Home » Eclipse Projects » BIRT » BIRT 3.7 - dynamic image from byte[] bound to column
BIRT 3.7 - dynamic image from byte[] bound to column [message #724609] Mon, 12 September 2011 16:22 Go to next message
Jon Nazario is currently offline Jon NazarioFriend
Hello there!
I am trying to get dynamic image working in BIRT 3.7 but all I get is either a message: "The resource of this report item is not reachable." or a default image during preview.
Details:
- IDE = RAD 8
- DataSource comes from WebService call to JAX-WS
+ The web service is hosted by WAS 8
+ The web service field uses a DataHandler which responds with a byte[] for the xml document. (i.e. <VirSignatureImage>R0lGODlh9QBgAPcAAAAAAAAAMwAAZgAAmQAAz....[[more data]]</VirSignatureImage>
- In Birt 3.7 for the DataSet I am using SOAP Response = "Use schema from response."
- In Column Mapping, the data type options don't display (Blob or Java Object) so is selected as string
- For the Image as a Dynamic Object is when I see the options to use the dataSetRow["field"] as a Blob or Java Object
Non has work, and haven't found any pointer if the issue is a the beginning with the column data type set to String or how to script to make in java script the field into a byte array.
Thanks for any help
Re: BIRT 3.7 - dynamic image from byte[] bound to column [message #724627 is a reply to message #724609] Mon, 12 September 2011 16:51 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Can you set the binding to string as well and then use some script to
set the values? For example if the image is base64encoded, set the
image type Dynamic Image and use an onCreate script like:
importPackage(Packages.javax.imageio);
importPackage(Packages.java.io);
//this.mimeType = "image/png";
importPackage(Packages.sun.misc);
decoder = new BASE64Decoder();
decodedBytes =
decoder.decodeBuffer(this.getRowData().getColumnValue("yourstringwithimg"));
this.data =decodedBytes;
bais = new ByteArrayInputStream( decodedBytes);
bufimg = ImageIO.read(bais);
this.setHeight(bufimg.getHeight() +"px");
this.setWidth(bufimg.getWidth() +"px");
Jason
On 9/12/2011 12:22 PM, Jon Nazario wrote:
> Hello there!
> Details:
> - IDE = RAD 8 - DataSource comes from WebService call to JAX-WS
> from response."
> Thanks for any help
Re: BIRT 3.7 - dynamic image from byte[] bound to column [message #724639 is a reply to message #724627] Mon, 12 September 2011 17:56 Go to previous messageGo to next message
same behavior, no errors and no image.
How can I see what is occurring internally?
Forgot to add that I am using BIRT viewer as my engine.
Re: BIRT 3.7 - dynamic image from byte[] bound to column [message #724643 is a reply to message #724627] Mon, 12 September 2011 17:57 Go to previous messageGo to next message
Same behavior, no errors and no image.
Re: BIRT 3.7 - dynamic image from byte[] bound to column [message #724644 is a reply to message #724627] Mon, 12 September 2011 17:57 Go to previous messageGo to next message
Re: BIRT 3.7 - dynamic image from byte[] bound to column [message #724667 is a reply to message #724644] Mon, 12 September 2011 18:43 Go to previous messageGo to next message
Any chance you can post an xml snippet with the image string in it?
Jason
Re: BIRT 3.7 - dynamic image from byte[] bound to column [message #724676 is a reply to message #724667] Mon, 12 September 2011 19:16 Go to previous messageGo to next message
I just realize I had the script in the wrong section. I was thinking the "onCreate" was the name of the javascript for the dynamic image. But playing around found that it was in the actual script tab while having the image focus. After that change, now it works. Smile Thanks SOOOOOOO much!
Re: BIRT 3.7 - dynamic image from byte[] bound to column [message #762242 is a reply to message #724609] Wed, 07 December 2011 18:51 Go to previous messageGo to next message
Hate to revive old posts, but I am having problems reading the image again.. It suddenly stopped working.
In summary I have 2 reports for which this technique works, but for one of the reports it just stopped working.... Nothing blows, but the image doesn't display in the report. I used a .Net client to call the web service and the image returned is good.
So any advice on how to try debug or adjust the code? Also is a GIF image what I am using.
Re: BIRT 3.7 - dynamic image from byte[] bound to column [message #762250 is a reply to message #762242] Wed, 07 December 2011 18:55 Go to previous message
Jon,
What script did you end up using?
Jason
Previous Topic:Specifying the number of rows per page
Next Topic:ClassLoader Problem in Event Handler
Current Time: Tue Jun 19 08:52:19 GMT 2018
Powered by FUDForum. Page generated in 0.01974 seconds
