Home » Eclipse Projects » BIRT » Report parameters not retaining default value
Report parameters not retaining default value [message #769983] Fri, 23 December 2011 02:50 Go to next message
jk_work123 is currently offline jk_work123Friend
I have set up two report parameters : startDate and endDate in my report.
This is linked to the dataset parameters and the query works fine with the parameters.
Issue is that I have set the default value for startDate (as current date) and endDate as (current date -7) via expression. This came up consistently in the prompt when invoking the view. Then just once, I changed the report parameters manually in the prompt.
After that, the parameters are retaining the changed values in the prompt instead of showing the default values when I invoke the viewer.
Is there something I can do to reset the parameters to default?
thanks!
Re: Report parameters not retaining default value [message #771592 is a reply to message #769983] Tue, 27 December 2011 17:44 Go to previous message
Jason Weathersby is currently offline Jason WeathersbyFriend
If you are in the designer it saves the last parameter values when you
select the preview tab. If you select view report in Web Viewer from
the toolbar, it should prompt for the parameters with your expressions.
Jason
> the parameters.
> changed the report parameters manually in the prompt. After that, the
> thanks!
Previous Topic:Get Default item of a SelectionList
Next Topic:Column sum based on another column
Current Time: Sun Feb 18 07:25:40 GMT 2018
Powered by FUDForum. Page generated in 0.01940 seconds
