Home » Eclipse Projects » BIRT » BIRT reports security issue with database password (odaPassword)(Database Password (odaPassword) unencrypted)
BIRT reports security issue with database password (odaPassword) [message #777901] Wed, 11 January 2012 01:06 Go to next message
Daniel V is currently offline Daniel V
I have remarked that my database password appear not-encrypted into the report file under the design section.
<design:DataSetParameters>
<design:parameterDefinitions>
<design:inOutMode>In</design:inOutMode>
<design:attributes>
</design:attributes>
<design:inputAttributes>
<design:elementAttributes>
<design:optional>false</design:optional>
<design:masksValue>false</design:masksValue>
<design:dynamicValueChoices>
<design:dataSetDesign>
<design:name>Agents</design:name>
<design:odaExtensionDataSetId>org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet</design:odaExtensionDataSetId>
<design:dataSourceDesign>
<design:name>vsl</design:name>
<design:odaExtensionId>org.eclipse.birt.report.data.oda.jdbc</design:odaExtensionId>
<design:publicProperties>
<design:properties>
<design:nameValue>
<design:name>odaDriverClass</design:name>
<design:value>org.postgresql.Driver</design:value>
</design:nameValue>
</design:properties>
<design:properties>
<design:nameValue>
<design:name>odaURL</design:name>
<design:value>jdbc:postgresql://localhost/db</design:value>
</design:nameValue>
<design:properties>
<design:nameValue>
<design:name>odaUser</design:name>
<design:value>postgres</design:value>
</design:nameValue>
<design:properties>
<design:nameValue>
<design:name>odaPassword</design:name>
<design:value>CLEAR_PASSWORD</design:value>
</design:nameValue>
-The value of the parameter odaPassword is not encrypted!
Just to note that the database password is encrypted for the data-source definition :
<property name="odaDriverClass">org.postgresql.Driver</property>
<property name="odaURL">jdbc:postgresql://localhost/db</property>
<property name="odaUser">postgres</property>
<encrypted-property name="odaPassword" encryptionID="base64">ENCRYPTED_PASSWORD</encrypted-property>
Any help is very appreciated.
Thanks in advance.
Cheers
PS: I'm using BIRT 2.5.2
Re: BIRT reports security issue with database password (odaPassword) [message #778401 is a reply to message #777901] Wed, 11 January 2012 12:38 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
I believe in later versions this has been fixed. If you switch to the
xml view and delete the designer values, does it re-write them?
Jason
On 1/11/2012 1:06 AM, Daniel Mising name wrote:
> Hello,
> <design:attributes>
> <design:properties>
> <design:nameValue>
> </design:nameValue>
> <design:properties>
> <design:nameValue>
> </design:nameValue>
> <design:properties>
> <design:nameValue>
> </design:nameValue>
> <design:properties>
> <design:nameValue>
> </design:nameValue>
> definition :
> Thanks in advance.
> Cheers
Jason Weathersby
BIRT Exchange
icon14.gif  Re: BIRT reports security issue with database password (odaPassword) [message #781054 is a reply to message #778401] Fri, 20 January 2012 03:56 Go to previous message
Hi Jason,
Thanks a lot Smile
I have only deleted the design value for the odaPassword parameter as you have suggested, so now it looks like this :
<design:value></design:value>
and the problem is SOLVED, the report still works as expected and the database password is not shown.
I have edited the .rptdesign file manually (with text editor) but even I have re-saved the report with the BIRT designer the password was not re-written.
Cheers
[Updated on: Fri, 20 January 2012 04:34]
Report message to a moderator
Previous Topic:How access to servlet context parameters from birt javascript?
Next Topic:"Getting more records or rows with data which are not generated in Birt designer preview."
Current Time: Thu Jun 20 08:36:36 EDT 2013
Powered by FUDForum. Page generated in 0.01647 seconds
