Home » Eclipse Projects » BIRT » Drag and Drop function for Bird
Drag and Drop function for Bird [message #756628] Mon, 14 November 2011 14:30 Go to next message
gloeckner.peter is currently offline gloeckner.peterFriend
I'm trying to implement a drag and drop function for bird (rcp and rap) but there are a lot of problems i'm not able to solve.
I'm able to print the pixel the user clicked on relativly to the point in the top left, but i'm not able to compute where the position is relativly to the origin of the graph. Therefore I need to know the size of the Title etc. or the Position of the ClientArea of the Graph but all methods like getWidth or getX don't provide the right values.
On the other hand i have some problems with my triggers Smile .
For example i'm able to show a tooltip when a point is clicked (with the code below) but i have no idea, how to call a function which prints some text when a point is clicked.
<code>
bs1.getTriggers().add(TriggerImpl
.create(TriggerCondition.ONMOUSEDOWN_LITERAL, ActionImpl
.create(ActionType.SHOW_TOOLTIP_LITERAL,
TooltipValueImpl.create(500, null))));
</code>
Thanks for help,
Peter
Re: Drag and Drop function for Bird [message #756680 is a reply to message #756628] Mon, 14 November 2011 16:14 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Peter,
Are you using the chart engine api to run the charts?
Jason
On 11/14/2011 9:30 AM, gloeckner.peter wrote:
> On the other hand i have some problems with my triggers :) .
> <code>
> </code>
> Thanks for help,
> Peter
Re: Drag and Drop function for Bird [message #756699 is a reply to message #756680] Mon, 14 November 2011 17:39 Go to previous messageGo to next message
Yes, I'm using the chart engine.
Re: Drag and Drop function for Bird [message #756757 is a reply to message #756699] Mon, 14 November 2011 23:13 Go to previous messageGo to next message
I am not sure this will help but you can define your own action renderer
for the chart engine like:
gcs = gr.build(dServer, cm, bo, null, null, null);
gcs.getRunTimeContext().setActionRenderer( new MyActionRenderer());
dRenderer.setProperty(IDeviceRenderer.UPDATE_NOTIFIER,
new EmptyUpdateNotifier(cm, gcs.getChartModel()));
Then the action render should extend the ActionRendererAdapter class like:
import org.eclipse.birt.chart.render.ActionRendererAdapter;
import org.eclipse.birt.chart.computation.DataPointHints;
import org.eclipse.birt.chart.event.StructureSource;
import org.eclipse.birt.chart.event.StructureType;
import org.eclipse.birt.chart.factory.IDataRowExpressionEvaluator;
import org.eclipse.birt.chart.model.attribute.ActionType;
import org.eclipse.birt.chart.model.attribute.TooltipValue;
import org.eclipse.birt.chart.model.attribute.URLValue;
import org.eclipse.birt.chart.model.data.Action;
import org.eclipse.birt.chart.util.ChartUtil;
* Simple implementation for IActionRenderer
public class MyActionRenderer extends ActionRendererAdapter {
public void processAction( Action action, StructureSource source )
if ( ActionType.SHOW_TOOLTIP_LITERAL.equals( action.getType( ) ) )
TooltipValue tv = (TooltipValue) action.getValue( );
if ( StructureType.SERIES_DATA_POINT.equals( source.getType( ) ) )
final DataPointHints dph = (DataPointHints) source.getSource( );
String MyToolTip = "My Value is " + dph.getDisplayValue() + "--"
+dph.getBaseDisplayValue();
tv.setText( MyToolTip );
Jason
Re: Drag and Drop function for Bird [message #756884 is a reply to message #756757] Tue, 15 November 2011 12:37 Go to previous messageGo to next message
Unfortunately this doesn't help. I've allready implemented a ActionRenderer. The problem is that the method processAction isn't called wenn a action happens (for example when i am clicking on a data point), it's called consistently.
Peter
Re: Drag and Drop function for Bird [message #756943 is a reply to message #756884] Tue, 15 November 2011 16:07 Go to previous messageGo to next message
I know the chart engine when used within a report can invoke a client
side script when a data point is clicked. I believe you may be able to
setup the chart engine to do this in your app. If you had a simple app
that shows the problem that you could share, we may be able to help.
Jason
> Thanks
> Peter
Re: Drag and Drop function for Bird [message #757005 is a reply to message #756943] Tue, 15 November 2011 23:07 Go to previous messageGo to next message
This are my two classes.
The class SwtLiveChartViewer is copied from a tutorial.
In the class LineChart i am adding the trigger.
When i'm clicking on a point the tooltipp is displayed. In fact i only want to call a function, which i can defined, when the user clicks on a point.
Peter
package org.eclipse.ui.tutorials.rcp.charts;
import org.eclipse.birt.chart.model.Chart;
import org.eclipse.birt.chart.model.ChartWithAxes;
import org.eclipse.birt.chart.model.attribute.AxisType;
import org.eclipse.birt.chart.model.attribute.DataPoint;
import org.eclipse.birt.chart.model.attribute.DataPointComponentType;
import org.eclipse.birt.chart.model.attribute.IntersectionType;
import org.eclipse.birt.chart.model.attribute.LineStyle;
import org.eclipse.birt.chart.model.attribute.TickStyle;
import org.eclipse.birt.chart.model.attribute.TriggerCondition;
import org.eclipse.birt.chart.model.attribute.impl.ColorDefinitionImpl;
import org.eclipse.birt.chart.model.attribute.impl.DataPointComponentImpl;
import org.eclipse.birt.chart.model.attribute.impl.JavaNumberFormatSpecifierImpl;
import org.eclipse.birt.chart.model.attribute.impl.TooltipValueImpl;
import org.eclipse.birt.chart.model.component.Axis;
import org.eclipse.birt.chart.model.component.Series;
import org.eclipse.birt.chart.model.component.impl.SeriesImpl;
import org.eclipse.birt.chart.model.data.NumberDataSet;
import org.eclipse.birt.chart.model.data.SeriesDefinition;
import org.eclipse.birt.chart.model.data.impl.ActionImpl;
import org.eclipse.birt.chart.model.data.impl.NumberDataSetImpl;
import org.eclipse.birt.chart.model.data.impl.SeriesDefinitionImpl;
import org.eclipse.birt.chart.model.data.impl.TriggerImpl;
import org.eclipse.birt.chart.model.impl.ChartWithAxesImpl;
import org.eclipse.birt.chart.model.type.LineSeries;
import org.eclipse.birt.chart.model.type.impl.LineSeriesImpl;
import org.eclipse.swt.widgets.Composite;
public class LineChart extends SwtLiveChartViewer{
public void init(){
xData = new double[2];
yData = new double[2];
xData[0] = 1;
xData[1] = 2;
yData[0] = 1;
yData[1] = 2;
public double[] xData;
public double[] yData;
* std - Konstruktor
* @param parent
* @param style
public LineChart(Composite parent, int style) {
super(parent, style);
* Chart Eigenschaften festlegen
public Chart createChart(){
ChartWithAxes chart = ChartWithAxesImpl.create();
//x-Achse
Axis xAxis = chart.getPrimaryBaseAxes()[0];
xAxis.getTitle().setVisible(false); //Titel
xAxis.getTitle().getCaption().setValue("x");
xAxis.getTitle().getCaption().getFont().setBold(false);
xAxis.getTitle().getCaption().getFont().setSize(11);
xAxis.getTitle().getCaption().getFont().setName("MS Sans Serif");
xAxis.getLabel().setVisible(false); //Achsenbeschriftung
xAxis.getLabel().getCaption().getFont().setSize(20);
xAxis.getLabel().getCaption().getFont().setName("MS Sans Serif");
xAxis.getMajorGrid().setTickStyle(TickStyle.BELOW_LITERAL);
xAxis.setType(AxisType.LINEAR_LITERAL);
xAxis.getOrigin().setType(IntersectionType.VALUE_LITERAL);
xAxis.getScale().setStep(1.0);
//y-Achse
Axis yAxis = ((ChartWithAxes) chart).getPrimaryOrthogonalAxis(xAxis);
yAxis.getTitle().setVisible(false);
yAxis.getTitle().getCaption().setValue("y");
yAxis.getTitle().getCaption().getFont().setBold(false);
yAxis.getTitle().getCaption().getFont().setRotation(90);
yAxis.getTitle().getCaption().getFont().setSize(11);
yAxis.getTitle().getCaption().getFont().setName("MS Sans Serif");
yAxis.getLabel().setVisible(false);
yAxis.getLabel().getCaption().getFont().setSize(8);
yAxis.getLabel().getCaption().getFont().setName("MS Sans Serif");
yAxis.getMajorGrid().getLineAttributes().setVisible(true);
yAxis.getMajorGrid().getLineAttributes().setColor(ColorDefinitionImpl.GREY());
yAxis.getMajorGrid().getLineAttributes().setStyle(LineStyle.DASHED_LITERAL);
yAxis.getMajorGrid().setTickStyle(TickStyle.LEFT_LITERAL);
yAxis.setType(AxisType.LINEAR_LITERAL);
yAxis.getOrigin().setType(IntersectionType.VALUE_LITERAL);
yAxis.getScale().setStep(1.0);
//TODO
init();
//x-Series
Series xSeries = SeriesImpl.create();
SeriesDefinition sdX = SeriesDefinitionImpl.create();
sdX.getSeries().add(xSeries);
xAxis.getSeriesDefinitions().add(sdX);
// X-Axis
NumberDataSet dataX = NumberDataSetImpl.create( xData );
xSeries.setDataSet(dataX);
NumberDataSet orthoValuesDataSet1 = NumberDataSetImpl.create(yData);
LineSeries bs1 = (LineSeries) LineSeriesImpl.create();
bs1.setDataSet(orthoValuesDataSet1);
//bs1.setRiserOutline(null);
DataPoint dp = bs1.getDataPoint();
dp.getComponents().clear();
dp.setPrefix("(");
dp.setSuffix(")");
// Chart doesn't support format specifier for text, so we use
// JavaNumberFormatSpecifierImpl here.
dp.getComponents().add(DataPointComponentImpl
.create(DataPointComponentType.BASE_VALUE_LITERAL,
JavaNumberFormatSpecifierImpl.create("0")));
.create(DataPointComponentType.ORTHOGONAL_VALUE_LITERAL,
SeriesDefinition sdY = SeriesDefinitionImpl.create();
yAxis.getSeriesDefinitions().add(sdY);
sdY.getSeries().add(bs1);
return chart;
* @param chart
public void updateDataSet(ChartWithAxes chart)
Axis yAxis = chart.getPrimaryOrthogonalAxis(xAxis);
NumberDataSet dataY = NumberDataSetImpl.create( yData );
// X-Axis
SeriesDefinition sdX = (SeriesDefinition) xAxis.getSeriesDefinitions().get(0);
((Series) sdX.getSeries().get(0)).setDataSet(dataX);
// Y-Axis
SeriesDefinition sdY = (SeriesDefinition) yAxis.getSeriesDefinitions().get(0);
((Series) sdY.getSeries().get(0)).setDataSet(dataY);
public void insertPoint(String x, String y){
System.out.println("DoubleKLick: " + x + " " + y);
double[] xDataNew = new double[xData.length + 1];
double[] yDataNew = new double[yData.length + 1];
System.arraycopy(xData, 0, xDataNew, 0, xData.length);
System.arraycopy(yData, 0, yDataNew, 0, yData.length);
xDataNew[xData.length] = Double.valueOf(x);
yDataNew[yData.length] = Double.valueOf(y);
xData = xDataNew;
yData = yDataNew;
updateDataSet((ChartWithAxes) chart);
public Chart getDesignTimeModel() {
return gcs.getChartModel();
public Chart getRunTimeModel() {
return chart;
public Object peerInstance() {
return this;
public void regenerateChart() {
redraw();
public void repaintChart() {
redraw();
import org.eclipse.birt.chart.api.ChartEngine;
import org.eclipse.birt.chart.device.IDeviceRenderer;
import org.eclipse.birt.chart.device.IUpdateNotifier;
import org.eclipse.birt.chart.exception.ChartException;
import org.eclipse.birt.chart.factory.GeneratedChartState;
import org.eclipse.birt.chart.factory.Generator;
import org.eclipse.birt.chart.model.attribute.Bounds;
import org.eclipse.birt.chart.model.attribute.impl.BoundsImpl;
import org.eclipse.birt.core.framework.PlatformConfig;
import org.eclipse.swt.events.ControlEvent;
import org.eclipse.swt.events.ControlListener;
import org.eclipse.swt.events.PaintEvent;
import org.eclipse.swt.events.PaintListener;
import org.eclipse.swt.graphics.GC;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.graphics.Rectangle;
public abstract class SwtLiveChartViewer extends Composite implements PaintListener, ControlListener, IUpdateNotifier{
private IDeviceRenderer idr = null;
public Chart chart;
public GeneratedChartState gcs = null;
* Used in building the chart for the first time
private boolean bFirstPaint = true;
* Constructor
public SwtLiveChartViewer( Composite parent, int style )
super( parent, style );
try
PlatformConfig config = new PlatformConfig( );
config.setBIRTHome("");
idr = ChartEngine.instance( config ).getRenderer( "dv.SWT" );
idr.setProperty(IDeviceRenderer.UPDATE_NOTIFIER, this);
catch ( ChartException pex )
pex.printStackTrace();
chart = createChart( );
public void dispose() {
if( (imgChart !=null) && (!imgChart.isDisposed()))imgChart.dispose();
if( (gcImage !=null) && (!gcImage.isDisposed()))gcImage.dispose();
super.dispose();
public abstract Chart createChart();
private Image imgChart;
private GC gcImage;
private Bounds bo;
* (non-Javadoc)
* @see
* org.eclipse.swt.events.PaintListener#paintControl(org.eclipse.swt.events
* .PaintEvent)
public final void paintControl( PaintEvent e )
Rectangle d = this.getClientArea( );
if ( bFirstPaint )
//if resized
imgChart = new Image( this.getDisplay( ), d );
gcImage = new GC( imgChart );
idr.setProperty( IDeviceRenderer.GRAPHICS_CONTEXT, gcImage );
bo = BoundsImpl.create( 0, 0, d.width, d.height );
bo.scale( 72d / idr.getDisplayServer( ).getDpiResolution( ) );
Generator gr = Generator.instance( );
try
gcs = gr.build( idr.getDisplayServer( ), chart, bo, null, null, null );
// gcs.getRunTimeContext().setActionRenderer( new MyActionHandler());
gr.render( idr, gcs );
GC gc = e.gc;
gc.drawImage( imgChart, d.x, d.y );
catch ( ChartException ce )
ce.printStackTrace( );
bFirstPaint = false;
Display.getDefault( ).timerExec( 500, new Runnable( ) {
public void run( )
chartRefresh( );
* (non-Javadoc)
* @see
* org.eclipse.swt.events.SelectionListener#widgetDefaultSelected(org.eclipse
* .swt.events.SelectionEvent)
private void chartRefresh( )
if ( !isDisposed( ) )
final Generator gr = Generator.instance( );
//scrollData( (ChartWithAxes) chart );
// Refresh
try
gr.refresh( gcs );
catch ( ChartException ex )
ex.printStackTrace( );
redraw( );
public void controlMoved(ControlEvent arg0) {
bFirstPaint = true;
public void controlResized(ControlEvent arg0) {
bFirstPaint = true;
Re: Drag and Drop function for Bird [message #757570 is a reply to message #756628] Sat, 19 November 2011 14:49 Go to previous messageGo to next message
No Message Body
[Updated on: Sat, 19 November 2011 16:10]
Report message to a moderator
Re: Drag and Drop function for Bird [message #757820 is a reply to message #757005] Wed, 16 November 2011 16:35 Go to previous messageGo to next message
Your class needs to implement the
ICallBackNotifier. Take a look at this example.
package my.swt.live.viewer;
import org.eclipse.birt.chart.device.ICallBackNotifier;
import org.eclipse.birt.chart.event.WrappedStructureSource;
import org.eclipse.birt.chart.model.attribute.CallBackValue;
import org.eclipse.birt.chart.model.attribute.LineAttributes;
import org.eclipse.birt.chart.model.attribute.Marker;
import org.eclipse.birt.chart.model.attribute.MarkerType;
import org.eclipse.birt.chart.model.attribute.Position;
import org.eclipse.birt.chart.model.attribute.RiserType;
import org.eclipse.birt.chart.model.attribute.impl.CallBackValueImpl;
import org.eclipse.birt.chart.model.data.TextDataSet;
import org.eclipse.birt.chart.model.data.impl.TextDataSetImpl;
import org.eclipse.birt.chart.model.layout.Legend;
import org.eclipse.birt.chart.model.layout.Plot;
import org.eclipse.birt.chart.model.type.BarSeries;
import org.eclipse.birt.chart.model.type.impl.BarSeriesImpl;
import org.eclipse.birt.chart.util.PluginSettings;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.MessageBox;
import org.eclipse.swt.widgets.Shell;
public class SwtLiveChartViewer extends Composite implements
PaintListener,
ICallBackNotifier
private boolean bNeedsGeneration = true;
private Chart cm = null;
private GeneratedChartState gcs = null;
public static SwtLiveChartViewer c3dViewer;
public Chart getDesignTimeModel( )
return cm;
public void regenerateChart( )
redraw( );
public Chart getRunTimeModel( )
return gcs.getChartModel( );
public void repaintChart( )
redraw( );
return this;
public void callback( Object event, Object source, CallBackValue value )
Object obj1 =
((DataPointHints)((WrappedStructureSource)source).getSource()).getBaseValue();
Object obj2 =
((DataPointHints)((WrappedStructureSource)source).getSource()).getOrthogonalValue().toString();
Object obj3 =
((DataPointHints)((WrappedStructureSource)source).getSource()).getSeriesValue();
double xval =
((DataPointHints)((WrappedStructureSource)source).getSource()).getLocation().getX();
double yval =
((DataPointHints)((WrappedStructureSource)source).getSource()).getLocation().getY();
StructureSource structuredSource = (StructureSource) source;
DataPointHints dph = (DataPointHints) structuredSource.getSource();
Object obj4 =
MessageBox mb = new MessageBox ( this.getShell( ) );
mb.setMessage( xval + "," + yval);
mb.open( );
* execute application
* @param args
public static void main( String[] args )
Display display = Display.getDefault( );
Shell shell = new Shell( display );
shell.setSize( 600, 400 );
shell.setLayout( new GridLayout( ) );
c3dViewer = new SwtLiveChartViewer( shell, SWT.NO_BACKGROUND );
c3dViewer.setLayoutData( new GridData( GridData.FILL_BOTH ) );
c3dViewer.addPaintListener( c3dViewer );
shell.open( );
while ( !shell.isDisposed( ) )
if ( !display.readAndDispatch( ) )
display.sleep( );
display.dispose( );
* Constructor
PlatformConfig config = new PlatformConfig();
config.setProperty( "STANDALONE", "true" ); //$NON-NLS-1$//$NON-NLS-2$
final PluginSettings ps = PluginSettings.instance( config );
try
idr = ps.getDevice( "dv.SWT" );//$NON-NLS-1$
idr.setProperty( IDeviceRenderer.UPDATE_NOTIFIER, this );
cm = createLiveChart( );
public static final Chart createLiveChart( )
ChartWithAxes cwaBar = ChartWithAxesImpl.create( );
//Plot
cwaBar.getBlock( ).setBackground( ColorDefinitionImpl.WHITE( ) );
Plot p = cwaBar.getPlot( );
p.getClientArea( ).setBackground( ColorDefinitionImpl.create( 255,
255,
225 ) );
//Legend
Legend lg = cwaBar.getLegend( );
LineAttributes lia = lg.getOutline( );
lg.getText( ).getFont( ).setSize( 16 );
lia.setStyle( LineStyle.SOLID_LITERAL );
lg.getInsets( ).setLeft( 10 );
lg.getInsets( ).setRight( 10 );
//Title
cwaBar.getTitle( )
.getLabel( )
.getCaption( )
.setValue( "Live Chart Demo" );//$NON-NLS-1$
//X-Axis
Axis xAxisPrimary = cwaBar.getPrimaryBaseAxes( )[0];
xAxisPrimary.setType( AxisType.TEXT_LITERAL );
xAxisPrimary.getOrigin( ).setType( IntersectionType.VALUE_LITERAL );
xAxisPrimary.getOrigin( ).setType( IntersectionType.MIN_LITERAL );
xAxisPrimary.getTitle( )
.getCaption( )
.setValue( "Category Text X-Axis" );//$NON-NLS-1$
xAxisPrimary.setTitlePosition( Position.BELOW_LITERAL );
xAxisPrimary.getLabel( ).getCaption( ).getFont( ).setRotation( 75 );
xAxisPrimary.setLabelPosition( Position.BELOW_LITERAL );
xAxisPrimary.getMajorGrid( ).setTickStyle( TickStyle.BELOW_LITERAL );
.getLineAttributes( )
.setStyle( LineStyle.DOTTED_LITERAL );
.setColor( ColorDefinitionImpl.create( 64, 64, 64 ) );
xAxisPrimary.getMajorGrid( ).getLineAttributes( ).setVisible( true );
//Y-Axis
Axis yAxisPrimary = cwaBar.getPrimaryOrthogonalAxis( xAxisPrimary );
yAxisPrimary.getLabel( ).getCaption( ).setValue( "Price Axis"
);//$NON-NLS-1$
yAxisPrimary.getLabel( ).getCaption( ).getFont( ).setRotation( 37 );
yAxisPrimary.setLabelPosition( Position.LEFT_LITERAL );
yAxisPrimary.setTitlePosition( Position.LEFT_LITERAL );
yAxisPrimary.getTitle( ).getCaption( ).setValue( "Linear Value Y-Axis"
);//$NON-NLS-1$
yAxisPrimary.setType( AxisType.LINEAR_LITERAL );
yAxisPrimary.getMajorGrid( ).setTickStyle( TickStyle.LEFT_LITERAL );
.setColor( ColorDefinitionImpl.RED( ) );
yAxisPrimary.getMajorGrid( ).getLineAttributes( ).setVisible( true );
//X-Series
Series seCategory = SeriesImpl.create( );
SeriesDefinition sdX = SeriesDefinitionImpl.create( );
xAxisPrimary.getSeriesDefinitions( ).add( sdX );
sdX.getSeries( ).add( seCategory );
//Y-Series (1)
BarSeries bs1 = (BarSeries) BarSeriesImpl.create( );
bs1.setSeriesIdentifier( "Unit Price" );//$NON-NLS-1$
bs1.setRiserOutline( null );
bs1.setRiser( RiserType.RECTANGLE_LITERAL );
//bs1.getTriggers( ).add(
// TriggerImpl.create( TriggerCondition.MOUSE_CLICK_LITERAL,
// ActionImpl.create( ActionType.TOGGLE_VISIBILITY_LITERAL,
SeriesValueImpl.create("not used" ) ) ) );
//Trigger tr1 = TriggerImpl.create(TriggerCondition.ONMOUSEOVER_LITERAL,
// ActionImpl.create(ActionType.SHOW_TOOLTIP_LITERAL,
// TooltipValueImpl.create(200, null)));
bs1.getTriggers( ).add( TriggerImpl.create(
ActionImpl.create( ActionType.CALL_BACK_LITERAL,
CallBackValueImpl.create( String.valueOf( bs1.getSeriesIdentifier(
//bs1.getTriggers().add(tr1);
//Y-Series (2)
LineSeries ls1 = (LineSeries) LineSeriesImpl.create( );
ls1.setSeriesIdentifier( "Quantity" );//$NON-NLS-1$
ls1.getLineAttributes( ).setColor( ColorDefinitionImpl.GREEN( ) );
for ( int i = 0; i < ls1.getMarkers( ).size( ); i++ )
( (Marker) ls1.getMarkers( ).get( i ) ).setType(
MarkerType.BOX_LITERAL );
ls1.setCurve( true );
SeriesDefinition sdY = SeriesDefinitionImpl.create( );
yAxisPrimary.getSeriesDefinitions( ).add( sdY );
sdY.getSeriesPalette( ).shift( -1 );
sdY.getSeries( ).add( bs1 );
sdY.getSeries( ).add( ls1 );
// Update data
updateDataSet( cwaBar );
return cwaBar;
static final void updateDataSet( ChartWithAxes cwaBar )
// Associate with Data Set
TextDataSet categoryValues = TextDataSetImpl.create( sa );
NumberDataSet seriesOneValues = NumberDataSetImpl.create( da1 );
NumberDataSet seriesTwoValues = NumberDataSetImpl.create( da2 );
// X-Axis
.get( 0 );
( (Series) sdX.getSeries( ).get( 0 ) ).setDataSet( categoryValues );
// Y-Axis
.get( 0 );
( (Series) sdY.getSeries( ).get( 0 ) ).setDataSet( seriesOneValues );
( (Series) sdY.getSeries( ).get( 1 ) ).setDataSet( seriesTwoValues );
//Live Date Set
private static final String[] sa = {
"One", "Two", "Three", "Four",
"Five",//$NON-NLS-1$//$NON-NLS-2$//$NON-NLS-3$//$NON-NLS-4$//$NON-NLS-5$
"Six", "Seven", "Eight", "Nine",
"Ten"};//$NON-NLS-1$//$NON-NLS-2$//$NON-NLS-3$//$NON-NLS-4$//$NON-NLS-5$
private static final double[] da1 = {
56.99,
352.95,
-201.95,
299.95,
-95.95,
25.45,
129.33,
-26.5,
43.5,
122
private static final double[] da2 = {
20, 35, 59, 105, 150, -37, -65, -99, -145, -185
Image imgChart = new Image( this.getDisplay( ), d );
GC gcImage = new GC( imgChart );
//Look at IDeviceRenderer.java for all properties
//like DPI_RESOLUTION
//FILE_IDENTIFIER
//FORMAT_IDENTIFIER
//UPDATE_NOTIFIER
//idr.setProperty(IDeviceRenderer.UPDATE_NOTIFIER, this);
Bounds bo = BoundsImpl.create( 0, 0, d.width, d.height );
if ( bNeedsGeneration )
bNeedsGeneration = false;
try
cm,
bo,
null,
null,
null );
if ( bFirstPaint )
try
GC gc = e.gc;
Jason
On 11/15/2011 6:07 PM, gloeckner.peter wrote:
> point.
> Thanks
> Peter
> import
> public void init(){
> xData[0] = 1;
> xData[1] = 2;
> yData[0] = 1;
> yData[1] = 2;
> * std - Konstruktor
> * @param parent
> * @param style
> //x-Achse
> //y-Achse
> //TODO
> init();
> //x-Series
> // X-Axis
> dp.setPrefix("(");
> dp.setSuffix(")");
> return chart;
> * * @param chart
> // X-Axis
> // Y-Axis
> xData = xDataNew;
> yData = yDataNew;
> @Override
> @Override
> return chart;
> @Override
> return this;
> @Override
> redraw();
> @Override
> redraw();
> import org.eclipse.swt.widgets.Display;
> public Chart chart;
> * Constructor
> try
> @Override
> super.dispose();
> private GC gcImage;
> private Bounds bo;
> * (non-Javadoc)
> * * @see
> * .PaintEvent)
> if ( bFirstPaint )
> //if resized
> try
> GC gc = e.gc;
> public void run( )
> chartRefresh( );
> * (non-Javadoc)
> * * @see
> // Refresh
> try
> gr.refresh( gcs );
> redraw( );
> bFirstPaint = true;
> bFirstPaint = true;
Re: Drag and Drop function for Bird [message #757840 is a reply to message #757570] Mon, 21 November 2011 18:44 Go to previous messageGo to next message
Can you try using the generated chart state object to get the plot
computations like: (Note this only gets the auto scale of the orthogonal
axis) The x-axis will have a discreet number of points as defined in you
dataset. Have a look at the bottom to see how to access these points.
Axis xAxis = ((ChartWithAxes) chart).getPrimaryBaseAxes()[0];
Axis yAxis = xAxis.getAssociatedAxes().get(0);
SeriesDefinition xSerieDef = xAxis.getSeriesDefinitions().get(0);
SeriesDefinition ySerieDef = yAxis.getSeriesDefinitions().get(0);
Series ySerie = ySerieDef.getRunTimeSeries().get(0);
Object min =
gcs.getComputations().getSeriesRenderingHints(ySerieDef,ySerie).getOrthogonalScale().getMaximum(
Object max =
gcs.getComputations().getSeriesRenderingHints(ySerieDef,ySerie).getOrthogonalScale().getMinimum(
//x and y data points
Object orthodp1 =
gcs.getComputations().getSeriesRenderingHints(ySerieDef,ySerie).getDataPoints()[0].getOrthogonalValue();
catdp1 =
gcs.getComputations().getSeriesRenderingHints(ySerieDef,ySerie).getDataPoints()[0].getBaseValue();
int xaxisdpsize =
gcs.getComputations().getSeriesRenderingHints(ySerieDef,ySerie).getDataPoints().length;
Jason
On 11/19/2011 9:49 AM, gloeckner.peter wrote:
> I could solve some problems. But I have another one :).
> In fact i forgot about triggers and added two listeners to my LineChart.
> The first one is notified when i click on the chart, the second one when
> you release your mouse.
> I found the right methods to compute, where the point is relativly to
> the origin of the graph. (in point not pixel coordinates) Now I need the
> actual MaxValue of the Axis, but the results of these method calls
> (class MouseUpListener, method handleEvent)
> System.out.println(xAxis.getScale().getMin());
> System.out.println(xAxis.getScale().getMax());
> are null.
> When I'm assigning a max and min value, like this
> // xAxis.getScale().setMin(NumberDataElementImpl.create(0));
> // xAxis.getScale().setMax(NumberDataElementImpl.create(3));
> I will loose the autoExpand ability.
> Below you can see my two classes, my LineChart can be instantiated in
> your RCP view like this:
> c3dViewer = new LineChart( all, SWT.NO_BACKGROUND );
> c3dViewer.addControlListener( c3dViewer );
> c3dViewer.setDragAndDropEnabled(true);
> public Chart chart;
> * Constructor
> try
> @Override
> super.dispose();
> private GC gcImage;
> private Bounds bo;
> * (non-Javadoc)
> * @see
> * .PaintEvent)
> if ( bFirstPaint )
> //if resized
> try
> GC gc = e.gc;
> public void run( )
> chartRefresh( );
> * (non-Javadoc)
> * @see
> // Refresh
> try
> gr.refresh( gcs );
> redraw( );
> bFirstPaint = true;
> bFirstPaint = true;
> import
> import org.eclipse.birt.chart.model.data.impl.NumberDataElementImpl;
> import org.eclipse.swt.widgets.Event;
> import org.eclipse.swt.widgets.Listener;
> private boolean dragAndDropEnabled = false;
> private MouseDownListener MouseDownListener;
> private MouseUpListener MouseUpListener;
> public boolean isDragAndDropEnabled() {
> return dragAndDropEnabled;
> public void setDragAndDropEnabled(boolean dragAndDropEnabled) {
> this.dragAndDropEnabled = dragAndDropEnabled;
> if(this.dragAndDropEnabled){
> this.MouseUpListener = new MouseUpListener();
> this.MouseDownListener = new MouseDownListener(this.MouseUpListener);
> addListener(SWT.MouseDown, this.MouseDownListener);
> addListener(SWT.MouseUp, this.MouseUpListener);
> }else{
> removeListener(SWT.MouseDown, this.MouseDownListener);
> removeListener(SWT.MouseUp, this.MouseUpListener);
> public void init(){
> xData[0] = 1;
> xData[1] = 2;
> yData[0] = 1;
> yData[1] = 2;
> * std - Konstruktor
> * @param parent
> * @param style
> //x-Achse
> xAxis.getTitle().setVisible(true); //Titel
> xAxis.getLabel().setVisible(true); //Achsenbeschriftung
> xAxis.getLabel().getCaption().getFont().setSize(11);
> xAxis.getScale().setAutoExpand(true);
> //y-Achse
> yAxis.getTitle().setVisible(true);
> yAxis.getLabel().setVisible(true);
> //TODO
> init();
> //x-Series
> // X-Axis
> dp.setPrefix("(");
> dp.setSuffix(")");
> /* bs1.getTriggers().add(TriggerImpl
> TooltipValueImpl.create(500, null))));*/
> //Farben
> chart.getPlot().getClientArea().setBackground(ColorDefinitionImpl.BLUE());
> chart.getPlot().setBackground(ColorDefinitionImpl.GREEN());
> chart.getLegend().setBackground(ColorDefinitionImpl.CYAN());
> chart.getTitle().setBackground(ColorDefinitionImpl.ORANGE());
> chart.getPlot().getOutline().setColor(ColorDefinitionImpl.BLACK());
> return chart;
> * * @param chart
> // X-Axis
> // Y-Axis
> xData = xDataNew;
> yData = yDataNew;
> @Override
> @Override
> return chart;
> @Override
> return this;
> @Override
> redraw();
> @Override
> redraw();
> public class MouseDownListener implements Listener{
> private MouseUpListener mouseUpListener;
> public MouseDownListener(MouseUpListener mouseUpListener){
> this.mouseUpListener = mouseUpListener;
> @Override
> public void handleEvent(Event event) {
> mouseUpListener.setStart(event);
> public class MouseUpListener implements Listener{
> private Event start = null;
> public void setStart(Event start){
> this.start = start;
> @Override
> Bounds clientarea = gcs.getComputations().getPlotBounds();
> double start_y = clientarea.getTop() + clientarea.getHeight() - start.y;
> double start_x = start.x - clientarea.getLeft();
> System.out.println(start_x + " , " + start_y);
Re: Drag and Drop function for Bird [message #768639 is a reply to message #757840] Tue, 20 December 2011 14:16 Go to previous message
Thanks for the help.
I could solve the problems and will post a solution, when i'm sure it's correct.
Previous Topic:How to handle click on image with areas
Next Topic:Cross-tab issues
Current Time: Sat Feb 24 10:42:55 GMT 2018
Powered by FUDForum. Page generated in 0.02612 seconds
