How to control table size for PDF Generation? [message #730671] |
Wed, 28 September 2011 20:27 |
Jean-Baptiste Guillois Messages: 33 Registered: August 2011 |
Member |
I am using BIRT 3.7.1 and created some reports with large tables. By "large", i mean tables with a big width.
As a result, when i export this report as a PDF, the table does not fit (i have the 2/3 of the table visible and only one page in the PDF file) in the pdf A4 page even when setting the report layout as "AutoLayout".
Where (if any) can i configure the maximum width or "another autolayout" setting?
Even if i tick the "Size to fit" or "Auto" options in the export dialog, no change, the table is still cut.
Actually, i haven't tested it but it might not be specific to the PDF Emmiter....
Thanks a lot for your help,
Jean-Baptiste
Re: How to control table size for PDF Generation? [message #730680 is a reply to message #730671] |
Wed, 28 September 2011 20:57 |
Select the master page and set the page size to one of the specific
formats or use custom and set any size you want.
Jason
On 9/28/2011 4:27 PM, jeanbaptiste.guillois wrote:
> Hello,
> setting?
> Emmiter....
> Jean-Baptiste
FUDForum. Page generated in 0.02746 seconds
