Home » Eclipse Projects » BIRT » Warnings when rendering chart to svg
Warnings when rendering chart to svg [message #761893] Wed, 07 December 2011 08:48 Go to next message
js Missing name is currently offline js Missing nameFriend
Member
When I render my chart to svg using the birt api (3.7) I get all these warnings:
07-12-2011 09:40:50 org.eclipse.birt.chart.device.svg.SVGInteractiveRenderer groupPrimitive
WARNING: !exception.missing.component.interaction!
07-12-2011 09:40:50 org.eclipse.birt.chart.device.svg.SVGInteractiveRenderer ungroupPrimitive
any ideas?
Re: Warnings when rendering chart to svg [message #762245 is a reply to message #761893] Wed, 07 December 2011 18:54 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Are you using the chart engine api or the report engine api? If you are
using the chart engine api are you setting this property?
idr.setProperty( IDeviceRenderer.UPDATE_NOTIFIER,
new EmptyUpdateNotifier( cm, gcs.getChartModel( ) ) );
Jason
> warnings:
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> any ideas?
Re: Warnings when rendering chart to svg [message #762847 is a reply to message #762245] Thu, 08 December 2011 17:41 Go to previous messageGo to next message
Member
I am using the chart engine. Specifying the option below removes the
warnings but is it good to just ignore those warnings? It seems that
specifying the option does not solve the problem instead its simply not
reported.
"Jason Weathersby" wrote in message news:jbococ$p2r$1@news.eclipse.org...
Jason
> warnings:
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> 07-12-2011 09:40:50
> any ideas?
Re: Warnings when rendering chart to svg [message #762876 is a reply to message #762847] Thu, 08 December 2011 18:46 Go to previous message
You get those warnings when you have chart interactivity features in the
chart model and you do not specify a handler for them. If you use a
show tooltip on the chart is that working?
Jason
> reported.
> Jason
>> warnings:
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> 07-12-2011 09:40:50
>> any ideas?
Previous Topic:vector rendering of svg in pdf
Next Topic:BIRT without Jetty
Current Time: Fri May 25 01:37:32 GMT 2018
Powered by FUDForum. Page generated in 0.02296 seconds
