Home » Eclipse Projects » BIRT » NullPointerException registering extensions
NullPointerException registering extensions [message #723819] Fri, 09 September 2011 15:02 Go to next message
john.libby is currently offline john.libbyFriend
I am having trouble migrating a birt project into a spring project. So far, I have birt integrated and working on generating a report. However, I am getting the following NPE:
Caused by: java.lang.NullPointerException
   at org.eclipse.datatools.connectivity.oda.spec.manifest.ResultExtensionExplorer.addAllExtensions(ResultExtensionExplorer.java:541)
   at org.eclipse.datatools.connectivity.oda.spec.manifest.ResultExtensionExplorer.(ResultExtensionExplorer.java:122)
   at org.eclipse.datatools.connectivity.oda.spec.manifest.ResultExtensionExplorer.getInstance(ResultExtensionExplorer.java:86)
   at org.eclipse.birt.data.engine.impl.DataEngineImpl.getValidationContext(DataEngineImpl.java:764)
   at org.eclipse.birt.data.engine.impl.OdaDataSetRuntime.(OdaDataSetRuntime.java:56)
I can include more of the stack trace if it helps. It seems that within ResultExtensionExplorer, this line of code:
IExtension[] extensions = ManifestExplorer.getExtensions( DTP_ODA_DYNAMIC_RESULT_SETS_EXT_POINT );
is returning null. I'm guessing that there is some sort of configuration that I have not migrated properly into the destination project. Can anyone point me to possible configurations I should be looking at?
Re: NullPointerException registering extensions [message #724567 is a reply to message #723819] Mon, 12 September 2011 15:01 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
John,
Can you give some more detail on how you integrating the two? What
version of spring and what version of BIRT?
Jason
> at
> at
> at
> at
> at
Re: NullPointerException registering extensions [message #724580 is a reply to message #724567] Mon, 12 September 2011 15:36 Go to previous messageGo to next message
I fixed it, sorry. Somehow my classpath got mangled and the birt runtime jar was not available.
Re: NullPointerException registering extensions [message #724626 is a reply to message #724580] Mon, 12 September 2011 16:42 Go to previous message
Thanks for the update.
Jason
Previous Topic:Re: Format axis label
Next Topic:Mysql connection
Current Time: Sat May 26 09:38:55 GMT 2018
Powered by FUDForum. Page generated in 0.01994 seconds
