Home » Eclipse Projects » BIRT » Cannot open connection(Cannot open the connection for the driver: org.eclipse.birt.report.data.oda.jdbc.dbprofile)
Cannot open connection [message #758214] Tue, 22 November 2011 06:09 Go to next message
Emmanuel  is currently offline Emmanuel
I can view the report in Eclipse but I have this message when i deploy it on tomcat.
I read a lot of post but did not find any solution to my trouble and I am using direct connection.
Manu
the message is
- An exception occurred during processing. Please see the following message for details:
Cannot open the connection for the driver: org.eclipse.birt.report.data.oda.jdbc.dbprofile.
org.eclipse.datatools.connectivity.oda.OdaException ;
java.lang.IllegalStateException: Unable to determine the default workspace location. Check your OSGi-less platform configuration of the plugin or datatools workspace path. (Element ID:163) exception.error ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: An exception occurred during processing. Please see the following message for details:
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1214)
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1193)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:96)
at org.eclipse.birt.report.engine.executor.TableItemExecutor.execute(TableItemExecutor.java:62)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:34)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:180)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:929)
at org.eclipse.birt.report.service.BirtViewerReportService.runAndRenderReport(BirtViewerReportService.java:973)
at org.eclipse.birt.report.service.actionhandler.BirtRunAndRenderActionHandler.__execute(BirtRunAndRenderActionHandler.java:76)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.presentation.aggregation.layout.EngineFragment.doService(EngineFragment.java:318)
at org.eclipse.birt.report.presentation.aggregation.AbstractBaseFragment.service(AbstractBaseFragment.java:76)
at org.eclipse.birt.report.servlet.BirtEngineServlet.__doGet(BirtEngineServlet.java:120)
at org.eclipse.birt.report.servlet.BaseReportEngineServlet.doGet(BaseReportEngineServlet.java:185)
at org.eclipse.birt.report.servlet.BaseReportEngineServlet.doPost(BaseReportEngineServlet.java:224)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:641)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:722)
at org.eclipse.birt.report.servlet.BaseReportEngineServlet.service(BaseReportEngineServlet.java:116)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:304)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerFilter.java:68)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:224)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:185)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:151)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:100)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:929)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:405)
at org.apache.coyote.http11.Http11AprProcessor.process(Http11AprProcessor.java:269)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:515)
at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:1773)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: org.eclipse.birt.report.data.adapter.api.AdapterException: An exception occurred during processing. Please see the following message for details:
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.execute(DataRequestSessionImpl.java:640)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteQuery(DteDataEngine.java:152)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:267)
at org.eclipse.birt.report.engine.executor.ExecutionContext.executeQuery(ExecutionContext.java:1905)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:80)
... 41 more
Caused by: org.eclipse.birt.data.engine.odaconsumer.OdaDataException: Cannot open the connection for the driver: org.eclipse.birt.report.data.oda.jdbc.dbprofile.
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.newException(ExceptionHandler.java:54)
at org.eclipse.birt.data.engine.odaconsumer.ConnectionManager.openConnection(ConnectionManager.java:177)
at org.eclipse.birt.data.engine.executor.DataSource.newConnection(DataSource.java:224)
at org.eclipse.birt.data.engine.executor.DataSource.open(DataSource.java:212)
at org.eclipse.birt.data.engine.impl.DataSourceRuntime.openOdiDataSource(DataSourceRuntime.java:217)
at org.eclipse.birt.data.engine.impl.QueryExecutor.openDataSource(QueryExecutor.java:407)
at org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecution(QueryExecutor.java:317)
at org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(PreparedQuery.java:455)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.produceQueryResults(PreparedDataSourceQuery.java:190)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.execute(PreparedDataSourceQuery.java:178)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery.execute(PreparedOdaDSQuery.java:145)
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.execute(DataRequestSessionImpl.java:620)
... 45 more
Caused by: org.eclipse.datatools.connectivity.oda.OdaException ;
at org.eclipse.birt.report.data.oda.jdbc.dbprofile.impl.Connection.open(Connection.java:118)
at org.eclipse.birt.report.data.oda.jdbc.dbprofile.impl.Connection.open(Connection.java:62)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaConnection.open(OdaConnection.java:250)
at org.eclipse.birt.data.engine.odaconsumer.ConnectionManager.openConnection(ConnectionManager.java:165)
... 55 more
Caused by: java.lang.IllegalStateException: Unable to determine the default workspace location. Check your OSGi-less platform configuration of the plugin or datatools workspace path.
at org.eclipse.datatools.connectivity.internal.ConnectivityPlugin.getDefaultStateLocation(ConnectivityPlugin.java:154)
at org.eclipse.datatools.connectivity.drivers.DriverManager.wereDefaultDriversCreated(DriverManager.java:518)
at org.eclipse.datatools.connectivity.drivers.DriverManager.resetDefaultInstances(DriverManager.java:594)
at org.eclipse.datatools.connectivity.drivers.DriverManager.<init>(DriverManager.java:117)
at org.eclipse.datatools.connectivity.drivers.DriverManager.getInstance(DriverManager.java:62)
at org.eclipse.datatools.connectivity.DriverConnectionBase.getDriverDefinition(DriverConnectionBase.java:136)
at org.eclipse.datatools.connectivity.drivers.jdbc.JDBCConnection.createConnection(JDBCConnection.java:177)
at org.eclipse.datatools.connectivity.drivers.jdbc.JDBCConnection.internalCreateConnection(JDBCConnection.java:141)
at org.eclipse.datatools.connectivity.drivers.jdbc.JDBCConnection.open(JDBCConnection.java:97)
at org.eclipse.datatools.enablement.internal.mysql.connection.JDBCMySQLConnectionFactory.createConnection(JDBCMySQLConnectionFactory.java:28)
at org.eclipse.datatools.connectivity.internal.ConnectionFactoryProvider.createConnection(ConnectionFactoryProvider.java:83)
at org.eclipse.datatools.connectivity.internal.ConnectionProfile.createConnection(ConnectionProfile.java:359)
at org.eclipse.datatools.connectivity.sqm.internal.core.connection.ConnectionInfoImpl.initializeJDBCConnection(ConnectionInfoImpl.java:659)
at org.eclipse.datatools.connectivity.sqm.internal.core.connection.ConnectionInfoImpl.<init>(ConnectionInfoImpl.java:644)
at org.eclipse.datatools.connectivity.sqm.internal.core.connection.ConnectionFactory.createConnection(ConnectionFactory.java:38)
at org.eclipse.datatools.connectivity.sqm.core.SQMConnectionFactory.createConnection(SQMConnectionFactory.java:45)
at org.eclipse.datatools.connectivity.sqm.internal.core.connection.ConnectionFactory.createConnection(ConnectionFactory.java:59)
at org.eclipse.datatools.connectivity.internal.ConnectionFactoryAdapterProvider.createConnection(ConnectionFactoryAdapterProvider.java:114)
at org.eclipse.datatools.connectivity.internal.ManagedConnection.createConnection(ManagedConnection.java:163)
at org.eclipse.datatools.connectivity.internal.CreateConnectionJob.run(CreateConnectionJob.java:56)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Re: Cannot open connection [message #758316 is a reply to message #758214] Tue, 22 November 2011 12:16 Go to previous message
Jason Weathersby is currently offline Jason Weathersby
Are you using BIRT 3.7 or greater? It looks like you are using a
connection profile. Try entering the jdbc connection parameters in the
jdbc data source without using a profile.
If you want to use a connection profile you have to set a dtp workspace
env variable:
http://wiki.eclipse.org/Birt_3.7_Migration_Guide#Connection_Profiles
Jason
On 11/22/2011 6:09 AM, Emmanuel wrote:
> Hello,
> it on tomcat.
> Regards
> Manu
> the message is
> time(s) )
> for details:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> for details:
> at
> at
> at
> at
> at
> ... 41 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 45 more
> at
> at
> at
> at
> ... 55 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Jason Weathersby
BIRT Exchange
Previous Topic:Dynamic parameter properties
Next Topic:BIRT header and footer
Current Time: Wed May 22 03:06:43 EDT 2013
Powered by FUDForum. Page generated in 0.01646 seconds
