| Missing required plug-ins for RCP application with BIRT [message #763831] |
Sat, 10 December 2011 12:28  |
Timothy Vogel Messages: 56 Registered: July 2009 |
Member |
I am unable to get a sample RCP application with BIRT to run. The goal is to have an RCP application with the set of plug-ins needed for a simple report and no other plug-ins (designer, chart, etc).
When I run the setup below from the IDE, it produces pages of missing bundle errors. I have tried modifying the target and product files to have all the features in the 3.7.1 framework with similar errors.
My setup
- A product plugin with
--target file that has RCP feature and the org.eclipse.birt feature from the 3.7.1 framework download
--a product file that includes the RCP feature, org.eclipse.birt feature and my example feature
- my java plug-in project with
--application based on sample RCP with a view
--modified view with a call to WebView.display() to show the report
--a simple class that has 3 String getters used on the report
--a simple report that uses scripting. This report shows properly in the Preview tab.
Can anyone help me understand the right set of BIRT plug-ins to get this working?
[Updated on: Sat, 10 December 2011 12:32] Report message to a moderator
| Re: Missing required plug-ins for RCP application with BIRT [message #764660 is a reply to message #763831] |
Mon, 12 December 2011 10:55  |
Jason Weathersby Messages: 9167 Registered: July 2009 |
The issue is most likely that you need some of the BIRT framework
plugins in addition to dtp and emf plugins. Look at the list in this post:
http://www.birt-exchange.org/org/devshare/deploying-birt-reports/1194-eclipse-product-configuration-file-for-webviewer-in-rcp/
This was done with an older version of BIRT but I believe it still
works. In the post is a link to the app that uses the Hello World RCP
app with BIRT viewer integrated.
Jason
> My setup
> Preview tab.
> working?
Jason Weathersby
BIRT Exchange
FUDForum. Page generated in 0.01454 seconds
