Home » Modeling » Graphiti » TransactionalEditing Domain problem
TransactionalEditing Domain problem [message #716397] Wed, 17 August 2011 09:48 Go to next message
Murthy Bhat is currently offline Murthy BhatFriend
I have a Graphiti based diagram editor which allows for editing my domain model graphically. Now, I have a case where i have to manually modify the domain model just before save. But when i try to run a "RecordingCommand" I get the error saying "Cannot activate read/write transaction in read-only transaction context". Any idea where am I going wrong ? Is it the command ?
Murthy
Re: TransactionalEditing Domain problem [message #716410 is a reply to message #716397] Wed, 17 August 2011 10:37 Go to previous messageGo to next message
Tim Kaiser is currently offline Tim KaiserFriend
Hi Murthy,
how do you execute the command?
At which point exactly (when) do you execute the command (callstack)?
Possibly there is a read-only transaction open already
within whih you cannot nest a write-transaction...
Best, Tim
Re: TransactionalEditing Domain problem [message #716419 is a reply to message #716410] Wed, 17 August 2011 11:19 Go to previous messageGo to next message
Hi Tim,
Thanks.
I am executing this command in the doSave() method of my own ResourceFactory. I need some changes to be done to the domain model before its persisted onto the file. So I set my values using the record command. Something like this :
      public void doSave(OutputStream outputStream, Map< ? , ? > options)
            throws IOException
      MyModel myModel=...;
      TransactionalEditingDomain editingDomain = getEditingDomain(resourceSet);
      final CommandStack commandStack = editingDomain.getCommandStack();
      commandStack.execute(new RecordingCommand(editingDomain)
         protected void doExecute()
              //My custom Changes
              myModel.setCustomName("");
   super.save(outputStream, options);
Murthy
Re: TransactionalEditing Domain problem [message #716426 is a reply to message #716419] Wed, 17 August 2011 11:32 Go to previous messageGo to next message
The command looks good.
How is your doSave method interwoven with the Graphiti framework?
Re: TransactionalEditing Domain problem [message #716501 is a reply to message #716426] Wed, 17 August 2011 15:05 Go to previous messageGo to next message
My resourceset contains as contents (GraphitiDiagramModel+MyModel) which are linked to each other. I was wondering if modifying the resourceset (modify its contents) is affecting the emf transaction due to its graphiti connection?
Murthy
Re: TransactionalEditing Domain problem [message #716742 is a reply to message #716501] Thu, 18 August 2011 09:46 Go to previous message
Hi Tim,
Thanks for the suggestion. I guess I had another read-only transaction open already over which i was trying to run another transaction. By moving my model modification to a much earlier state i was able to resolve my problem.
Murthy
Previous Topic:Using user defined shapes in Graphiti
Next Topic:Adding Shapes Programmatically
Current Time: Fri Feb 23 12:48:51 GMT 2018
Powered by FUDForum. Page generated in 0.01760 seconds
