Home » Eclipse Projects » BIRT » Determine size of extended item(Need to determine size of parent cell containing my extended item)
Determine size of extended item [message #764231] Sun, 11 December 2011 18:12 Go to next message
Thomas Weinstein is currently offline Thomas WeinsteinFriend
I've implemented my first extended item following the "rotated label" tutorial.
For rendering I use the simple image approach described there.
Works well but I have one remaining problem:
I want to use the item in a report table.
At the moment it renders with a fixed size which can be set using a custom property I've implemented. But what I really need is to render it dynamically so it fills the cell of the table. I can't find any api to access the width of the parent container my item is contained in.
Thank you very mutch for any idea.
Re: Determine size of extended item [message #764693 is a reply to message #764231] Mon, 12 December 2011 17:28 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Thomas,
It may be a good idea to log an enhancement request for this. If the
designer does not specifically set the width/height getting the parent
dimensions will just return null. For example assume I have the rotated
text in a cell in a grid and I have set the column width in the report.
I can get the size like:
public Object onRowSets( IBaseResultSet[] results ) throws BirtException
if ( textItem == null )
return null;
Object myParent = content.getParent().getParent().getParent();
CellContent myCell = (CellContent) content.getParent();
int colnumber = myCell.getColumn();
if( myParent instanceof TableContent){
TableContent tc = (TableContent) myParent;
Column mycol = (Column) tc.getColumns().get(colnumber);
ColumnDesign coldes = (ColumnDesign) mycol.getGenerateBy();
DimensionType mywid = coldes.getWidth();
But if it is auto-sized the width will return null.
Jason
> tutorial.
Re: Determine size of extended item [message #764955 is a reply to message #764693] Tue, 13 December 2011 06:54 Go to previous messageGo to next message
Hi Jason,
thank you very much for your quick response.
I used your code like that:
    private int getParentLengthInPixels( IRowSet[] rowSets )
        CellContent myCell = (CellContent)content.getParent();
        if ( myParent instanceof TableBandContent )
            myParent = ((TableBandContent)myParent).getParent();
        if ( myParent instanceof TableContent )
            TableContent tc = (TableContent)myParent;
            Column mycol = (Column)tc.   getColumns().get( colnumber );
            ColumnDesign coldes = (ColumnDesign)mycol.getGenerateBy();
            System.out.println( "mywid=" + mywid ); // This gives e.g. 21%
            int res = mywid != null ? (int)mywid.convertTo( DimensionType.UNITS_PX ) : -1;
            System.out.println( "res=" + res );
            return res;
        return -1;
The width is not null but e.g. 21%.
But now I have to convert to pixels to render my image.
But when I use the conversion above I get an exception:
java.lang.IllegalArgumentException: "targetUnits"must be one of the absolute units(CM, IN, MM, PT, PC).
So it seems I cannot convert to pixels using convertTo ??
Do you have any idea how I can get pixels?
Best Regards
Thomas
Re: Determine size of extended item [message #765240 is a reply to message #764955] Tue, 13 December 2011 17:21 Go to previous messageGo to next message
Thomas,
What happens if you set the width of the column in a fixed size instead
of %?
Jason
On 12/13/2011 1:54 AM, Thomas Weinstein wrote:
> Hi Jason,
> : -1;
> return res;
> return -1;
> The width is not null but e.g. 21%. But now I have to convert to pixels
> to render my image.
> Best Regards
> Thomas
Re: Determine size of extended item [message #766050 is a reply to message #765240] Thu, 15 December 2011 06:22 Go to previous messageGo to next message
Hi Jason,
I was two days away so I could not test.
But even if this works it will not solve my problem, because the rptdesign file is generated based on a template and report description outside of BIRT. This report description allows only relative widths for columns.
Is there a way I can determine the width and resolution of the render target in pixels or in cm?
Thomas,
of %?
Jason
Re: Determine size of extended item [message #766338 is a reply to message #766050] Thu, 15 December 2011 15:19 Go to previous message
I do not know of a way to do it. If you generate html directly from the
designer (ie not using frameset) you can look at the html generated by
view source. You will see there is no absolute sizes generated unless
you specify an absolute size in the designer.
Jason
On 12/15/2011 1:23 AM, Thomas Weinstein wrote:
> Hi Jason,
> I was two days away so I could not test. But even if this works it will
> Quote:
>> Thomas,
>> instead of %?
>> Jason
Previous Topic:Moving Reports into Production
Next Topic:How to embed a link into object?
Current Time: Fri Jan 19 00:12:00 GMT 2018
Powered by FUDForum. Page generated in 0.01624 seconds
