Home » Modeling » Graphiti » Setting own file extension for Graphiti Diagram
Setting own file extension for Graphiti Diagram [message #707255] Mon, 01 August 2011 11:51 Go to next message
Phillipp  is currently offline Phillipp Friend
Hey since most of the work on my editor is done I would like to have my own extension for the diagram instead of ".diagram". I have found out that you have to redirect the new extension to the contentprovider from graphiti. At least that is what I concluded from this eclipse help site . My problem now is that I can not find out the contentprovider ID.
Thanks for your help!
Re: Setting own file extension for Graphiti Diagram [message #707872 is a reply to message #707255] Tue, 02 August 2011 06:57 Go to previous messageGo to next message
Joerg Reichert is currently offline Joerg ReichertFriend
Member
Hi Phillipp,
this is defined in the graphiti.ui plugin.xml
The content type with its file extension:
   <extension
         point="org.eclipse.core.contenttype.contentTypes">
      <content-type
            file-extensions="diagram"
            id="org.eclipse.graphiti.content.diagram"
            name="%_contenttype_diagram">
      </content-type>
   </extension>
and the binding of the content type to the diagram editor:
   <extension
         point="org.eclipse.ui.editors">
 	  <editor
          class="org.eclipse.graphiti.ui.editor.DiagramEditor"
          contributorClass="org.eclipse.graphiti.ui.editor.DiagramEditorActionBarContributor"
          default="true"
          icon="icons/diagram.gif"
          id="org.eclipse.graphiti.ui.editor.DiagramEditor"
          matchingStrategy="org.eclipse.graphiti.ui.editor.DiagramEditorFactory$DiagramEditorMatchingStrategy"
          name="%_diagram_editor_name">
       <contentTypeBinding
             contentTypeId="org.eclipse.graphiti.content.diagram">
       </contentTypeBinding>
      </editor>
   </extension>
So you have to redefine both extensions in the plugin.xml of your plug-in to use your preferred file extension.
Joerg
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
[Updated on: Tue, 02 August 2011 06:58]
Report message to a moderator
Re: Setting own file extension for Graphiti Diagram [message #711444 is a reply to message #707872] Sat, 06 August 2011 06:16 Go to previous message
Thank you
Edit:
I found out it works for me when I just put a new file-association in my plugin.xml:
<extension
       <file-association
             content-type="org.eclipse.graphiti.content.diagram"
             file-extensions="mynewfavouritediagram"
             file-names="My_Diagram">
       </file-association>
    </extension>
[Updated on: Sat, 06 August 2011 07:26]
Previous Topic:dynamical CreateFeatures ?
Next Topic:Creating a model browser
Current Time: Sun Apr 22 01:37:08 GMT 2018
Powered by FUDForum. Page generated in 0.02645 seconds
