Home » Archived » M2M (model-to-model transformation) » [ATL] Assigning attributes to target class using HOT
[ATL] Assigning attributes to target class using HOT [message #725040] Tue, 13 September 2011 19:07 Go to next message
Subhav Pradhan is currently offline Subhav PradhanFriend
Another newbie question. I am working on writing a HOT and I am running into a very simple problem for which I have not been able to find any solution in the available documentations.
I have created an EClass--C and EAttribute--A in my target metamodel using different rules but now I am having problem assigning attribute A to class C. I have tried changing the value of eAttribute for my class C but I get error saying that the field eAttribute is not changeable.
Any help would be much appreciated!
Subhav
[Updated on: Tue, 13 September 2011 19:08]
Report message to a moderator
Re: [ATL] Assigning attributes to target class using HOT [message #725218 is a reply to message #725040] Wed, 14 September 2011 09:30 Go to previous messageGo to next message
Sylvain EVEILLARD is currently offline Sylvain EVEILLARDFriend
you have to use the eStructuralFeatures reference.
eAttribute is a derived attribute that uses the eStructuralFeatures reference.
Re: [ATL] Assigning attributes to target class using HOT [message #725442 is a reply to message #725218] Wed, 14 September 2011 19:39 Go to previous message
Ahh! As easy as that. Thanks much Sylvain. You help is very appreciated!
Subhav
Previous Topic:[ATL] EMF VM testing
Next Topic:ATL Development Tools
Current Time: Wed Apr 25 22:24:16 GMT 2018
Powered by FUDForum. Page generated in 0.01403 seconds
