Home » Eclipse Projects » BIRT » Reg: Masterpage in pdf files(Reg: Masterpage in pdf files)
Reg: Masterpage in pdf files [message #775728] Fri, 06 January 2012 15:42 Go to next message
harip kaligo is currently offline harip kaligoFriend
Member
We created a master page for our reports that contains title and subtitle, page numbers of the report.
All our reports display title only on the first page of our reports and from second page onwards we hide title and display only page numbers.
Doing this creates some empty space between the header(that comprises title from master page)and table data from second page. We could overcome this in HTML pages, but in PDF version of reports we could not reduce the gap created by hiding the grid in master page from second page.
Any idea on how to eliminate or remove the gap ?
We are using BIRT3.7 version.
KKP
Re: Reg: Masterpage in pdf files [message #776859 is a reply to message #775728] Mon, 09 January 2012 11:57 Go to previous messageGo to next message
Member
Any idea on this?
KKP
Re: Reg: Masterpage in pdf files [message #776983 is a reply to message #776859] Mon, 09 January 2012 15:56 Go to previous message
Jason Weathersby is currently offline Jason WeathersbyFriend
Can you post a report that uses the sample db that shows the issue?
Jason
On 1/9/2012 6:57 AM, kkp Mising name wrote:
> Any idea on this?
> KKP
Previous Topic:slight lag when running first report
Next Topic:Displaying a trademark symbol!
Current Time: Sat May 26 02:41:55 GMT 2018
Powered by FUDForum. Page generated in 0.01926 seconds
