Home » Eclipse Projects » BIRT » How to use some variable in Report Parameter input before starting report?
How to use some variable in Report Parameter input before starting report? [message #765014] Tue, 13 December 2011 09:02 Go to next message
mkrivic Mising name is currently offline mkrivic Mising nameFriend
Member
Is there possible to get some variable from BIRT dataset, and then use it as default value in Report Parameters input on starting report?
For example:
On somehow, I must get current user before starting report, and based on the user name, I must populate another parameter list box with method getSelectionParameterList.
If there is a method about getting user details in BIRT, it would be nice.
[Updated on: Tue, 13 December 2011 09:03]
Report message to a moderator
Re: How to use some variable in Report Parameter input before starting report? [message #765253 is a reply to message #765014] Tue, 13 December 2011 17:43 Go to previous message
Jason Weathersby is currently offline Jason WeathersbyFriend
Sure you should be able to retrieve session variables like:
reportContext.getHttpServletRequest().getSession().getAttribute(..);
As long as you have the user name in a session/request variable.
Jason
On 12/13/2011 4:02 AM, mkrivic wrote:
> For example:
Previous Topic:Output issue with Flat file
Next Topic:Problem with date params
Current Time: Tue May 22 10:22:38 GMT 2018
Powered by FUDForum. Page generated in 0.01820 seconds
