Home » Modeling » Graphiti » Connections connected to connections
Connections connected to connections [message #718517] Wed, 24 August 2011 15:19 Go to next message
Robert Brodt is currently offline Robert BrodtFriend
I'm having a heck of time getting a connection connected to another connection. Can someone please post a working example?
Thanks!
Bob
Re: Connections connected to connections [message #719259 is a reply to message #718517] Fri, 26 August 2011 14:00 Go to previous messageGo to next message
Michael Wenz is currently offline Michael WenzFriend
There's a small sample implementation in the Sketch test tool (available in
the Git repository in the tests folder) which at least explains the basic
usages.
HTH,
Michael
"Bob Brodt" <forums-noreply@eclipse.org> wrote in message
news:j33463$gv2$1@news.eclipse.org...
> Thanks!
> Bob
Re: Connections connected to connections [message #726509 is a reply to message #719259] Sun, 18 September 2011 12:12 Go to previous messageGo to next message
Andreas Graf is currently offline Andreas GrafFriend
Hi all,
are you referring to AbstractSketchCreateSimpleConnectionFeature.java? To this piece of code:
if (startAnchor == null && (context.getSourcePictogramElement() instanceof Connection)) {
			Shape s = SketchUtil.createConnectionPoint(context.getSourceLocation(), getDiagram());
			startAnchor = cs.createChopboxAnchor(s);
			Connection splitConnection = (Connection) context.getSourcePictogramElement();
			createConnection(splitConnection.getStart(), startAnchor);
			createConnection(startAnchor, splitConnection.getEnd());
			EcoreUtil.delete(splitConnection);
It seems that the "connection to a connection" functionality is actually a "split connection in two" functionality? Is that so? From the above code, I would also assume that e.g. any decorators get lost? What happens if you click on the now split connection? Will only half of it get selected?
Andreas
Re: Connections connected to connections [message #727028 is a reply to message #726509] Tue, 20 September 2011 08:20 Go to previous message
Yes, that's right. The coding basically splits the existing connection into
two new ones. Decorators would have to be moved along to the new
connection(s) as it it suitable for the tool. Selecting a part of the split
connection will select only one part.
The functionality offered by Graphiti is intentionally very basic to enable
tool builders to create a bunch of different behaviours when splitting
connections.
Michael
Previous Topic:Does Graphiti support fill patterns?
Next Topic:Transient (run time only) graphics in Graphiti?
Current Time: Mon Jun 18 19:42:34 GMT 2018
Powered by FUDForum. Page generated in 0.01722 seconds
