JSF support? [message #77024] |
Tue, 14 November 2006 10:27 |
I write a webapp bundle and I want to integrate JSF. My server is the
jettybundle.
But I get allways this error when running the webapp bundle:
org.mortbay.jetty.servlet.ServletHandler handle
SCHWERWIEGEND: /faces/index.jsp:
java.lang.IllegalStateException: Application was not properly
initialized at startup, could not find Factory:
javax.faces.context.FacesContextFactory
at javax.faces.FactoryFinder.getFactory(FactoryFinder.java:263)
at javax.faces.webapp.FacesServlet.init(FacesServlet.java:142)
org.eclipse.equinox.http.registry.internal.ServletManager$Se rvletWrapper.initializeDelegate(ServletManager.java:144)
org.eclipse.equinox.http.registry.internal.ServletManager$Se rvletWrapper.service(ServletManager.java:128)
org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest(ServletRegistration.java:91)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:110)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:68)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:428)
org.mortbay.jetty.servlet.ServletHandler.dispatch(ServletHan dler.java:677)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:568)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1530)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1482)
at org.mortbay.http.HttpServer.service(HttpServer.java:909)
at org.mortbay.http.HttpConnection.service(HttpConnection.java: 820)
at org.mortbay.http.HttpConnection.handleNext(HttpConnection.ja va:986)
at org.mortbay.http.HttpConnection.handle(HttpConnection.java:8 37)
org.mortbay.http.SocketListener.handleConnection(SocketListe ner.java:245)
at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:3 57)
at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:5 34)
But the Factory is available in the bundle!
Is there any support for JSF in an equinox bundle?
Or can anybody help me or give me a hint?
Sabine
Re: JSF support? [message #77223 is a reply to message #77024] |
Wed, 15 November 2006 03:30 |
Originally posted by: skaegi.sympatico.ca
Hi Sabine,
Equinox currently doesn't have a JSF bundle.
That said, it should be feasible to add support, it's more a matter of
finding the time to take a look.
(contributions welcome)
With that said, as I recall JSF uses a ServletContextListener to do some
initialization work as the context gets created so I suspect the error
you're seeing is related to not having an attribute set.
The OSGi HttpService does not have the concept of a ServletContextListener
however (if you're determined) you can simulate the initialization with
either another servlet or by wrapping the Faces servlet with another servlet
that can do the initialization. The first approach is probably sufficient
for testing. Eventually we might look at doing the second approach and
offering good out-of-the-box support.
HTH
-Simon
"Sabine Wagner" <user@domain.invalid> wrote in message
news:ejc5p6$jgi$1@utils.eclipse.org...
> jettybundle.
> at
> at
> at
> at
vlet.java:110)
> at
java:68)
> at
> at
> at
> Best regards,
> Sabine
Re: JSF support? [message #77367 is a reply to message #77223] |
Thu, 16 November 2006 19:26 |
Hi Simon,
thanks for your reply.
I solved the problem with the FacesContextFactory. But now I have the
problem that there's no ServletContextListener registered. And I don't
know how to to register the Listener without web.xml.
You mentioned that it's possible to simulate this with a servlet.
Can you post a small example servlet, please!
Sabine
Simon Kaegi schrieb:
> Hi Sabine,
> HTH
> -Simon
>>Hi,
>>jettybundle.
>>at
>>at
>>at
>>at
> vlet.java:110)
>>at
> java:68)
>>at
>>at
>>at
>>Best regards,
>>Sabine
Re: JSF support? [message #77462 is a reply to message #77367] |
Fri, 17 November 2006 05:01 |
Sure, here's a quick example
If you know exactly which classes are involved you can create a no argument
constructor by extending this and setting the instances (or just take a look
and do your own thing.)
HTH
-Simon
package some.package
import java.io.IOException;
import javax.servlet.*;
public class ServletCotextListenerServletAdaptor implements Servlet {
private ServletConfig config;
private ServletContextListener listener;
private Servlet delegate;
public ServletCotextListenerServletAdaptor(ServletContextListener listener,
Servlet delegate) {
this.listener = listener;
this.delegate = delegate;
public void init(ServletConfig config) throws ServletException {
this.config = config;
listener.contextInitialized(new
ServletContextEvent(config.getServletContext()));
delegate.init(config);
public void service(ServletRequest req, ServletResponse resp) throws
ServletException, IOException {
delegate.service(req, resp);
public void destroy() {
delegate.destroy();
listener.contextDestroyed(new
config = null;
public ServletConfig getServletConfig() {
return config;
public String getServletInfo() {
return "";
news:ejie3m$jlf$1@utils.eclipse.org...
> Hi Simon,
> Best regards,
> Sabine
> > Hi Sabine,
servlet
sufficient
> > HTH
> > -Simon
> >>Hi,
> >>jettybundle.
> >>at
> >>at
> >>at
> >>at
> > vlet.java:110)
> >>at
> > java:68)
> >>at
> >>at
> >>at
> >>at
> >>Best regards,
> >>Sabine
FUDForum. Page generated in 0.03480 seconds
