Home » Modeling » Graphiti » Force model save
Force model save [message #741389] Wed, 19 October 2011 13:38 Go to next message
Julien Delange is currently offline Julien DelangeFriend
Member
Dear all,
I am currently making a graphiti project which is linked with my own meta model. So, when changing a property, I would like to update the value of the object from the meta model itself.
So, in the properties of my component, I have a ComboBox for the property value.
	private CCombo languageValue;
Then, when building the combo box object in my code, I add a selection listener. I disable the delivering attribute in order to avoid error messages from eclipse (telling than I'm not allowed to write in this editing domain).
So, now, after invoking this piece of code and when changing the property, the property is not saved in the model. On the other hand, if I move one object on the diagram and save it again, the new property value is saved.
So, one workaround would be to force to save the model when the property value is updated or to notify eclipse that the model changed. Unfortunately, when I invoke notify() on the PictogramElement, I got the IllegalMonitorStateException.
So, there is my questions :
1. How can I indicate to force to save the model from just an object that contains a PictogramElement ?
2. Is there a possibility to force the notification of a change in the model from a PictogramElement ?
Thanks for any suggestion/comment
Best,
		languageValue.addSelectionListener(new SelectionAdapter() {
		      public void widgetSelected(SelectionEvent e)
		          String[] propertyValues = languageValue.getItems();
		          String propertyValue = propertyValues[languageValue.getSelectionIndex()];
		          PictogramElement pe = getSelectedPictogramElement();
		          Object bo = Graphiti.getLinkService().getBusinessObjectForLinkedPictogramElement(pe);
		          if (bo instanceof Function)
		        	  Function f = (Function) bo;
		        	  System.out.println("selected object " + f.getName());
		        	  System.out.println("property value  " + propertyValue);
		        	  f.eSetDeliver(false);
		        	  f.setLanguage(propertyValue);
Re: Force model save [message #742251 is a reply to message #741389] Thu, 20 October 2011 10:13 Go to previous messageGo to next message
Michael Wenz is currently online Michael WenzFriend
Julien,
I'm not sure if I fully understood your issue. But there is an example on
how to build editable property sheets in our FAQ:
http://www.eclipse.org/graphiti/developers/faq.php
Baseline is that you have to use the editing domain of the editor, otherwise
you will run into sync issues.
HTH,
Michael
Re: Force model save [message #742389 is a reply to message #742251] Thu, 20 October 2011 12:54 Go to previous message
Member
This helped a lot. And then, using the code you provided, the new component is notified of the modification and I can save the model. As a result, the new property value is shown when I load the model again.
However, since I applied these modifications, I got the following when I exit the platform. Do you have any idea why this happen ?
Thanks for your quick feedback,
Best,
!ENTRY org.eclipse.ui.workbench 4 0 2011-10-20 14:51:12.281
!MESSAGE Widget disposed too early for part org.eclipse.emf.cdo.ui.CDOSessionsView
!STACK 0
java.lang.RuntimeException: Widget disposed too early for part org.eclipse.emf.cdo.ui.CDOSessionsView
	at org.eclipse.ui.internal.WorkbenchPartReference$1.widgetDisposed(WorkbenchPartReference.java:171)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:123)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
	at org.eclipse.swt.widgets.Widget.release(Widget.java:808)
	at org.eclipse.swt.widgets.Composite.releaseChildren(Composite.java:873)
	at org.eclipse.swt.widgets.Widget.release(Widget.java:811)
	at org.eclipse.swt.widgets.Canvas.releaseChildren(Canvas.java:167)
	at org.eclipse.swt.widgets.Decorations.releaseChildren(Decorations.java:773)
	at org.eclipse.swt.widgets.Shell.releaseChildren(Shell.java:1290)
	at org.eclipse.swt.widgets.Widget.dispose(Widget.java:446)
	at org.eclipse.swt.widgets.Decorations.dispose(Decorations.java:447)
	at org.eclipse.swt.widgets.Shell.dispose(Shell.java:715)
	at org.eclipse.jface.window.Window.close(Window.java:335)
	at org.eclipse.jface.window.ApplicationWindow.close(ApplicationWindow.java:307)
	at org.eclipse.ui.internal.WorkbenchWindow.hardClose(WorkbenchWindow.java:1761)
	at org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchWindow.java:730)
	at org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWindow.java:715)
	at org.eclipse.ui.internal.WorkbenchWindow$5.run(WorkbenchWindow.java:860)
	at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindow.java:858)
	at org.eclipse.jface.window.WindowManager.close(WindowManager.java:109)
	at org.eclipse.ui.internal.Workbench$18.run(Workbench.java:1109)
	at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:1106)
	at org.eclipse.ui.internal.Workbench.access$15(Workbench.java:1035)
	at org.eclipse.ui.internal.Workbench$25.run(Workbench.java:1279)
	at org.eclipse.ui.internal.Workbench.close(Workbench.java:1277)
	at org.eclipse.ui.internal.Workbench.close(Workbench.java:1249)
	at org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchWindow.java:727)
	at org.eclipse.jface.window.Window.handleShellCloseEvent(Window.java:741)
	at org.eclipse.jface.window.Window$3.shellClosed(Window.java:687)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:98)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
	at org.eclipse.swt.widgets.Decorations.closeWidget(Decorations.java:308)
	at org.eclipse.swt.widgets.Decorations.WM_CLOSE(Decorations.java:1677)
	at org.eclipse.swt.widgets.Control.windowProc(Control.java:4530)
	at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
	at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1610)
	at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2061)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:4972)
	at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
	at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2526)
	at org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:498)
	at org.eclipse.swt.widgets.Control.windowProc(Control.java:4623)
	at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
	at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2531)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3752)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
!MESSAGE Widget disposed too early for part org.eclipse.ui.views.PropertySheet
!STACK 0
java.lang.RuntimeException: Widget disposed too early for part org.eclipse.ui.views.PropertySheet
!ENTRY org.eclipse.ui.workbench 4 2 2011-10-20 14:51:12.312
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
!STACK 0
org.eclipse.core.runtime.AssertionFailedException: assertion failed:
	at org.eclipse.core.runtime.Assert.isTrue(Assert.java:110)
	at org.eclipse.core.runtime.Assert.isTrue(Assert.java:96)
	at org.eclipse.ui.internal.PartList.removePart(PartList.java:174)
	at org.eclipse.ui.internal.WorkbenchPage.disposePart(WorkbenchPage.java:1796)
	at org.eclipse.ui.internal.WorkbenchPage.partRemoved(WorkbenchPage.java:1789)
	at org.eclipse.ui.internal.ViewFactory.releaseView(ViewFactory.java:257)
	at org.eclipse.ui.internal.Perspective.dispose(Perspective.java:292)
	at org.eclipse.ui.internal.WorkbenchPage.dispose(WorkbenchPage.java:1868)
	at org.eclipse.ui.internal.WorkbenchWindow.closeAllPages(WorkbenchWindow.java:887)
	at org.eclipse.ui.internal.WorkbenchWindow.hardClose(WorkbenchWindow.java:1722)
Previous Topic:Restricting move
Next Topic:Removing remove
Current Time: Wed Apr 25 07:14:34 GMT 2018
Powered by FUDForum. Page generated in 0.02103 seconds
