Home » Eclipse Projects » WindowBuilder » No root methods when designing a class which implements IDetailsPage and extends a bean
No root methods when designing a class which implements IDetailsPage and extends a bean [message #759225] Sun, 27 November 2011 20:03 Go to next message
Roded Bahat is currently offline Roded BahatFriend
I'm working on a Master/Detail page using MasterDetailsBlock & IDetailsPage.
In order to generalize some Details pages, I've created an abstract class which implements the IDetailsPage interface.
Unfortunately, when trying to design classes which extend my abstract class, WindowBuilder claims to not find any root methods. As suggested, I tried using the @wbp.parser.entryPoint but that didn't help much.
Is there a way around this? or am I doing things completely wrong?
Any tips would be great.
Thanks a lot,
Roded
[Updated on: Sun, 27 November 2011 20:26]
Report message to a moderator
Re: No root methods when designing a class which implements IDetailsPage and extends a bean [message #759233 is a reply to message #759225] Sun, 27 November 2011 21:53 Go to previous messageGo to next message
Eric Clayberg is currently offline Eric ClaybergFriend
I would suggest posting a test case.
Re: No root methods when designing a class which implements IDetailsPage and extends a bean [message #759265 is a reply to message #759233] Mon, 28 November 2011 07:36 Go to previous messageGo to next message
An abstract class which implements IDetailsPage:
package testcasedetailspage;
import org.eclipse.ui.forms.IDetailsPage;
public abstract class testcaseabstractclass implements IDetailsPage {
The details page itself (Created using the WindowBuilder "DetailsPage" wizard.
The only change is that "implements IDetailsPage" was changed to "extends testcaseabstractclass"):
import org.eclipse.jface.viewers.ISelection;
import org.eclipse.jface.viewers.IStructuredSelection;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.ui.forms.IFormPart;
import org.eclipse.ui.forms.IManagedForm;
import org.eclipse.ui.forms.widgets.ExpandableComposite;
import org.eclipse.ui.forms.widgets.FormToolkit;
import org.eclipse.ui.forms.widgets.Section;
public class testcasedetailspage extends testcaseabstractclass {
	private IManagedForm managedForm;
	 * Create the details page.
	public testcasedetailspage() {
		// Create the details page
	 * Initialize the details page.
	 * @param form
	public void initialize(IManagedForm form) {
		managedForm = form;
	 * Create contents of the details page.
	 * @param parent
	public void createContents(Composite parent) {
		FormToolkit toolkit = managedForm.getToolkit();
		parent.setLayout(new FillLayout());
		Section section = toolkit.createSection(parent,
				ExpandableComposite.EXPANDED | ExpandableComposite.TITLE_BAR);
		section.setText("Empty Section");
		Composite composite = toolkit.createComposite(section, SWT.NONE);
		toolkit.paintBordersFor(composite);
		section.setClient(composite);
	public void dispose() {
		// Dispose
	public void setFocus() {
		// Set focus
	private void update() {
		// Update
	public boolean setFormInput(Object input) {
		return false;
	public void selectionChanged(IFormPart part, ISelection selection) {
		IStructuredSelection structuredSelection = (IStructuredSelection) selection;
		update();
	public void commit(boolean onSave) {
		// Commit
	public boolean isDirty() {
		return false;
	public boolean isStale() {
		return false;
	public void refresh() {
		update();
The same thing happens when the class extends the abstract class and implements IDetailsPage.
Reverting the change back to the original "implements" makes the design view work again.
Would appreciate any help.
Roded
[Updated on: Mon, 28 November 2011 07:40]
Re: No root methods when designing a class which implements IDetailsPage and extends a bean [message #759455 is a reply to message #759265] Mon, 28 November 2011 17:49 Go to previous messageGo to next message
Worked it out by having the abstract class implement all IDetailsPage methods, making it editable in WB as well as its subclasses.
Thanks.
Re: No root methods when designing a class which implements IDetailsPage and extends a bean [message #759658 is a reply to message #759265] Tue, 29 November 2011 14:17 Go to previous message
Konstantin Scheglov is currently offline Konstantin ScheglovFriend
This was fixed in trunk.
Konstantin Scheglov,
Google, Inc.
Previous Topic:Swing JFrame vs Application Window templates
Next Topic:Newbie question
Current Time: Wed May 23 20:56:55 GMT 2018
Powered by FUDForum. Page generated in 0.02254 seconds
