Home » Eclipse Projects » BIRT » slight lag when running first report
slight lag when running first report [message #776629] Sun, 08 January 2012 18:59 Go to next message
Missing name Missing name is currently offline Missing name Missing name
Hi All,
When I run a BIRT report for the first time, it takes a while to get to the progress bar, then a while to finally render the report. Every time I view the same report after that initial report, it goes much much faster.
It is like something is getting compiled on that first run.
is there a way to eliminate the initial lag?
Bruce
Re: slight lag when running first report [message #776684 is a reply to message #776629] Sun, 08 January 2012 23:15 Go to previous message
sam va is currently offline sam va
we also observed the same behaviour. we are running in a server environment (multiple reports can run parallelly). The first report though will take some time additionally... may be bringing up the engine (if you are re-using the engine)
Previous Topic:Birt 3.7 - Frameset mapping crashes my Tomcat server
Next Topic:String based parameters in ODA OCL
Current Time: Sat May 25 12:31:09 EDT 2013
Powered by FUDForum. Page generated in 0.01414 seconds
