Home » Eclipse Projects » DSDP - Real-Time Software Components (RTSC) » Embedded Instances -- RTSC-pedia article
Embedded Instances -- RTSC-pedia article [message #715] Thu, 18 December 2008 23:11
Bob Frankel is currently offline Bob FrankelFriend
Here's the link: http://rtsc.eclipse.org/docs-tip/Embedded_Instances
Check it out, especially if you're producing RTSC modules and wish to
leverage this advanced feature which has been in use for quite some time
-- and now, is officially documented.
With this newsgroup becoming more active, let's use this particular
thread for general comments/questions about the article, in lieu of the
discussion page attached to this article on the RTSC-pedia wiki. At the
same, *do* correct typos you may find by simply editing the article in
place.
Previous Topic:"requires internal" docs
Next Topic:RTSC for ECU
Current Time: Wed Jan 17 13:31:47 GMT 2018
Powered by FUDForum. Page generated in 0.01289 seconds
