Home » Eclipse Projects » Rich Client Platform (RCP) » Load Image(Error: NullPointerException )
Load Image [message #778483] Thu, 12 January 2012 20:09 Go to next message
Simon Woelki is currently offline Simon WoelkiFriend
Hey guys,
When my application starts it opens a image upload.
This works fine. But as soon as it enters the application it throws an error:
	at uad.ViewPart4.createPartControl(ViewPart4.java:145)
	at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewReference.java:375)
	at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:229)
	at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
	at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
	at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:534)
	at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
	at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
	at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
	at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
	at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1245)
	at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1198)
	at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1597)
	at org.eclipse.ui.internal.PartStack.createControl(PartStack.java:643)
	at org.eclipse.ui.internal.PartStack.createControl(PartStack.java:570)
	at org.eclipse.ui.internal.PartSashContainer.createControl(PartSashContainer.java:568)
	at org.eclipse.ui.internal.PerspectiveHelper.activate(PerspectiveHelper.java:272)
	at org.eclipse.ui.internal.Perspective.onActivate(Perspective.java:981)
	at org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPage.java:2714)
	at org.eclipse.ui.internal.WorkbenchWindow$27.run(WorkbenchWindow.java:3023)
	at org.eclipse.ui.internal.WorkbenchWindow.setActivePage(WorkbenchWindow.java:3004)
	at org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(WorkbenchWindow.java:799)
	at org.eclipse.ui.internal.Workbench$23.runWithException(Workbench.java:1224)
	at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
	at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
	at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
	at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
	at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
	at org.eclipse.ui.internal.Workbench$33.runWithException(Workbench.java:1595)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
	at uad.Application.start(Application.java:20)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Here is the code:
final FileDialog FD = new FileDialog(Display.getCurrent().getActiveShell(), SWT.MULTI);
  		//FD.setFilterPath("C:\\Users\\Admin\\workspace\\");
  		String[] filterExt = {"*.jpg", "*.gif", "*.png",  "*.jpeg", "*.bmp", "*.*"};
  		FD.setFilterExtensions(filterExt);
  	    String hans = FD.open();
  		if (hans != null)
  			String[] bilder = FD.getFileNames();
  			String pfad = FD.getFilterPath();
  			for (int i = 0; i < bilder.length; i++)
  				String Bild = pfad + "\\" + bilder[i];
  				ImageDescriptor imageDescriptor = Activator.getImageDescriptor(Bild);
				Image orginalImage = imageDescriptor.createImage();
					Label label = new Label(linkeSpalte, SWT.RESIZE);
					label.setImage(orginalImage);
  		if (hans == null)
  				label.setText("Falsches Format oder keine Datei(en) ausgewählt.");
Image orginalImage = imageDescriptor.createImage(); is line 145 (NullPointerException)
Any ideas?
Best regards
Simon
Re: Load Image [message #778492 is a reply to message #778483] Thu, 12 January 2012 20:56 Go to previous message
David Wegener is currently offline David WegenerFriend
Well, the obvious answer would be that Activator.getImageDescriptor(Bild) is returning null. Most likely the path you are building isn't correct.
Previous Topic:Keeping top displayed node the same during tree refreshing
Next Topic:MultiPageFormEditor switch Tab on Key Event
Current Time: Sun Apr 22 03:23:56 GMT 2018
Powered by FUDForum. Page generated in 0.01429 seconds
