Home » Modeling » TMF (Xtext) » add external jar in xtext ui folder(add external jar in xtext ui folder)
add external jar in xtext ui folder [message #757226] Thu, 17 November 2011 08:50 Go to next message
samir  is currently offline samir Friend
hi
I need to use the GLPK library to to solve contraint. I added the jar from java build path > add external jar
but when I run my application I have this exception :
java.lang.NoClassDefFoundError: org/gnu/glpk/GlpkSolver
at polytime.ui.popup.actions.Interprete.getVarValue(Interprete.java:366)
at polytime.ui.popup.actions.Interprete.typeTerm(Interprete.java:319)
at polytime.ui.popup.actions.Interprete.run(Interprete.java:100)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3588)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3209)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Caused by: java.lang.ClassNotFoundException: org.gnu.glpk.GlpkSolver
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:513)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:266)
... 32 more
thanks
[Updated on: Thu, 17 November 2011 08:56]
Report message to a moderator
Re: add external jar in xtext ui folder [message #757236 is a reply to message #757226] Thu, 17 November 2011 09:46 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
hi,
did you add the jar to a folder within the plugin project, and added the dependency to the manifest (classpath section)
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: https://xtext.itemis.com
Twitter : @chrdietrich
Blog : https://www.dietrich-it.de
Re: add external jar in xtext ui folder [message #757248 is a reply to message #757236] Thu, 17 November 2011 10:40 Go to previous messageGo to next message
Can you explain in more detail,
Re: add external jar in xtext ui folder [message #757251 is a reply to message #757248] Thu, 17 November 2011 10:54 Go to previous messageGo to next message
(1) Open Manifest File
(2) Go to the runtime tab
(3) search the Classpath section
(4) hit the add button
Re: add external jar in xtext ui folder [message #757255 is a reply to message #757251] Thu, 17 November 2011 11:20 Go to previous messageGo to next message
I added a folder in ui ,where I put the jar, and I add the dependency to the manifest, but when I run it throws this exception
!SESSION 2011-11-17 04:15:30.857 -----------------------------------------------
eclipse.buildId=M20110909-1335
java.version=1.6.0_20
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=it_IT
Framework arguments: -product org.eclipse.sdk.ide
Command-line arguments: -product org.eclipse.sdk.ide -data /home/rachid/workspace/../runtime-EclipseApplication -dev file:/home/rachid/workspace/.metadata/.plugins/org.eclipse.pde.core/Eclipse Application/dev.properties -os linux -ws gtk -arch x86 -consoleLog
!ENTRY org.eclipse.osgi 2 0 2011-11-17 04:15:53.055
!MESSAGE The activator org.xtext.example.mydsl.ui.internal.MyDslActivator for bundle polyTime.ui is invalid
!STACK 0
org.osgi.framework.BundleException: The activator org.xtext.example.mydsl.ui.internal.MyDslActivator for bundle polyTime.ui is invalid
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:171)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:679)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:268)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:236)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1207)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugin.java:268)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:264)
at org.eclipse.ui.internal.registry.EditorDescriptor.createEditor(EditorDescriptor.java:235)
at org.eclipse.ui.internal.EditorManager.createPart(EditorManager.java:875)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:609)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1245)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1198)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1597)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:493)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:479)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:808)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:707)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:666)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2942)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2850)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2842)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2793)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2789)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2773)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2764)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
at org.eclipse.ui.wizards.newresource.BasicNewFileResourceWizard.performFinish(BasicNewFileResourceWizard.java:111)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:827)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:432)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.internal.actions.NewWizardShortcutAction.run(NewWizardShortcutAction.java:135)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
Caused by: java.lang.ClassNotFoundException: org.xtext.example.mydsl.ui.internal.MyDslActivator
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:345)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:164)
... 88 more
Root exception:
!ENTRY org.eclipse.ui 4 0 2011-11-17 04:15:53.068
!MESSAGE Unable to create editor ID org.xtext.example.mydsl.MyDsl: The editor class could not be instantiated. This usually indicates a missing no-arg constructor or that the editor's class name was mistyped in plugin.xml.
!STACK 0
java.lang.ClassNotFoundException: org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory
Re: add external jar in xtext ui folder [message #757258 is a reply to message #757255] Thu, 17 November 2011 11:40 Go to previous messageGo to next message
Are you sure you have a class org.xtext.example.mydsl.ui.internal.MyDslActivator?
~Christian
Re: add external jar in xtext ui folder [message #757259 is a reply to message #757258] Thu, 17 November 2011 11:46 Go to previous messageGo to next message
Meinte Boersma is currently offline Meinte BoersmaFriend
You might want to compare any plugin.xml files with their plugin.xml_gen counterparts and likewise for manifest.mf vs. manifest.mf_gen.
Re: add external jar in xtext ui folder [message #757264 is a reply to message #757258] Thu, 17 November 2011 12:05 Go to previous messageGo to next message
i haven't
Re: add external jar in xtext ui folder [message #757266 is a reply to message #757264] Thu, 17 November 2011 12:15 Go to previous messageGo to next message
If you dont have the activator class you do use configure it in the manifest?
Re: add external jar in xtext ui folder [message #757270 is a reply to message #757266] Thu, 17 November 2011 12:31 Go to previous messageGo to next message
exist a guide for using a jar within xtext project?
Re: add external jar in xtext ui folder [message #757281 is a reply to message #757270] Thu, 17 November 2011 13:19 Go to previous messageGo to next message
i still dont get your problem.
the steps i described work perfectly for me.
this is not xtext specific. this is ordinary plugin development.
~Christian
Re: add external jar in xtext ui folder [message #757290 is a reply to message #757281] Thu, 17 November 2011 14:17 Go to previous messageGo to next message
I did everything you told me, now I also have the class g.xtext.example.mydsl.ui.internal.MyDslActivator
but when i run , i have this exception
!SESSION 2011-11-17 07:14:47.084 -----------------------------------------------
!ENTRY org.eclipse.osgi 2 0 2011-11-17 07:15:01.430
!STACK 0
at org.eclipse.xtext.internal.ResourceServiceProviderDescriptor.get(ResourceServiceProviderDescriptor.java:40)
at org.eclipse.xtext.internal.ResourceServiceProviderDescriptor.get(ResourceServiceProviderDescriptor.java:1)
at org.eclipse.xtext.resource.impl.ResourceServiceProviderRegistryImpl$InternalData.getServiceProvider(ResourceServiceProviderRegistryImpl.java:40)
at org.eclipse.xtext.resource.impl.ResourceServiceProviderRegistryImpl.getResourceServiceProvider(ResourceServiceProviderRegistryImpl.java:75)
at org.eclipse.xtext.resource.impl.ResourceServiceProviderRegistryImpl.getResourceServiceProvider(ResourceServiceProviderRegistryImpl.java:91)
at org.eclipse.xtext.ui.resource.UriValidator.isValid(UriValidator.java:27)
at org.eclipse.xtext.ui.resource.Storage2UriMapperImpl.isValidUri(Storage2UriMapperImpl.java:99)
at org.eclipse.xtext.ui.resource.Storage2UriMapperImpl.getUri(Storage2UriMapperImpl.java:83)
at org.eclipse.xtext.builder.impl.ToBeBuiltComputer.getUri(ToBeBuiltComputer.java:154)
at org.eclipse.xtext.builder.impl.ToBeBuiltComputer.updateStorage(ToBeBuiltComputer.java:121)
at org.eclipse.xtext.builder.impl.ToBeBuiltComputer$2.visit(ToBeBuiltComputer.java:107)
at org.eclipse.core.internal.resources.Resource$2.visit(Resource.java:106)
at org.eclipse.core.internal.resources.Resource$1.visitElement(Resource.java:65)
at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:82)
at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:86)
at org.eclipse.core.internal.watson.ElementTreeIterator.iterate(ElementTreeIterator.java:127)
at org.eclipse.core.internal.resources.Resource.accept(Resource.java:75)
at org.eclipse.core.internal.resources.Resource.accept(Resource.java:104)
at org.eclipse.core.internal.resources.Resource.accept(Resource.java:88)
at org.eclipse.xtext.builder.impl.ToBeBuiltComputer.updateProject(ToBeBuiltComputer.java:102)
at org.eclipse.xtext.builder.impl.javasupport.JdtToBeBuiltComputer.updateProject(JdtToBeBuiltComputer.java:84)
at org.eclipse.xtext.builder.impl.XtextBuilder.fullBuild(XtextBuilder.java:182)
at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:85)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:728)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
... 46 more
Root exception:
0 [Worker-1] ERROR org.eclipse.xtext.internal.ResourceServiceProviderDescriptor - Plug-in polyTime.ui was unable to load class org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory.
org.eclipse.core.runtime.CoreException: Plug-in polyTime.ui was unable to load class org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory.
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:176)
Caused by: java.lang.ClassNotFoundException: org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory
... 38 more
!ENTRY org.eclipse.osgi 2 0 2011-11-17 07:15:06.864
!STACK 0
at org.eclipse.xtext.builder.impl.RegistryBuilderParticipant$BuilderParticipantReader.readElement(RegistryBuilderParticipant.java:102)
at org.eclipse.emf.ecore.plugin.RegistryReader.internalReadElement(RegistryReader.java:123)
at org.eclipse.emf.ecore.plugin.RegistryReader.readRegistry(RegistryReader.java:93)
at org.eclipse.xtext.builder.impl.RegistryBuilderParticipant.initParticipants(RegistryBuilderParticipant.java:80)
at org.eclipse.xtext.builder.impl.RegistryBuilderParticipant.getParticipants(RegistryBuilderParticipant.java:67)
at org.eclipse.xtext.builder.impl.RegistryBuilderParticipant.build(RegistryBuilderParticipant.java:52)
at org.eclipse.xtext.builder.impl.XtextBuilder.doBuild(XtextBuilder.java:160)
at org.eclipse.xtext.builder.impl.XtextBuilder.fullBuild(XtextBuilder.java:183)
... 32 more
Root exception:
5425 [Worker-1] ERROR org.eclipse.xtext.builder.impl.RegistryBuilderParticipant$BuilderParticipantReader - Plugin polyTime.ui, extension org.eclipse.xtext.builder.participant
5425 [Worker-1] ERROR org.eclipse.xtext.builder.impl.RegistryBuilderParticipant$BuilderParticipantReader - Plug-in polyTime.ui was unable to load class org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory.
5425 [Worker-1] ERROR org.eclipse.xtext.builder.impl.RegistryBuilderParticipant$BuilderParticipantReader - Error processing extension: org.eclipse.core.internal.registry.ConfigurationElementHandle@2e88
Re: add external jar in xtext ui folder [message #757295 is a reply to message #757290] Thu, 17 November 2011 14:53 Go to previous messageGo to next message
Here is what i do
(1) create a new Project with the wizard
(2) generate the language
(3) create a test jar with a Test class
package test;
public class Test {
	public static void sayHello() {
		System.out.println("Hello World!");
(4) create a folder lib
(5) place test.jar in the lib folder
(6) edit the manifest file (here is the outcome)
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: org.xtext.example.mydsl.ui
Bundle-Vendor: My Company
Bundle-Version: 1.0.0
Bundle-SymbolicName: org.xtext.example.mydsl.ui; singleton:=true
Bundle-ActivationPolicy: lazy
Require-Bundle: org.xtext.example.mydsl;visibility:=reexport,
 org.eclipse.xtext.ui,
 org.eclipse.ui.editors;bundle-version="3.5.0",
 org.eclipse.ui.ide;bundle-version="3.5.0",
 org.eclipse.xtext.ui.shared,
 org.eclipse.ui,
 org.eclipse.xtext.builder,
 org.antlr.runtime,
 org.eclipse.xtext.common.types.ui,
 org.eclipse.xtext.ui.codetemplates.ui,
 org.eclipse.compare
Import-Package: org.apache.log4j,
 org.apache.commons.logging
Bundle-RequiredExecutionEnvironment: J2SE-1.5
Export-Package: org.xtext.example.mydsl.ui.contentassist.antlr,
Bundle-Activator: org.xtext.example.mydsl.ui.internal.MyDslActivator
Bundle-ClassPath: lib/test.jar,
(7) edit the org.xtext.example.mydsl.ui.internal.MyDslActivator.start(BundleContext)(for test purpose)
	public void start(BundleContext context) throws Exception {
		super.start(context);
		INSTANCE = this;
		try {
			registerInjectorFor("org.xtext.example.mydsl.MyDsl");
		} catch (Exception e) {
			Logger.getLogger(getClass()).error(e.getMessage(), e);
			throw e;
		Test.sayHello();
(Cool run the app, create a new mydsl file and check the console for a message
Re: add external jar in xtext ui folder [message #757299 is a reply to message #757295] Thu, 17 November 2011 15:22 Go to previous message
solved, thanks so much
Previous Topic:[xtend2] import static inner Java classes
Next Topic:preventing use of "open file"
Current Time: Sat Jun 23 10:19:12 GMT 2018
Powered by FUDForum. Page generated in 0.02835 seconds
