| Parameter in sequence [message #778633] |
Fri, 13 January 2012 10:25  |
fru Missing name Messages: 6 Registered: December 2011 |
Junior Member |
I would like to use the parameter dialog of the web viewer as a login prompt for acessing my data in the report. This is working well as long I don't need these login-data in the parameter dialog itself.
Is there any way to evaluate parameters in a sequence, so I could use the login data retrieven from a parameter group A, to populate a parameter list in a subsequent paramater group B ?
I experimented with cascading parameter group but since they use datasets I can't see this working.
Any ideas would be appreciated.
fru
| Re: Parameter in sequence [message #778683 is a reply to message #778633] |
Fri, 13 January 2012 11:24  |
Jason Weathersby Messages: 9167 Registered: July 2009 |
Cascaded is the only way I know of. Although cascaded parameter use
datasets these can be scripted datasets, where you can look at the
previous cascade value.
Jason
On 1/13/2012 10:25 AM, fru wrote:
> I don't need these login-data in the parameter dialog itself. Is there
> fru
Jason Weathersby
BIRT Exchange
FUDForum. Page generated in 0.01503 seconds
