Home » Eclipse Projects » Equinox » How to prevent bundle resume on restart
How to prevent bundle resume on restart [message #780478] Wed, 18 January 2012 08:44 Go to next message
Jan Mauersberger is currently offline Jan MauersbergerFriend
I have a bundle with lazy bundle activation policy, so the bundle is
started when using the first time. I have a bundle activator that
dynamically adds fragments to the bundle depending on certain
environment conditions and user preferences. That is working fine so far.
However, after a restart the framework is resuming all bundles that were
active on shutdown, among others also my bundle. Thus the
activator.start() method is called rather early in the startup phase
before(!) anything as application or product or eve even workspace is
known. Since my startup code depends on that I would like to know
whether it is possible to prevent suspension/resumption by any means or
whether someone had similar problems and a solution.
Thanks in advance
Jan
Re: How to prevent bundle resume on restart [message #780492 is a reply to message #780478] Wed, 18 January 2012 10:06 Go to previous messageGo to next message
Gunnar Wagenknecht is currently offline Gunnar WagenknechtFriend
Am 18.01.2012 09:44, schrieb Jan Mauersberger:
Relying on startup order and lazy start behavior is nearly impossible.
You may set explicit set start levels to ensure a specific start order
but then you won't have lazy activation.
I think it could work if you defer your processing until the bundles are
available. For example, in your start method check if everything is
available and if not register a bundle listener. The listener will be
notified about bundle changes and you could attach fragments more
dynamically (eventually also supporting detaching when a dependency is
stopped). Doesn't make the implementation easier, though.
-Gunnar
Gunnar Wagenknecht
gunnar@wagenknecht.org
http://wagenknecht.org/
Re: How to prevent bundle resume on restart [message #780530 is a reply to message #780492] Wed, 18 January 2012 13:31 Go to previous messageGo to next message
Thomas Watson is currently offline Thomas WatsonFriend
It sounds to me that something is eagerly starting your bundle which persistently marks it for eager (non-lazy) start on restart of the framework. Or perhaps there is another bundle starting which loads a class from your lazy-start bundle which is causing it to get lazy activated, but you think it is getting started too early.
You can enable the following trace option to see if something is eagerly starting your bundle:
org.eclipse.osgi/monitor/activation=true
HTH
Tom.
Re: How to prevent bundle resume on restart [message #780569 is a reply to message #780530] Wed, 18 January 2012 16:17 Go to previous messageGo to next message
Thomas,
I could confirm that the bundle seems to be lazily started having
eclipse started the first time (configuration space empty). The bundle
is started by a classloader "cascade".
On second start the activation stack is as following, so it seems to be
directly forced by the framework only:
MyActivator.start(BundleContext) line: 74
BundleContextImpl$1.run() line: 711
AccessController.doPrivileged(PrivilegedExceptionAction<T>) line: not
available [native method]
BundleContextImpl.startActivator(BundleActivator) line: 702
BundleContextImpl.start() line: 683
BundleHost.startWorker(int) line: 381
BundleHost(AbstractBundle).resume() line: 389
Framework.resumeBundle(AbstractBundle) line: 1131
StartLevelManager.resumeBundles(AbstractBundle[], boolean, int) line: 559
StartLevelManager.resumeBundles(AbstractBundle[], int) line: 544
StartLevelManager.incFWSL(int, AbstractBundle[]) line: 457
Using your trace option hint I get something like the following when the
bundle is started the first time lazily:
java.lang.Exception: A persistent start has been called on bundle:
XXXXX_1.0.0.qualifier
org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:306)
org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:291)
de.ikv.analyze.adapter.rhapsody.ui.AnalyzeRhapsodyAdapterUiPlugin.start(AnalyzeRhapsodyAdapterUiPlugin.java:40)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
What exactly does this debug output mean?
Thnaks for the help
Jan
> HTH
> Tom.
Re: How to prevent bundle resume on restart [message #780575 is a reply to message #780569] Wed, 18 January 2012 16:33 Go to previous messageGo to next message
Further up the stack from the debug should show you the class that is calling Bundle.start(). This is causing a persistent eager activation of the bundle when you restart.
HTH
Tom.
Re: How to prevent bundle resume on restart [message #780605 is a reply to message #780569] Wed, 18 January 2012 18:11 Go to previous messageGo to next message
Am 18.01.2012 17:17, schrieb Jan Mauersberger:
You need to change the call in AnalyzeRhapsodyAdapterUiPlugin line 40 to
"bundleToStart.start(Bundle.START_TRANSIENT)".
-Gunnar
Gunnar Wagenknecht
Re: How to prevent bundle resume on restart [message #780720 is a reply to message #780605] Thu, 19 January 2012 08:05 Go to previous message
Oh man,
I absolutely did forget that part of my own obsolete code: before trying
dynamic fragments I had added code to force certain bundle activation.
As it seems that forces a persistent restart of the bundle.
Thanks a lot for saving me lots of time and a headache!
Jan
> -Gunnar
Previous Topic:How to plug a different i18n mechanism
Next Topic:Problems building a p2-enabled Eclipse workbench-based product
Current Time: Wed May 23 20:59:09 GMT 2018
Powered by FUDForum. Page generated in 0.02082 seconds
