Home » Eclipse Projects » BIRT » Moving Reports into Production
Moving Reports into Production [message #765929] Wed, 14 December 2011 23:08 Go to next message
suneetshah2000 is currently offline suneetshah2000Friend
I have created a number of reports using the BIRT/Eclipse plugin. While creating these reports I created a connection profile and set my database connectivity passwords using eclipse.
I need to move these to production and will have to update my connection profile to include the new database/drivers/and credentials. I won't have eclipse in that environment. How can I update this information without Eclipse?
thanks for your help
Re: Moving Reports into Production [message #766337 is a reply to message #765929] Thu, 15 December 2011 15:16 Go to previous message
Jason Weathersby is currently offline Jason WeathersbyFriend
If you did not encrypt the connection profile you can use a text editor.
If you did you need to use the command line tool provided by DTP. To
read about the console tool look at:
Select Help -> Help Contents from the designer command menu. Then in
the Help window, select the content in
"Data Tools Platform User Documentation" -> "Creating a Connection
Profile" -> "Editing Connection Profile Properties" -> "Console Editor
Application".
Jason
On 12/14/2011 6:08 PM, suneetshah2000 wrote:
> Hello,
> without Eclipse?
Previous Topic:BIRT cause out of memory permgen space
Next Topic:Determine size of extended item
Current Time: Thu Apr 26 00:15:45 GMT 2018
Powered by FUDForum. Page generated in 0.01870 seconds
