Home » Modeling » Graphiti » Installing graphiti together with the plugin(setting graphiti as a dependency for a update site)
Installing graphiti together with the plugin [message #715322] Sat, 13 August 2011 10:54 Go to next message
Phillipp  is currently offline Phillipp Friend
I'd like to provide a update-site for the plugin I developed and just can't figure out what to do to get eclipse to install graphiti automatically when my plugin is installed.
Re: Installing graphiti together with the plugin [message #715695 is a reply to message #715322] Mon, 15 August 2011 08:46 Go to previous messageGo to next message
Tim Kaiser is currently offline Tim KaiserFriend
Hi Phillipp,
normally it should be enough if your plug-in defines
the respective dependencies to Graphiti in your bundle description(s).
Since a normal Eclipse Indigo install has the indigo
update site defined by default, the installer
should be able to install Graphiti automatically.
Which dependencies are defined in your plug-in?
Best, Tim
Re: Installing graphiti together with the plugin [message #716745 is a reply to message #715695] Thu, 18 August 2011 09:54 Go to previous messageGo to next message
My plugin depends on Graphiti 0.7.2 and it seems that Helios is not resolving this issue automatically.
Re: Installing graphiti together with the plugin [message #717130 is a reply to message #716745] Fri, 19 August 2011 10:55 Go to previous messageGo to next message
Michael Wenz is currently offline Michael WenzFriend
Helios cannot relsove that because Graphiti is not part of it. Graphiti
joined the release train in Indigo, so using Indigo would solve this.
For Helios you would need to find a way to add the Graphiti update site to
the retrieval process (not sure how to achieve that).
Michael
"Phillipp" schrieb im Newsbeitrag news:j2imrk$ndk$1@news.eclipse.org...
Re: Installing graphiti together with the plugin [message #719965 is a reply to message #715322] Mon, 29 August 2011 15:12 Go to previous message
ok, we updated to Indigo and Graphiti 0.8.0 and that solved the problem.
Was pretty painless Smile
Previous Topic:Connections
Next Topic:Diagram size seems ignored
Current Time: Fri Apr 27 05:10:28 GMT 2018
Powered by FUDForum. Page generated in 0.02128 seconds
