log.doc.user (4.3.0.v200611060100) "TPTP
Platform Log Documentation" [Resolved]
org.eclipse.tptp.platform.log.views (4.3.0.v200611070100) "Hyades Log
UI" [Resolved]
org.eclipse.tptp.platform.logging.events (4.3.0.v200611140100) "Common
Base Events" [Resolved]
org.eclipse.tptp.platform.lta (4.1.100.v200606131519) "TPTP Log and
Trace Analyzer" [Resolved]
org.eclipse.tptp.platform.models (4.2.100.v200611140100) "Hyades Models"
[Active]
org.eclipse.tptp.platform.probekit (4.1.100.v200606131519) "TPTP
ProbeKit" [Resolved]
org.eclipse.tptp.platform.probekit.launch (4.3.0.v200609210100)
"Probekit Launch Configuration" [Active]
org.eclipse.tptp.platform.report (4.1.100.v200606131519) "TPTP Charting
Service" [Resolved]
org.eclipse.tptp.platform.report.core (4.2.0.v200610310100) "TPTP Report
org.eclipse.tptp.platform.report.ui (4.1.100.v200606131519) "TPTP Report
UI" [Resolved]
org.eclipse.tptp.platform.samples (4.1.100.v200606131519) "TPTP Platform
Samples" [Resolved]
org.eclipse.tptp.platform.statistical.ui (4.1.100.v200606131519) "TPTP
Statistical UI" [Resolved]
org.eclipse.tptp.platform.trace (4.1.100.v200606131519) "TPTP Platform
Trace" [Resolved]
org.eclipse.tptp.test (4.1.100.v200606131519) "TPTP Test" [Resolved]
org.eclipse.tptp.test.samples (4.1.200.v200611030100) "TPTP Test
Samples" [Resolved]
org.eclipse.tptp.test.tools (4.1.100.v200606131519) "TPTP Test Tools"
[Resolved]
org.eclipse.tptp.trace (4.1.100.v200606131519) "TPTP Trace" [Resolved]
org.eclipse.tptp.trace.jvmti.client (4.2.0.v200611150100) "TPTP Trace
JVMTI Client" [Resolved]
org.eclipse.ui (3.2.1.M20061108) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.0.v20060602) "Browser Support" [Resolved]
org.eclipse.ui.cheatsheets (3.2.1.R321_v20060720) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.100.v20060605) "Console" [Active]
org.eclipse.ui.editors (3.2.1.r321_v20060721) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.101.r321_v20060802) "External Tools"
[Active]
org.eclipse.ui.forms (3.2.0.v20060602) "Eclipse Forms" [Resolved]
org.eclipse.ui.ide (3.2.1.M20060915-1030) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.2.2.R322_v20061214) "Welcome Framework" [Resolved]
org.eclipse.ui.intro.universal (3.2.1.R321_v20060905) "Universal
Welcome" [Resolved]
org.eclipse.ui.navigator (3.2.1.M20060913-0800) "Common Navigator View"
[Resolved]
org.eclipse.ui.navigator.resources (3.2.1.M20060906-0800b) "Navigator
Workbench Components" [Resolved]
org.eclipse.ui.presentations.r21 (3.2.0.I20060605-1400) "R21
Presentation Plug-in" [Resolved]
org.eclipse.ui.views (3.2.1.M20060906-0800) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.2.1.M20060830-0800) "Tabbed
Properties View" [Resolved]
org.eclipse.ui.win32 (3.2.0.I20060605-1400) "Eclipse UI Win32
Enhancements" [Resolved]
org.eclipse.ui.workbench (3.2.2.M20070119-0800) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20060605-1400) "Workbench
Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.2.0.v20060605-1400) "Text Editor
Framework" [Active]
org.eclipse.update.configurator (3.2.2.R32x_v20070111) "Install/Update
Configurator" [Active]
org.eclipse.update.core (3.2.3.R32x_v20070118) "Install/Update Core"
[Active]
org.eclipse.update.core.win32 (3.2.2.R32x_v20061214) "Install/Update
Core for Windows" [Resolved]
org.eclipse.update.scheduler (3.2.2.R32x_v20061214) "Automatic Updates
Scheduler" [Active]
org.eclipse.update.ui (3.2.2.R32x_v20070111) "Install/Update UI" [Resolved]
[Resolved]
org.eclipse.xsd.ecore.exporter (2.2.1.v200702131851) "XML Schema
Exporter for EMF" [Resolved]
org.eclipse.xsd.ecore.importer (2.2.0.v200702131851) "XML Schema
Importer for EMF" [Resolved]
org.eclipse.xsd.edit (2.2.1.v200702131851) "XML Schema Edit Framework"
[Resolved]
org.eclipse.xsd.editor (2.2.0.v200702131851) "XML Schema Editor" [Resolved]
org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
org.junit4 (4.1.0.1) "JUnit Testing Framework Version 4" [Resolved]
org.mx4j.jmx (3.0.1.v200611140100) "MX4J" [Resolved]
system.bundle (3.2.2.R32x_v20070118) "OSGi System Bundle" [Active]
*** User Preferences:
#Fri Mar 30 18:04:39 EDT 2007
@org.eclipse.debug.ui=3.2.2.r322_v20070202
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE _HYADES_EXECUTION=C\:\\Java\\eclipse\\plugins\\org.eclipse.h yades.execution_4.3.1.v200702221346\\hexl.jar;C\:\\Java\\ecl ipse\\plugins\\org.eclipse.hyades.execution_4.3.1.v200702221 346\\hexr.jar;C\:\\Java\\eclipse\\plugins\\org.eclipse.hyade s.execution_4.3.1.v200702221346\\tptp-automation-client.jar; C\:\\Java\\eclipse\\plugins\\org.eclipse.hyades.execution_4. 3.1.v200702221346\\tptp-automation-server.jar;C\:\\Java\\ecl ipse\\plugins\\org.eclipse.hyades.execution_4.3.1.v200702221 346\\hexcore.jar;
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ templates= <?xml
version\="1.0" encoding\="UTF-8"?><templates/>
@org.eclipse.ui.ide=3.2.1.M20060915-1030
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launchin g.PREF_VM_XML= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<vmSettings
defaultVM\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 13,1157651466160 "
defaultVMConnector\="">\r\n<vmType
id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\r\n<vm
id\="1157651466160"
javadocURL\="http\://java.sun.com/j2se/1.5.0/docs/api/"
name\="jre1.5.0_06" path\="C\:\\Program
Files\\Java\\jre1.5.0_06"/>\r\n</vmType>\r\n</vmSettings >\r\n
@org.eclipse.pde.core=3.2.1.v20060915-0800
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.unusedLabel=ignore
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.code_te mplates_migrated=true
/instance/org.eclipse.hyades.execution/PATH_ORG_ECLIPSE_HYAD ES_LOGGING_CORE=C\:\\Java\\eclipse\\plugins\\org.eclipse.hya des.logging.core_4.3.0.v200609190100
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE _HYADES_PROBEKIT=C\:\\Java\\eclipse\\plugins\\org.eclipse.hy ades.probekit_4.2.100.v200609190100\\probekit.jar;
/instance/org.eclipse.hyades.ui/filters.filterSelection=Prof ilingAgentScope;Default
Filter\n\norg.eclipse.hyades.trace.views.adapter.internal.Co verageStatisticViewer;ProfilingAgentScope\n
/instance/org.eclipse.debug.ui/pref_state_memento.org.eclips e.debug.ui.ExpressionView= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<VariablesViewMemento
org.eclipse.debug.ui.SASH_DETAILS_PART\="315"
org.eclipse.debug.ui.SASH_VIEW_PART\="684"/>
@org.eclipse.ui.browser=3.2.0.v20060602
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE _HYADES_PERFMON_AGENTS=;%CUSTOMPATH_ORG_ECLIPSE_HYADES_PERFM ON_AGENTS%\\core\\lib\\coreagent.jar;%CUSTOMPATH_ORG_ECLIPSE _HYADES_PERFMON_AGENTS%\\core\\lib\\coreagent.jar;%CUSTOMPAT H_ORG_ECLIPSE_HYADES_PERFMON_AGENTS%\\core\\lib\\coreagent.j ar;%CUSTOMPATH_ORG_ECLIPSE_HYADES_PERFMON_AGENTS%\\core\\lib \\coreagent.jar;%CUSTOMPATH_ORG_ECLIPSE_HYADES_PERFMON_AGENT S%\\core\\lib\\coreagent.jar;%CUSTOMPATH_ORG_ECLIPSE_HYADES_ PERFMON_AGENTS%\\core\\lib\\coreagent.jar;%CUSTOMPATH_ORG_EC LIPSE_HYADES_PERFMON_AGENTS%\\core\\lib\\coreagent.jar;%CUST OMPATH_ORG_ECLIPSE_HYADES_PERFMON_AGENTS%\\core\\lib\\coreag ent.jar;%CUSTOMPATH_ORG_ECLIPSE_HYADES_PERFMON_AGENTS%\\core \\lib\\coreagent.jar
/instance/org.eclipse.ui.editors/overviewRuler_migration=mig rated_3.1
@org.eclipse.jdt.ui=3.2.2.r322_v20070124
/project/API/org.eclipse.core.resources/encoding//javax/cim/ messages.properties=8859_1
/instance/org.eclipse.core.resources/version=1
@org.eclipse.core.resources=3.2.2.R32x_v20061218
@org.eclipse.hyades.ui=4.2.0.v200611040100
/instance/org.eclipse.ui/showIntro=false
/instance/org.eclipse.help.ui/browser.y=0
/instance/org.eclipse.help.ui/browser.x=0
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE _CORE_COMMANDS=C\:\\Java\\eclipse\\plugins\\org.eclipse.core .commands_3.2.0.I20060605-1400.jar;
/instance/org.eclipse.help.ui/browser.maximized=false
/instance/org.eclipse.help.ui/browser.w=1024
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE _EMF_COMMON=C\:\\Java\\eclipse\\plugins\\org.eclipse.emf.com mon_2.2.1.v200702131851.jar;
/instance/org.eclipse.pde.core/platform_path=C\:\\Java\\ecli pse
/instance/org.eclipse.jdt.ui/tabWidthPropagated=true
@org.eclipse.team.cvs.ui=3.2.2.M20061121
@org.eclipse.debug.core=3.2.1.v20060823
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
/instance/org.eclipse.hyades.execution/PATH_ORG_ECLIPSE_HYAD ES_TEST_TOOLS_CORE=C\:\\Java\\eclipse\\plugins\\org.eclipse. hyades.test.tools.core_4.3.1.v200701291655
@org.eclipse.ui.workbench=3.2.2.M20070119-0800
file_export_version=3.0
@org.eclipse.jdt.launching=3.2.2.r322_v20061114
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.w idth=
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE _TPTP_PLATFORM_MODELS=C\:\\Java\\eclipse\\plugins\\org.eclip se.tptp.platform.models_4.2.100.v200611140100\\tptp-models.j ar;C\:\\Java\\eclipse\\plugins\\org.eclipse.tptp.platform.mo dels_4.2.100.v200611140100\\fastxpath.jar;
/instance/org.eclipse.help.ui/browser.h=768
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Co urier
New|10|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier New;
/instance/org.eclipse.hyades.execution/PATH_ORG_ECLIPSE_TPTP _PLATFORM_MODELS=C\:\\Java\\eclipse\\plugins\\org.eclipse.tp tp.platform.models_4.2.100.v200611140100
/instance/org.eclipse.team.ui/org.eclipse.team.ui.first_time =false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.enumIdentifier=error
/instance/org.eclipse.cdt.debug.ui/org.eclipse.debug.ui.Brea kpointView.org.eclipse.cdt.debug.ui.cDebug.show_full_paths=t rue
/instance/org.eclipse.hyades.execution/ECLIPSE_ARCH=x86
/instance/org.eclipse.ui.ide/platformState=1175292163650
/instance/org.eclipse.hyades.execution/PATH_ORG_ECLIPSE_TPTP _PLATFORM_LOGGING_EVENTS=C\:\\Java\\eclipse\\plugins\\org.ec lipse.tptp.platform.logging.events_4.3.0.v200611140100
/instance/org.eclipse.hyades.trace.ui/profilingTypeSets=<?xml
version\="1.0" encoding\="UTF-8"?><profilingSets><profilingSet
id\="org.eclipse.tptp.platform.probekit.ui.ProbekitProfilingSet "
name\="Probe Example" description\="Insert user-defined Probes in the
application. Edit the Profiling Type to specify which Probes to
deploy."><profilingTypes><profilingType
name\=" org.eclipse.tptp.platform.probekit.ui.internal.launch.Probek itProfilingType "/></profilingTypes><attributes><attribute
name\="SETOPTION_TRACE_MODE" value\="none"/><attribute
name\="SETOPTION_STACK_INFORMATION" value\="none"/><attribute
name\="SETOPTION_TICKET" value\="true"/><attribute
name\="SETOPTION_ALLOCATION_INFORMATION"
value\="none"/></attributes></profilingSet><profilingSet
id\="tptp-dummy-profiling-set-StartJWBEMServer"
name\="DummyProfilingSet" description\="Programmatically
Created"><profilingTypes><profilingType
name\="org.eclipse.tptp.analysisType.jvmti.execution"/></profilingTypes ><attributes><attribute
name\="org.eclipse.tptp.platform.jvmti.client.ATTR_EXEC_FLOW "
value\="false"/><attribute name\="CPU_TIME" value\="true"/><attribute
name\="org.eclipse.tptp.platform.jvmti.client.ATTR_EXEC_DATA "
value\="true"/><attribute name\="STACK_INFORMATION"
value\="normal"/><attribute name\="SETOPTION_ALLOCATION_INFORMATION"
id\="org.eclipse.hyades.defaultProfilingSets.executionStat"
name\="Execution History - Statistical" description\="Analyze the
application execution time. See how many methods were called and the
amount of time taken to execute every
method."><profilingTypes><profilingType
name\="org.eclipse.hyades.profilingType.execution"/></profilingTypes ><attributes><attribute
name\="SETOPTION_TRACE_MODE" value\="noObjectCorrelation"/><attribute
name\="SETOPTION_STACK_INFORMATION" value\="normal"/><attribute
name\="org.eclipse.hyades.trace.ui.ATTR_SHOW_EXECUTION_FLOW "
name\="org.eclipse.hyades.trace.ui.ATTR_SHOW_EXEC_INSTANCES "
value\="false"/><attribute name\="SETOPTION_ALLOCATION_INFORMATION"
id\="org.eclipse.hyades.defaultProfilingSets.execution" name\="Execution
History - Full Graphical Detail" description\="Analyze the application
execution time. See how many methods were called, the amount of time
taken to execute every method, and the execution flow graphical
details."><profilingTypes><profilingType
id\="org.eclipse.hyades.defaultProfilingSets.memory" name\="Memory
Analysis" description\="Analyze the application heap. See how many
classes were loaded, how many instances are still alive and the memory
size allocated by every class.&\#xA;Analyze memory leaks by collecting
Object Reference information."><profilingTypes><profilingType
name\="org.eclipse.hyades.profilingType.memoryHeap"/></profilingTypes ><attributes><attribute
name\="SETOPTION_TRACE_MODE" value\="full"/><attribute
name\="SETOPTION_ALLOCATION_INFORMATION" value\="default"/><attribute
name\="org.eclipse.hyades.trace.ui.ATTR_SHOW_HEAP_INSTANCES "
value\="false"/></attributes></profilingSet><profilingSet
id\="org.eclipse.hyades.defaultProfilingSets.coverage" name\="Code
Coverage - Method Level" description\="Captures code coverage
information and is optimized for high
performance."><profilingTypes><profilingType
name\="org.eclipse.hyades.profilingType.methodCoverage"/></profilingTypes ><attributes><attribute
name\="SETOPTION_METHOD_COUNTS" value\="true"/><attribute
value\="none"/></attributes></profilingSet></profilingSets >
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE _HYADES_TEST_CORE=C\:\\Java\\eclipse\\plugins\\org.eclipse.h yades.test.core_4.2.101.v200701291655\\hexteh.jar;C\:\\Java\ \eclipse\\plugins\\org.eclipse.hyades.test.core_4.2.101.v200 701291655\\hexrecr.jar;C\:\\Java\\eclipse\\plugins\\org.ecli pse.hyades.test.core_4.2.101.v200701291655\\test-core.jar;
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .compliance=1.5
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_APACHE_ COMMONS_LOGGING=C\:\\Java\\eclipse\\plugins\\org.apache.comm ons_logging_1.0.4.v200606131651\\lib\\commons-logging-1.0.4. jar;
/instance/org.eclipse.debug.ui/pref_state_memento.org.eclips e.debug.ui.VariableView= <?xml
org.eclipse.debug.ui.SASH_DETAILS_PART\="231"
org.eclipse.debug.ui.SASH_VIEW_PART\="768">\r\n<COLUMN_SIZES
IMemento.internal.id\=" org.eclipse.debug.ui.VARIALBE_COLUMN_PRESENTATION.COL_VAR_VA LUE "
SIZE\="464"/>\r\n<COLUMN_SIZES
IMemento.internal.id\=" org.eclipse.debug.ui.VARIALBE_COLUMN_PRESENTATION.COL_VAR_NA ME "
SIZE\="240"/>\r\n</VariablesViewMemento>
/instance/org.eclipse.jdt.ui/Refactoring.savealleditors=true
@org.eclipse.hyades.execution=4.3.1.v200702221346
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE _SWT=C\:\\Java\\eclipse\\plugins\\org.eclipse.swt_3.2.2.v323 6b.jar;C\:\\Java\\eclipse\\plugins\\org.eclipse.swt.win32.wi n32.x86_3.2.2.v3236.jar;
/instance/org.eclipse.tptp.platform.common.ui/switch_to_pers pective=always
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.codeComp lete.visibilityCheck=enabled
@org.eclipse.ui.editors=3.2.1.r321_v20060721
@org.eclipse.hyades.trace.ui=4.3.0.v200611070100
@org.eclipse.core.variables=3.1.100.v20060605
/instance/org.eclipse.hyades.execution/CUSTOMPATH_ORG_ECLIPS E_HYADES_PERFMON_AGENTS=;%RASERVER_HOME%\\extensions\\org.ec lipse.hyades.perfmon.agents;%RASERVER_HOME%\\extensions\\org .eclipse.hyades.perfmon.agents;%RASERVER_HOME%\\extensions\\ org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\\extension s\\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\\extens ions\\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\\ext ensions\\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME%\\ extensions\\org.eclipse.hyades.perfmon.agents;%RASERVER_HOME %\\extensions\\org.eclipse.hyades.perfmon.agents;%RASERVER_H OME%\\extensions\\org.eclipse.hyades.perfmon.agents;%RASERVE R_HOME%\\extensions\\org.eclipse.hyades.perfmon.agents;%RASE RVER_HOME%\\extensions\\org.eclipse.hyades.perfmon.agents;%R ASERVER_HOME%\\extensions\\org.eclipse.hyades.perfmon.agents
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE _HYADES_LOGGING_PARSERS=C\:\\Java\\eclipse\\plugins\\org.ecl ipse.hyades.logging.parsers_4.3.0.v200611020100\\hparse.jar; C\:\\Java\\eclipse\\plugins\\org.eclipse.hyades.logging.pars ers_4.3.0.v200611020100\\tpglimport.jar;
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=C\:\\Doc uments and
Settings\\jmars\\workspace-wbem
/instance/org.eclipse.cdt.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE _HYADES_LOGGING_ADAPTER=C\:\\Java\\eclipse\\plugins\\org.ecl ipse.hyades.logging.adapter_4.3.0.v200611140100\\hgla.jar;
/instance/org.eclipse.team.cvs.ui/pref_first_startup=false
@org.eclipse.tptp.platform.common.ui=4.3.0.v200611070100
/instance/org.eclipse.hyades.execution/PATH_ORG_ECLIPSE_HYAD ES_PROBEKIT=C\:\\Java\\eclipse\\plugins\\org.eclipse.hyades. probekit_4.2.100.v200609190100
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .codegen.targetPlatform=1.5
/instance/org.eclipse.hyades.execution/PATH_ORG_ECLIPSE_HYAD ES_EXECUTION=C\:\\Java\\eclipse\\plugins\\org.eclipse.hyades .execution_4.3.1.v200702221346
/instance/org.eclipse.hyades.trace.ui/switch_to_perspective= always
/instance/org.eclipse.cdt.core/indexer=org.eclipse.cdt.core. domsourceindexer
/instance/org.eclipse.hyades.execution/PROBEKIT_PLUGIN=C\:\\ Java\\eclipse\\plugins\\org.eclipse.hyades.probekit_4.2.100. v200609190100
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.formatterpro files.version=10
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE _EMF_ECORE=C\:\\Java\\eclipse\\plugins\\org.eclipse.emf.ecor e_2.2.2.v200702131851.jar;
/instance/org.eclipse.ui.workbench/ENABLED_DECORATORS=org.ec lipse.jdt.ui.override.decorator\:true,org.eclipse.jdt.ui.int erface.decorator\:false,org.eclipse.pde.ui.binaryProjectDeco rator\:false,org.eclipse.team.cvs.ui.decorator\:true,org.ecl ipse.ui.LinkedResourceDecorator\:true,
/instance/org.eclipse.jdt.ui/content_assist_lru_history=<?xml
version\="1.0" encoding\="UTF-8"?><history maxLHS\="100" maxRHS\="10"/>
@org.eclipse.jdt.core=3.2.3.v_686_R32x
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.templat es_migrated=true
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE _TPTP_PLATFORM_LOGGING_EVENTS=C\:\\Java\\eclipse\\plugins\\o rg.eclipse.tptp.platform.logging.events_4.3.0.v200611140100\ \tlcore.jar;C\:\\Java\\eclipse\\plugins\\org.eclipse.tptp.pl atform.logging.events_4.3.0.v200611140100\\hlcbe101.jar;C\:\ \Java\\eclipse\\plugins\\org.eclipse.tptp.platform.logging.e vents_4.3.0.v200611140100\\tlcbe101.jar;
/instance/org.eclipse.hyades.execution/PATH_ORG_ECLIPSE_HYAD ES_LOGGING_ADAPTER=C\:\\Java\\eclipse\\plugins\\org.eclipse. hyades.logging.adapter_4.3.0.v200611140100
@org.eclipse.search=3.2.1.r321_v20060726
/instance/org.eclipse.hyades.execution/LIB_EXTENSION=.dll
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.switch_p erspective_on_suspend=always
/instance/org.eclipse.hyades.execution/PATH_ORG_ECLIPSE_TPTP _PLATFORM_COLLECTION_FRAMEWORK=C\:\\Java\\eclipse\\plugins\\ org.eclipse.tptp.platform.collection.framework_4.2.0.v200611 140100
/instance/org.eclipse.ui.ide/tipsAndTricks=true
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE _EQUINOX_COMMON=C\:\\Java\\eclipse\\plugins\\org.eclipse.equ inox.common_3.2.0.v20060603.jar;
@org.eclipse.jdt.debug.ui=3.2.2.r322_v20061205
/instance/org.eclipse.debug.core/prefWatchExpressions=<?xml
version\="1.0" encoding\="UTF-8"?>\r\n<watchExpressions/>\r\n
/instance/org.eclipse.jdt.debug.ui/org.eclipse.debug.ui.Expr essionView.org.eclipse.jdt.debug.ui.show_null_entries=true
/instance/org.eclipse.ui.browser/browsers=<?xml version\="1.0"
encoding\="UTF-8"?>\r\n<web-browsers
current\="0">\r\n<system/>\r\n<external location\="C\:\\Program
Files\\Mozilla Firefox\\firefox.exe" name\="Firefox"/>\r\n<external
location\="C\:\\Program Files\\Internet Explorer\\iexplore.exe"
name\="Internet Explorer"/>\r\n</web-browsers>
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE _OSGI=c\:\\Java\\eclipse\\plugins\\org.eclipse.osgi_3.2.2.R3 2x_v20070118.jar;
/instance/org.eclipse.hyades.execution/ECLIPSEROOT=C\:\\Java \\eclipse
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.user_vie w_bindings= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<viewBindings>\r\n<view
id\="org.eclipse.debug.ui.ExpressionView">\r\n<perspective
id\="org.eclipse.debug.ui.DebugPerspective"
userAction\="opened"/>\r\n</view>\r\n<view
id\="org.eclipse.ui.console.ConsoleView">\r\n<perspective
id\="org.eclipse.jdt.ui.JavaPerspective"
userAction\="opened"/>\r\n<perspective
id\="org.eclipse.hyades.trace.internal.ui.tracePerspective"
userAction\="opened"/>\r\n</view>\r\n</viewBindings>\r\n
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocat ions.migrated=true
/instance/org.eclipse.cdt.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .source=1.5
/instance/org.eclipse.jdt.debug.ui/org.eclipse.debug.ui.Vari ableView.org.eclipse.jdt.debug.ui.show_null_entries=true
/instance/org.eclipse.cdt.debug.ui/org.eclipse.debug.ui.Debu gView.org.eclipse.cdt.debug.ui.cDebug.show_full_paths=true
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE _EMF_ECORE_XMI=C\:\\Java\\eclipse\\plugins\\org.eclipse.emf. ecore.xmi_2.2.2.v200702131851.jar;
@org.eclipse.team.ui=3.2.1.M200608151725
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_JUNIT=C \:\\Java\\eclipse\\plugins\\org.junit_3.8.1\\junit.jar;
/instance/org.eclipse.team.cvs.core/repositories/%pserver%wb-jmars@wbempc%%Repository/location=\:pserver\:wb-jmars@wbempc\:/Repository
/instance/org.eclipse.tptp.platform.common.ui/org.eclipse.hy ades.ui.filters.internal.defaultFilters.org.eclipse.hyades.t race.views=true
/instance/org.eclipse.search/org.eclipse.search.defaultPersp ective=org.eclipse.search.defaultPerspective.none
/instance/org.eclipse.hyades.execution/CLASSPATH_COM_IBM_ICU =C\:\\Java\\eclipse\\plugins\\com.ibm.icu_3.4.5.20061213.jar ;
/instance/org.eclipse.hyades.execution/JONAS_HOME=null
/instance/org.eclipse.hyades.execution/PATH_ORG_ECLIPSE_HYAD ES_LOGGING_PARSERS=C\:\\Java\\eclipse\\plugins\\org.eclipse. hyades.logging.parsers_4.3.0.v200611020100
/instance/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.c ore.cDebug.common_source_containers= <?xml
version\="1.0"
encoding\="UTF-8"?>\r\n<sourceLookupDirector>\r\n<sourceContainers
duplicates\="false"/>\r\n</sourceLookupDirector>\r\n
/instance/org.eclipse.jdt.ui/proposalOrderMigrated=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder. resourceCopyExclusionFilter=*.launch,*.testsuite,*.deploy,*. location,*.execution,*.datapool,*.artifact,*.html,*.svg
/instance/org.eclipse.hyades.execution/CLASSPATH_ORG_ECLIPSE _HYADES_LOGGING_CORE=C\:\\Java\\eclipse\\plugins\\org.eclips e.hyades.logging.core_4.3.0.v200609190100\\hlcore.jar;C\:\\J ava\\eclipse\\plugins\\org.eclipse.hyades.logging.core_4.3.0 .v200609190100\\hl14.jar;C\:\\Java\\eclipse\\plugins\\org.ec lipse.hyades.logging.core_4.3.0.v200609190100\\hllog4j.jar;C \:\\Java\\eclipse\\plugins\\org.eclipse.hyades.logging.core_ 4.3.0.v200609190100\\hlcommons.jar;
/instance/org.eclipse.hyades.execution/RASERVER_HOME=C\:\\Ja va\\eclipse\\plugins\\org.eclipse.hyades.execution_4.3.1.v20 0702221346\\iac-runtime
/instance/org.eclipse.hyades.trace.ui/set_filters=<filters> <filter id \=
'org.eclipse.hyades.trace.ui.filterSet.default' key \= 'DEF_SETNM' name
\= 'Default'><contents><content text
Re: java.lang.NoClassDefFoundError: <my main class> [message #94804 is a reply to message #94669] |
Tue, 03 April 2007 19:45 |
No real name Messages: 404 Registered: July 2009 |
What is the nature of your application (e.g. Java application/Eclipse
Applicaiton/JUnit/...)?
Which of the two data collectors are you selecting under the monitor tab?
There is one that corresponds to the JVMPI agent ("Java Profiling (double
click to modify filters)") and one that corresponds to the JVMTI agent
("Java Profiling ( Java 5.0+ )(double click to modify filters)").
You can't run the JVMTI agent if you don't have the standalone Agent
Controller installed.
"Jim Marshall" <jim.marshall@wbemsolutions.com> wrote in message
news:euk1k4$25t$1@build.eclipse.org...
> install and then unzipped the all-in-one package. Eclipse starts up and I
> can debug my application in Eclipse with no problem. But when I select the
> profile option I get a "java.lang.NoClassDefFoundError" for my projects
> main class.
> I am using:
> config details:
> win32
> -ws
> win32
> -arch
> x86
> -launcher
> -name
> Eclipse
> -showsplash
> 600
> -exitdata
> 2598_784
> -vm
> -Xmx256m
> -jar
> eof=eof
> file.separator=\
> line.separator=
> os.arch=x86
> os.name=Windows XP
> os.version=5.1
> osgi.arch=x86
> osgi.nl=en_US
> osgi.os=win32
> osgi.ws=win32
> path.separator=;
> sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386
> i86
> sun.desktop=windows
> user.country=US
> user.language=en
> user.name=jmars
> user.variant=
> *** Features:
> org.apache.batik.pdf (1.6.0.v20060613-1220-0842282835-3442) "Apache Batik
> Pdf"
> org.eclipse.emf.ecore.sdo (2.2.1.v200702131851) "EMF Service Data Objects
> (SDO)"
> Development Tools"
> Platform"
> org.eclipse.rcp.source (3.2.2.r322_v20070104-8pcviKVqd8J7C1U) "Eclipse RCP
> SDK"
> Monitoring"
> org.eclipse.tptp.monitoring.doc.user (4.3.0.v200610310100--1G955G767A5755)
> "TPTP Monitoring Project Documentation"
> org.eclipse.tptp.monitoring.examples (4.3.0.v200610310100--08422832432322)
> "User examples for the TPTP Monitoring Tools Plugins"
> org.eclipse.tptp.monitoring.la.core (4.3.0.v200608310100--2PD88PAA_H8A88)
> "TPTP Analysis"
> org.eclipse.tptp.platform.core (4.3.1.v200701291655--GFEkmGwH-woGu8) "TPTP
> Platform"
> Documentation"
> "Log Analysis Core"
> org.eclipse.tptp.platform.lta (4.3.0.v200610310100--1G955G6B6E6A6D) "TPTP
> "TPTP ProbeKit"
> org.eclipse.tptp.test.doc.user (4.3.0.v200611020100--08422833372322) "Test
> "TPTP Test Samples"
> Test Tools"
> Trace"
> Trace JVMTI Client"
> com.ibm.icu.source (3.4.5.20061213) "International Components for Unicode
> Plug-in" [Resolved]
> Plug-in" [Resolved]
> org.eclipse.core.contenttype (3.2.0.v20060603) "Eclipse Content Mechanism"
> [Active]
> org.eclipse.core.expressions (3.2.2.r322_v20070109a) "Expression Language"
> [Active]
> [Active]
> [Resolved]
> org.eclipse.core.filesystem.win32.x86 (1.0.0.v20060603) "Core File System
> org.eclipse.core.resources.compatibility (3.2.0.v20060603) "Core Resource
> [Resolved]
> Support" [Resolved]
> Model" [Resolved]
> org.eclipse.emf.ecore.change.edit (2.2.0.v200702131851) "EMF Ecore Change
> org.eclipse.emf.ecore.edit (2.2.0.v200702131851) "EMF Ecore Edit Support"
> [Resolved]
> [Resolved]
> (SDO)" [Resolved]
> org.eclipse.emf.exporter (2.2.0.v200702131851) "EMF Model Export Support"
> [Resolved]
> org.eclipse.emf.importer (2.2.2.v200702131851) "EMF Model Import Support"
> [Resolved]
> org.eclipse.emf.importer.ecore (2.2.0.v200702131851) "EMF Ecore Importer"
> [Resolved]
> [Resolved]
> org.eclipse.emf.mapping.ecore2ecore (2.2.0.v200702131851) "Ecore to Ecore
> Mapping" [Resolved]
> org.eclipse.emf.mapping.ecore2ecore.editor (2.2.0.v200702131851) "Ecore to
> Mapping" [Resolved]
> [Resolved]
> Mapping" [Resolved]
> [Active]
> Support" [Active]
> [Resolved]
> [Resolved]
> [Resolved]
> org.eclipse.hyades.logging.adapter (4.3.0.v200611140100) "TPTP Monitoring
> org.eclipse.hyades.logging.core.sample (4.1.100.v200606131519) "Sample for
> Hyades Logging Agent, Common Base Events and Logging Facility Support"
> [Resolved]
> org.eclipse.hyades.logging.parsers (4.3.0.v200611020100) "TPTP Monitoring
> org.eclipse.hyades.perfmon (4.2.0.v200606131519) "Perfmon StatCon Module"
> [Resolved]
> [Active]
> org.eclipse.hyades.probekit.doc.user (4.2.0.v200610310100) "Probekit User
> [Resolved]
> [Resolved]
> org.eclipse.hyades.statistical.ui (4.2.100.v200611061046) "Statistical UI"
> [Active]
> Plug-In" [Resolved]
> org.eclipse.hyades.test.tools.core (4.3.1.v200701291655) "TPTP Test Tools
> org.eclipse.hyades.test.tools.ui (4.3.0.v200611150100) "TPTP Test Tools UI
> Plug-In" [Resolved]
> org.eclipse.hyades.test.ui (4.2.101.v200701291655) "TPTP Test UI Plug-In"
> [Resolved]
> [Active]
> org.eclipse.hyades.trace.views (4.1.200.v200611150100) "Hyades Trace Views
> Plugin" [Resolved]
> [Resolved]
> [Active]
> org.eclipse.jdt.doc.user (3.2.0.v20060605-1400) "Eclipse Java Development
> org.eclipse.jdt.junit (3.2.1.r321_v20060810) "Java Development Tools JUnit
> support" [Resolved]
> [Active]
> org.eclipse.jface.databinding (1.0.0.I20060605-1400) "JFace Data Binding"
> [Resolved]
> org.eclipse.ltk.core.refactoring (3.2.1.r321_v20060823) "Refactoring Core"
> [Active]
> [Active]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> org.eclipse.pde.runtime (3.2.0.v20060605) "Plug-in Development Environment
> Runtime" [Resolved]
> [Resolved]
> (3.2.2.r322_v20070119-RQghndJN8IM0MsK) "Eclipse Platform Plug-in Developer
> org.eclipse.swt.win32.win32.x86 (3.2.2.v3236) "Standard Widget Toolkit for
> Windows" [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> org.eclipse.tptp.monitoring.examples (4.3.0.v200610210100) "User examples
> [Resolved]
> org.eclipse.tptp.monitoring.managedagent.ui (4.3.0.v200611140100) "Managed
> org.eclipse.tptp.monitoring.symptom.editor (4.3.1.v200702091252) "Symptom
> org.eclipse.tptp.platform.agentcontroller.doc.user (4.2.100.v200611140100)
> org.eclipse.tptp.platform.analysis (4.1.100.v200606131519) "TPTP Analysis"
> [Resolved]
> org.eclipse.tptp.platform.collection.framework (4.2.0.v200611140100) "TPTP
> Plug-in" [Active]
> org.eclipse.tptp.platform.common.ui (4.3.0.v200611070100) "TPTP Common UI
> Plug-in" [Active]
> [Resolved]
> Core" [Resolved]
> org.eclipse.tptp.platform.log.views (4.3.0.v200611070100) "Hyades Log UI"
> [Resolved]
> org.eclipse.tptp.platform.lta (4.1.100.v200606131519) "TPTP Log and Trace
> [Active]
> org.eclipse.tptp.platform.probekit (4.1.100.v200606131519) "TPTP ProbeKit"
> [Resolved]
> org.eclipse.tptp.platform.probekit.launch (4.3.0.v200609210100) "Probekit
> Service" [Resolved]
> UI" [Resolved]
> Samples" [Resolved]
> Trace" [Resolved]
> org.eclipse.tptp.test.samples (4.1.200.v200611030100) "TPTP Test Samples"
> [Resolved]
> [Resolved]
> [Resolved]
> [Active]
> [Active]
> org.eclipse.ui.intro.universal (3.2.1.R321_v20060905) "Universal Welcome"
> [Resolved]
> [Resolved]
> org.eclipse.ui.presentations.r21 (3.2.0.I20060605-1400) "R21 Presentation
> Plug-in" [Resolved]
> Framework" [Active]
> [Active]
> org.eclipse.update.core.win32 (3.2.2.R32x_v20061214) "Install/Update Core
> Scheduler" [Active]
> [Resolved]
> [Resolved]
> org.eclipse.xsd.ecore.exporter (2.2.1.v200702131851) "XML Schema Exporter
> for EMF" [Resolved]
> org.eclipse.xsd.ecore.importer (2.2.0.v200702131851) "XML Schema Importer
> for EMF" [Resolved]
> [Resolved]
> [Resolved]
> id\="1157651466160"
> id\="tptp-dummy-profiling-set-StartJWBEMServer" name\="DummyProfilingSet"
> description\="Programmatically Created"><profilingTypes><profilingType
> execution time. See how many methods were called, the amount of time taken
> Analysis" description\="Analyze the application heap. See how many classes
> were loaded, how many instances are still alive and the memory size
> allocated by every class.&\#xA;Analyze memory leaks by collecting Object
> Coverage - Method Level" description\="Captures code coverage information
> and is optimized for high performance."><profilingTypes><profilingType
Re: java.lang.NoClassDefFoundError: <my main class> [message #94879 is a reply to message #94804] |
Wed, 04 April 2007 00:41 |
It's a Java Application. I have tried both monitors. With the JVMPI
agent I get the classdefnotfound error, with the JVMTI I get 'unable to
connect to agent".
I guess I am not familiar with standalone agent, what is it and how do I
run it?
Current Time: Thu Apr 25 05:50:36 GMT 2024
Powered by FUDForum. Page generated in 0.03663 seconds
