Home » Eclipse Projects » BIRT » Can BIRT access the host name of the running TC Server?(Can BIRT Reports or Event Handlers access the host name of the running TC Server?)
Can BIRT access the host name of the running TC Server? [message #754275] Tue, 01 November 2011 18:09 Go to next message
paula.mcdowell is currently offline paula.mcdowellFriend
Is there a way to verify the host name, as a String, of the application server instance running the BIRT Report?
For example, I'd like to compare
http://${client_request_host}:8080/Birt/frameset?__report=report.rptdesign
to
http://${tomcat_server_host}:8080/
If ${client_request_host} and ${tomcat_server_host} are not equal, I want to display an invalid request error message.
Thank you,
Paula
Re: Can BIRT access the host name of the running TC Server? [message #755250 is a reply to message #754275] Mon, 07 November 2011 19:39 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
You can get the host running the report like:
reportContext.getHttpServletRequest().getServerName();
Not sure what you are comparing it to though.
Jason
> to
> Thank you,
> Paula
Re: Can BIRT access the host name of the running TC Server? [message #755844 is a reply to message #755250] Wed, 09 November 2011 19:24 Go to previous messageGo to next message
Thanks for your response, Jason.
My report will be running in a web application. My end product will be a jar and a rptdesign to be included in the war.
So let me ask the question differently. Is there a way BIRT can access the server name of its parent web application?
For example:
http://www.example.com/BIRTReport/frameset?__report=myreport.rptdesign
The web application is BIRTReport. Is there a way to access "www.example.com" within my BIRT code? Either in the rptdesign or the event handlers? Ultimately I want to compare it to the "referer" cookie obtained from the client request.
Thanks.
Paula
Re: Can BIRT access the host name of the running TC Server? [message #755868 is a reply to message #755844] Wed, 09 November 2011 21:48 Go to previous message
In this case:
should work fine. Have yo tried it?
Jason
> For example:
> Thanks.
> Paula
Previous Topic:Manipulate elements manually over script
Next Topic:wget report
Current Time: Mon Apr 23 00:20:17 GMT 2018
Powered by FUDForum. Page generated in 0.02354 seconds
