Home » Eclipse Projects » Jubula » Check multi-line text block
Check multi-line text block [message #715862] Mon, 15 August 2011 19:43 Go to next message
karmatic  is currently offline karmatic Friend
I want to validate/check a text field with multiple lines of text.
example
Beispielstrasse 7
12345 Neverland
How can check if the content of both lines are correct using Jubula? If I write the whole address in a single line it gives an error.
Important! The address is a one text block with line breaks.
Re: Check multi-line text block [message #715961 is a reply to message #715862] Tue, 16 August 2011 06:09 Go to previous messageGo to next message
Alexandra Schladebeck is currently offline Alexandra SchladebeckFriend
Using regular expressions to check the data will let you do this:
http://help.eclipse.org/indigo/topic/org.eclipse.jubula.client.ua.help/html/reference/node4.html
Alex
Re: Check multi-line text block [message #716011 is a reply to message #715961] Tue, 16 August 2011 08:17 Go to previous messageGo to next message
Alex Schladebeck wrote on Tue, 16 August 2011 02:09
Link
Alex
@Alex
Thank you for the quick reply. In fact I have visited the exact link before I posted my problem. As far as I understand in Parameter value I should enter,
'Beispielstrasse 7\$12345 Neverland'
But when I run the test it wouldn't recognize the regexp.
I also tried the following Parameter values.
'Beispielstrasse 7\n12345 Neverland'
Beispielstrasse 7\\n12345 Neverland
Re: Check multi-line text block [message #716021 is a reply to message #716011] Tue, 16 August 2011 08:32 Go to previous messageGo to next message
The version with the two backslashes:
works for me.
Are you using the operator "matches" for the check?
If you're still having problems with the line break, then you could use .* instead as a workaround.
Alex
Re: Check multi-line text block [message #716034 is a reply to message #716021] Tue, 16 August 2011 09:02 Go to previous messageGo to next message
Alex Schladebeck wrote on Tue, 16 August 2011 04:32
works for me.
Alex
Hmm.. I tried your last suggestion as well.
As you can see on the attachment, it still doesn't work. I have no idea what else I can do.
Thanks again for the quick response.
index.php/fa/3663/0/
  • Attachment: regexp.png
    (Size: 34.08KB, Downloaded 578 times)
[Updated on: Tue, 16 August 2011 09:02]
Report message to a moderator
Re: Check multi-line text block [message #716051 is a reply to message #716034] Tue, 16 August 2011 10:28 Go to previous messageGo to next message
It looks like you're using backslash in front of the .* for the regex - that's not necessary. If you take away the backslash it should work.
Re: Check multi-line text block [message #716055 is a reply to message #716051] Tue, 16 August 2011 10:56 Go to previous messageGo to next message
Well, I tried that too. Sad
index.php/fa/3664/0/
  • Attachment: regexp2.png
    (Size: 34.23KB, Downloaded 480 times)
[Updated on: Tue, 16 August 2011 10:56]
Re: Check multi-line text block [message #716069 is a reply to message #716055] Tue, 16 August 2011 12:00 Go to previous messageGo to next message
It may be the case that you need to place .* after each item as well.
Max Mustermann.*Keplerstr. 10.*22765 Hamburg.*
or
Max Mustermann.*\\nKeplerstr. 10.*\\n22765 Hamburg.*
both give me correct matches in a test I did here.
[Updated on: Tue, 16 August 2011 12:00]
Re: Check multi-line text block [message #716117 is a reply to message #716069] Tue, 16 August 2011 13:39 Go to previous message
Thank you very much for being so patient. The last suggestion did work.
Previous Topic:Upcoming training courses at BREDEX
Next Topic:tests case to log in
Current Time: Fri May 25 15:09:55 GMT 2018
Powered by FUDForum. Page generated in 0.02081 seconds
