Home » Eclipse Projects » BIRT » Birt Runtime Error(Birt Runtime Error (web))
Birt Runtime Error [message #764610] Mon, 12 December 2011 14:23 Go to next message
magd is currently offline magdFriend
Dear All ,
I have Error in Birt Run-time (web Part)
When I use it to view My Reports .
I am using Tomcat application server
note : The image of Error appears in my Uploaded image.
  • Attachment: Birt.png
    (Size: 127.74KB, Downloaded 140 times)
[Updated on: Mon, 12 December 2011 14:26]
Report message to a moderator
Re: Birt Runtime Error [message #764707 is a reply to message #764610] Mon, 12 December 2011 17:51 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Do you have cookies enabled?
Jason
On 12/12/2011 9:23 AM, magd wrote:
> Dear All ,
> When I tried view My Report
> note : The Error appears in my Uploaded image
> Thanks
Re: Birt Runtime Error [message #765299 is a reply to message #764707] Tue, 13 December 2011 20:02 Go to previous messageGo to next message
yes the cookies are enabled
Re: Birt Runtime Error [message #765301 is a reply to message #765299] Tue, 13 December 2011 20:05 Go to previous messageGo to next message
Please see the uploaded image because it show the Error.
Magd
Re: Birt Runtime Error [message #765737 is a reply to message #765301] Wed, 14 December 2011 15:40 Go to previous messageGo to next message
What app server did you deploy the viewer on? Is it behind a proxy?
Try using the /run mapping instead of the /frameset mapping as a test.
Jason
> Magd
Re: Birt Runtime Error [message #765820 is a reply to message #765737] Wed, 14 December 2011 18:20 Go to previous messageGo to next message
I use Tomcat application server
it is not behind proxy
[Updated on: Wed, 14 December 2011 18:22]
Re: Birt Runtime Error [message #765835 is a reply to message #765820] Wed, 14 December 2011 18:45 Go to previous messageGo to next message
The Run mode is not working
The frame-set mode is not working
The preview mode is working successfully
To you MR Jason
Re: Birt Runtime Error [message #766329 is a reply to message #765835] Thu, 15 December 2011 15:03 Go to previous messageGo to next message
How did you deploy the viewer? Can you try just copying the
WebViewerExample folder to tomcat's webapps directory?
Jason
> Thanks
> To you MR Jason
Re: Birt Runtime Error [message #766888 is a reply to message #766329] Fri, 16 December 2011 15:48 Go to previous messageGo to next message
yes I did
Re: Birt Runtime Error [message #766923 is a reply to message #766888] Fri, 16 December 2011 16:51 Go to previous messageGo to next message
I have not seen this error on any version of tomcat. What os and
browser are you using?
Jason
On 12/16/2011 10:48 AM, magd wrote:
> yes I did
Re: Birt Runtime Error [message #766993 is a reply to message #766923] Fri, 16 December 2011 20:06 Go to previous messageGo to next message
Firefox
and
Google chrome is view this error
Re: Birt Runtime Error [message #767053 is a reply to message #766993] Fri, 16 December 2011 23:30 Go to previous messageGo to next message
What os?
Jason
On 12/16/2011 3:07 PM, magd wrote:
> Firefox
> and
Re: Birt Runtime Error [message #767297 is a reply to message #767053] Sat, 17 December 2011 15:42 Go to previous messageGo to next message
windows 7
Re: Birt Runtime Error [message #767579 is a reply to message #767297] Sun, 18 December 2011 11:47 Go to previous messageGo to next message
what is most OS you like to use it ?
[Updated on: Sun, 18 December 2011 11:47]
Re: Birt Runtime Error [message #768124 is a reply to message #767579] Mon, 19 December 2011 16:07 Go to previous messageGo to next message
Win 7, should be fine. I am running the viewer on tomcat on win 7. Do
you get anything in the tomcat logs?
Jason
On 12/18/2011 6:47 AM, magd wrote:
> what is most os you like to use it ?
Re: Birt Runtime Error [message #768164 is a reply to message #768124] Mon, 19 December 2011 17:25 Go to previous messageGo to next message
yes , I get data in Tomcat logs
Re: Birt Runtime Error [message #768165 is a reply to message #768164] Mon, 19 December 2011 17:27 Go to previous messageGo to next message
I don't get any thing in Birt logs files.
Do you get any thing in Birt logs ?
Re: Birt Runtime Error [message #768328 is a reply to message #768165] Mon, 19 December 2011 23:07 Go to previous messageGo to next message
Only if I set the log level in the web.xml of the viewer.
Jason
On 12/19/2011 12:28 PM, magd wrote:
> I don't get any thing in Birt logs files. Do you get any thing in Birt
> logs ?
Re: Birt Runtime Error [message #768657 is a reply to message #768328] Tue, 20 December 2011 15:02 Go to previous messageGo to next message
The problem is getting empty files in Birt log.
what is solution in this problem?
Re: Birt Runtime Error [message #768703 is a reply to message #768657] Tue, 20 December 2011 16:23 Go to previous messageGo to next message
Do you get this error with Fire Fox and IE or just Chrome.
Jason
Re: Birt Runtime Error [message #768780 is a reply to message #768703] Tue, 20 December 2011 19:31 Go to previous messageGo to next message
firefox and google chrome
make this problem
firefox create lck file
chrome create text file
Re: Birt Runtime Error [message #768831 is a reply to message #768780] Tue, 20 December 2011 22:20 Go to previous messageGo to next message
I do not know why this is happening on a vanilla viewer install. Can
you try a different version of Tomcat as a test?
Jason
> make this problem
Re: Birt Runtime Error [message #769162 is a reply to message #768831] Wed, 21 December 2011 14:01 Go to previous messageGo to next message
This problem happened when
I use birt viewer 2.6 and birt viewer 3.7
Re: Birt Runtime Error [message #769688 is a reply to message #769162] Thu, 22 December 2011 14:37 Go to previous messageGo to next message
can I use log4j to avoid this problem ?
Re: Birt Runtime Error [message #769746 is a reply to message #769688] Thu, 22 December 2011 16:12 Go to previous messageGo to next message
I do not think this is a logging issue. Did you try a different version
of tomcat?
Jason
Re: Birt Runtime Error [message #769843 is a reply to message #769746] Thu, 22 December 2011 19:30 Go to previous messageGo to next message
I tried different types of tomcat version
but I face this problem on all tomcat versions
Re: Birt Runtime Error [message #770518 is a reply to message #769843] Sat, 24 December 2011 14:09 Go to previous messageGo to next message
also I tried to put log4j jar files
in platform
but I still facing this problem
Re: Birt Runtime Error [message #770843 is a reply to message #770518] Sun, 25 December 2011 14:31 Go to previous messageGo to next message
what do you think about this problem jason?
Re: Birt Runtime Error [message #771586 is a reply to message #770518] Tue, 27 December 2011 17:31 Go to previous message
I do not know what the issue is. Can you show me your setup on Skype?
Jason
> in platform but I still facing this problem
Previous Topic:Is there support for Word and Excel output formats in the BIRT API?
Next Topic:Get Default item of a SelectionList
Current Time: Sun May 27 19:59:29 GMT 2018
Powered by FUDForum. Page generated in 0.03759 seconds
