All in one | Eclipse for Birt [message #764258] |
Sun, 11 December 2011 19:29 |
singlepoint  Messages: 4 Registered: December 2011 |
Junior Member |
Hi jason,
I am missing org.eclipse.birt.php.birtengine.BirtEngine. I am using birt all in one eclipse download, designed a report, deployed BirtViewer in Tomcat and ran the report, all worked fine. But I wanted to run the report from php so obviously I headed for php/java bridge. Deplyed the JavaBridge.war as you told in your article in Tomcat. But when I try to call the report from php (xampp) it's giving me this error that org.eclipse.birt.php.birtengine.BirtEngine is not found. Can you please tell me what I am doing wrong. This is the exception
Uncaught [[o:Exception]:"java.lang.Exception: ReferenceClass failed: new org.eclipse.birt.php.birtengine.BirtEngine. Cause: java.lang.ClassNotFoundException: org.eclipse.birt.php.birtengine.BirtEngine VM: 1.6.0_20
It seems like as if I am missing to set up some environment variable please help !
FUDForum. Page generated in 0.01588 seconds
