Home » Archived » Eclipse Process Manager (Stardust) » NullPointerException during first login in on Weblogic(Exception initSessionInfo in Weblogic SessionHelper)
NullPointerException during first login in on Weblogic [message #757518] Fri, 18 November 2011 18:02 Go to next message
Jan Hendrik Scheufen is currently offline Jan Hendrik ScheufenFriend
Member
I'm deploying Stardust in EJB mode and packaged as EAR on Weblogic 10.3. When trying to access the web application in a browser, the log shows the following exception:
                at weblogic.servlet.internal.ServletRequestImpl$SessionHelper.initSessionInfo(ServletRequestImpl.java:2611)
                at weblogic.servlet.internal.ServletRequestImpl$SessionHelper.getSessionInternal(ServletRequestImpl.java:2379)
                at weblogic.servlet.internal.ServletRequestImpl$SessionHelper.getSession(ServletRequestImpl.java:2369)
                at weblogic.servlet.internal.ServletRequestImpl.getSession(ServletRequestImpl.java:1285)
                at javax.servlet.http.HttpServletRequestWrapper.getSession(HttpServletRequestWrapper.java:227)
                at org.apache.myfaces.context.servlet.SessionMap.getSession(SessionMap.java:75)
                at org.apache.myfaces.context.servlet.SessionMap.getAttribute(SessionMap.java:46)
                at org.apache.myfaces.context.servlet.AbstractAttributeMap.get(AbstractAttributeMap.java:91)
                at com.icesoft.faces.context.effects.JavascriptContext.getIncludedLibs(JavascriptContext.java:129)
                at com.infinity.bpm.portal.common.filter.LoginFilter.includeCustomJS(LoginFilter.java:339)
                at com.infinity.bpm.portal.common.filter.LoginFilter.doFilter(LoginFilter.java:244)
It looks like deactivating KeepAlive in WLS for the Oracle database resources solves the issue (it is activated by default for 10g and 11g).
Re: NullPointerException during first login in on Weblogic [message #757519 is a reply to message #757518] Fri, 18 November 2011 18:04 Go to previous messageGo to next message
Member
We've seen similar issues on Weblogic before and deactivating the "KeepAlive" usually solved it.
Re: NullPointerException during first login in on Weblogic [message #985574 is a reply to message #757518] Thu, 15 November 2012 14:03 Go to previous message
Y Wang is currently offline Y WangFriend
We have run into similiar problem recently, changing the keep-alive value solved the problem.
Previous Topic:Build Process
Next Topic:Send activemq message to CarnotApplicationQuque
Current Time: Wed Apr 25 08:47:30 GMT 2018
Powered by FUDForum. Page generated in 0.01724 seconds
